TIRES - Sizes, brands, etc. - What do you run?
Reason why is beause the contact patch is smaller and the weight of the vehicle is concentrated and given more Pound Per Square than a wide tire or like dual trucks which can be rather wild. Now that I got 2 trucks in the 20's MPG bracket either gas or diesel powered tire do make a affect in MPG like it or not.
Prayer Time for MoparMom
Actually I do like Lima Beans... As for MoparMom she healing up good and getting plenty of rest and naps in. She gaining her strength back a day at a time. Tomorrow the Doc gets to take a peak at her beak and see if it healed up good.
$3.49
Hmmm... Don't I wish. Diesel up here is still $4.169 a gallon. But now that I crossed 22.6 MPG with the 96 Dodge 1500 and unleaded is 3.489 a gallon I'm happy. Now I got 2 trucks that can do 20+ MPG now one gas powered and one diesel powered.
Heater Treater
- Prayer Time for MoparMom
- Extreme cold!!!
Hmmm. That's the trick I guess the fact you can keep constant low temps in the minuses. Where driving down into the canyon you rise in temperature into the positive 30's and get up to New Meadows Valley it could be a minus temp so I've got to work with variable temps over terrain.- Heater Treater
Hopefully your smart and lubed all the pivot up with a dab of grease.- Extreme cold!!!
Personally I don't like the cardboard in front of the coolers or in-between. I've actually seen so seriously high engine coolant temps with cardboard in either setup but winter front on the grill there is just enough cold air in the lower bumper to keep things controlled on mild days.- Extreme cold!!!
That's a tough thermostat to get up here in Idaho no one even stocks the 200*F 6.7L thermostat. I'll just have to custom order it I guess.- Air Filter
Wow. I've learn more again. I didn't know they had mass-air flow sensors on the 6.7L Cummins. So adding a larger filter will set a mass-air flow sensor code? Interesting.- Prayer Time for MoparMom
MoparMom returns home. So now its watch and see time for 2 days.- Prayer Time for MoparMom
Man its hard to sit around waiting for the phone to ring and tell me any news. "Diesel" the dog is just totally beside himself right now constantly hunt through the house looking for Mom.- Oil pump housing failure, probable rebuild...
Well there went my though. Man I got to admit that sucks to have something a small as a gear tooth wipe out the oil pump and possibly the rest of the engine. So did you get to open up the engine and verify the internal stuff like bearings?- Hello from Ca
DRBIII tool which only the Dodge Dealer would typically have.- Prayer Time for MoparMom
Last night MoparMom end up with a severe nose bleed. I rushed her to the hospital at about 3am. The wonderful doctors got control of the bleeding. I'm kind of mental wreck right now but I think you can understand that. Doctor at this point is chalking up to stress and what has been happening last few days. Our neighbor (mail person) is going through a long drawn out divorce case (2 years now!) and we've been helping her get through it. If you don't mind gang would you please offer a few prayers for MoparMom. :pray:I just talked to her on the phone shes doing good and going to try and catch up on some sleep. Been a long night for both of us...- Extreme cold!!!
I've got my own home made grill inserts that typically amp up the coolant a few extra degrees like 193-197*F and a small boost to IAT temps.- Oil pump housing failure, probable rebuild...
Ouch... That going to hurt more than the turbo I fed a hose clamp. Ekkk... I kind of wonder about the cam gear since its not stock and maybe there was a minor defect in the gear. Since between bill and yourself you got more information to nail down this issue.- Hello from Ca
Welcome to the family. As far as the error code P1694... http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/232-p1694-no-bus-message-received-from-companion-module Before jumping out there you might want to double check the diagnostic first for clues and check over wiring issues.- New revised MPG/High idle switch design
MPG Fooler - Attempts to mimic summer temperature to increase MPG. Since the only sensor that changes sue to weather is IAT sensor. High Idle 6 & 3 Cylinder - Allows you to select either mode to warm up your truck quickly in the cold winter or maybe keep the alternator amped up while working or maybe set high idle for the hot days to cool the truck down with air conditioning.- Here are another couple of geniuses living in our world...
I had to like than and toss it back out on my FB...- Fuel pressure gauge..
Here is what I order for people... http://www.alligatorperformance.com/gauge-mechanical-fuel-pressure-black-p-1678.html- Boost pressures?
For drilling for the EGT's.. For you boost gauge...- TDI
Nice. That's certainly cheap for fuel...- New revised MPG/High idle switch design
Last I knew Ed is working on the cubby hole setup first and will work on others really soon.- 1996 Dodge Ram - MPG Report
Another lap to the grocery store for miscellaneous stuff. No cheating here I'm still driving the 1996 Dodge 1500. You'll notice my Tmg (total for the tank is a bit low) I made a run to New Meadows, ID and haul a trailer load of pallets back for a neighbor. But I've now broke over 20 MPG with a 5.9L V8 engine now with a Automatic Trans...Vitals I can give...1996 Dodge Ram 1500 - 5.9L Magnum V8 - 46RE Automatic Trans - Mopar Performance PCM - 3.55 Gear Ratio - Scaled 5,200# Fuel: 87 OctaneTrip: 90 Miles TraveledCargo and Passengers: 2 on board (350#), groceries (80#), 1/2 Tank of fuelHigh Temp Outside: 35*FSpeed: 55 MPH or lower speed limits never exceeded 55 MPH.IAT: varied from 95-105*F.Coolant Temp: 191-193*F Tire Pressures: Front Axle: 43 PSI - Rear Axle: 29 PSIElevation: McCall, ID 5,100 feet approx.Home: 2,800 Feet measured.Going up I used 3rd Gear all the way from home to McCall, ID then at select times that I could I would use 4th gear (OD) on the way down. Tmg - Total For the Tank - 17.8 MPGCmg - Today's MPG - 21.6 MPG - Prayer Time for MoparMom
