  1. Welcome to the family.
  2. What funny I use to work in a local paint shop and all I did was demolition work pull old damaged panels off either from a accident or from a rust damage. Yes. Most panels can be cut free from a spot weld seam then replaced and spot welded again.
  3. Good ol' Tom stirring the pot.
  4. I tend to want to follow diesel4life for the first part in double checking everything before even thinking of buying a ECM. Make sure you not fighting a wiring issue, alternator or something else.
  5. Hmmm... I took care of my terminals all these years and still have factory wire terminals now. But in the pass the few fire trucks I've had to re-do I typically went out to the Cummins shop in Grangeville, ID and picked up a new length of welding cable and solder on terminals. I would solder on a new battery terminal and a new ring terminal and replace the wire as a whole. Reason... You more than likely find out cutting off the terminal head and find the copper strands corroded as well most just try using clamp on style terminals at this point the cable tend to fail rapidly because of easy access of acid to the cable.
  6. Ohm meter the ABS sensors make sure the wire aren't internal broken I've here and done this before and had a ABS sensor lead break internally. If replacing you MUST replace in pairs you can't replace one sensor alone in the front axle.
  7. Another update... I'm now down to 21.9 MPG Vitals I can give... Cargo and Passengers: 2 on board (350#), groceries (80#), 5/8 Tank of fuel High Temp Outside: 60*F (20*F colder) Speed: 55 MPH or lower speed limits never exceeded 55 MPH. IAT: Forced to 143*F checked actual a few times and it varied from 100-105*F. (10*F colder) Coolant Temp: 193-195*F Boost: 1.5 to 3 PSI on the flats and tried not to climb much above 10 PSI while climbing grades. EGT's: (450-500*F down) (550-600*F up) on average max'ed out at 750-800*F climbing 7% grade at 35-40 MPH (not count slowing down for corners acceleration.) Tire Pressures: Front Axle: 58 PSI - Rear Axle: 40 PSI Fuel was treated for 128:1 ratio 2 cycle oil. Air Conditioning was on and used (Defrosters). Elevation: McCall, ID 5,100 feet approx. Home: 2,800 Feet measured. Riggins, ID 1,800 feet approx. NOTE: This trip is going to exclude the trip to Riggins, ID so the distance is now for this trip 70 miles.
  8. I would pull the regulator out and inspect it for damage or debris.
  9. I've seen vacuum lines damaged by mice, vacuum motors damaged by BB's from a air rifle, I've seen vent doors stuck because of a 1 dollar bill wedged in the door, the list goes on... You might take some time and look under the dash for common vacuum issues first but worse case your pulling HVAC box out.
  10. Actually mine didn't get that bad but noticing a slight wetness at that seam and check the nuts and sure enough the nuts where not very tight.
  11. I would do like Flagman says... I would either fix the current headlight case to prevent water leakage or just replace with a junkyard headlight. Then I when out and bought a set of Silver Stars and they are lasting a long time.
  12. I talked with him for a short time and it had something to do with air bubbles in the return line. This is what he chasing right now. There a pump on the back of the CP3 that he ordered.
  13. Yes. Diesel fuel has to heated to 150-180*F to reach flash point. So below these temperatures diesel fuel will not readily ignite with a open flame. I've been direct plumbed like this for over 8 years now and no issues at all. Gauge has worked flawless for the 8 years. The tubing you see in the pictures is Air Brake Tubing and its rated for a burst pressure of 600-800 PSI so I hardly doubt a mere 15-20 PSI pump will blow it.
  14. Just left him a message so I can get more feedback on this...
  15. Actually it can't be done that way. What we are basically doing is unhooking the IAT sensor and stuffing a resistor 2.2k ohm in the plug. So no its not a momentary thing for the MPG fooler. But for the high idle it is. But then again if you start with timer circuits and PCB design your adding cost to it. I know Ed is working darn hard to keep the cost down and keep the design easy.
  16. I've had that happen only once. After the occurrence I just filled it back up and ran it. Never done it again. :shrug:Mine seem to push it out the cap and on to the floor. Dang sick pump puking on the floor.
  17. No codes that I've been told.He describes it as like a piston slap knock kind of.Unknown on the cetane boost I'll ask.
  18. You might have to pull the regulator out and clean and check it for damage. After seeing the adjustable regulators in another post here now I know why you guys have problems. Way too much hardware in one little hole. But I would pull it out and check the regulator for binding or debris.
  19. At least you got good idle pressure!
  20. Like myself I'm running Edge Comp (5x3), +50 HP Injectors and HX35 Turbo and its absolutely fine for a combination. Towing power is awesome and EGT's are very controllable. He's running... The only thing about a turbo upgrade is the amount of lag you might add.
  21. EKkkk! I highly suggest against the 45* cuts. Draw Straw I without any cuts. I've got the thickness of a quarter (coin) from the bottom and 4 small notches on the tip no more that 1/16 of inch deep. You have to remember the bottom of the tank will defect when going from empty to full almost a full 3/8" difference. As for the flow issue I would go back over all the plumbing and verify there is no hard kinks or bends that might slow flow down. Then also double check the pressure regulator I've heard they had issues.
  22. Damage to both lift pump and VP44. Maybe even the fuel tank as well.
  23. The only thing I don't like about it. Here in Idaho I see summer temps as high as 115*F and we all know about the heat soak issues with the VP44. The fact a mechanical pump is that low at idle bother me. Where my AirDog is nearly solid and never moves much from 17-18 PSI as of lately. In your case make sure to kick the idle up after starting hot to purge the heat from the VP44 you need to get above 14 PSI to get the overflow valve open.
  24. Just need to yank out those 6 speed trans and slap in a 5 speed. I only use 4 quarts (1 gallon) no problems and no 5th gear problems.
