Fire Academy
Our final car was up-side-down and the top was crush. This was to simulate a roll-over accident like leaving a canyon road and rolling down a embankment. Well our class did excellent and managed to open up the car in a move called a Oyster Cracker. It's where you remove the front fender, cut the front door hinge, rip the nader pin, then cut your rear door hinge and pop the other nader pin. Using struts to stabilize. Now cut the B post lay down on the ground. Put a ram in place and slightly lift. Now cut A post and C post. Now lifting slowly with the ram 2 guys are ratcheting the struts in tighter lifting the car and the ram is holding the roof down it turn Cracking the Oyster open freeing the patients. So this is where the instructor said you want to see a garbage truck? Hua?! We all voted "Yes!" So cut 2 relief cuts near the B post in the floor using 2 come-a-longs we managed to fold the backseat up on top of the car. So the backseat was up right and the cab was up-side-down. My buddy Kelly got the shot of all us around the Garbage truck. Oyster Cracker http://www.fireengineering.com/topics/m/video/31233413/oyster-cracker.htm
Fire Academy
MoparMom goofed... I took extrication class but arson was my second choice. So I had 20 hours worth of being certified to cut up vehicles for 3 days. Doesn't matter how you crash there is a way to cut you out of that steel can. You'll have to wait I've got to the pictures from my buddy phone. Like I dummy I left my memory card in the computer for my camera. :banghead:
Lift pump reccomendations?
I've got a old school AirDog 150 before the new owners messed up a good design...
Just want to say Thank you!!!
Out of respect and better coverage I moved your post to... http://forum.mopar1973man.com/threads/8429-Lack-of-power
Coolant
Been using standard yellow or green coolant now for +200k miles and zero damage here. It based on doing the coolant flush and change as recommended by the owners manual at 30k miles. I don't get hung up on the extended life coolant or the 5 year 100k miles stuff either. The fact is most all coolant system damage comes from the fact of people leave the coolant in way too long and the coolant turns corrosive over time. This is where the pH level shifts from 7 either towards 0 (acidic) or toward 14 (basic) either way is corrosive. Regardless of the brand of coolant if you want to do extended change then I highly suggest you get coolant test strips for check pH level. This is what extending coolant changes does... Changing every 30k miles as required by the manual... No problems.
Whats going on here?
Change you thinking. Don't move and alter ing to over come the AC noise. Why not just kill the AC noise source by fixing the alternator and be done with it. Because 99% of the time if you unhook the alternator and take a test drive the problem is gone so that alternator typically will be the problem.
Well hang around and post lots of questions. There is no such thing as a dumb question here. Just a unanswered one.
diesel problems, same ol, different machine...
Pickled mouse doesn't even sound good.
Tire Pressure Calculation
Don't I wish. I would love to get his type of tire wear but sure not going to happen with the things I have to do with my truck.
Knock while cold.
I haven't heard anything yet...
2-cycle oil Lubricity results
Loss of MPG from excessively low cetane.Excessive thick fuel (high cSt score) might not atomize good and put extra stress on the injection pump.
Like I said Tracy...
I think we all are just a wee bit that why when they say "Birds of a feather flock together". Just watch out this is a majority guy site some of them can be at times... But welcome again Tracy.
Exploded View Of a Bosch VP44 pump
123. Torx Screw Fillister805. Part Set Control Unit471. Closing Cover109. Cheesehead Screw480. O-ring127. Sealing Ring111. Torx Ovalhead Screw107. Angle Of Rotation Sensor135. Control Valve134. O-ring133. O-ring207. Spring Lock Washer206. Hexagon Nut810. Overflow Valve104. Screw Plug105. Flat Seal Ring398. Screw Plug397. Flat Seal Ring
20. Cam Ring19. Driver Disk21. Roller Shoe22. Roller12. Drive Shaft205. Selection Key17. Selection Friction Washer10. Torx Flathead Screw9. Support Ring7. Supply pump
61. Torx Oval Head Screw62. Spring Lock Washer805. Part Set Control Unit803. Part Set Restriction54. Gasket63. O-ring49. Torx Fillister Screw50. Hydraulic Head51. O-rings25. Deep Groove Ball Bearing23. Friction Washer
38. Screws37. Closing cover30. O-Ring39. O-Ring36. O-ring35. Hydraulic Stop42. Compression Spring801. Part Set of the Timing Piston
Ok... I dug through the part list and never found. Here is a picture of the seal kit used for rebuilding. All violet colored parts are in the seal kit. Mostly o-rings and gaskets. Notes Take notice this is the 4 cylinder version.
#51 are 3 o-ring seals. Give me a bit I'll get digging on this...
More than welcome I'm glad to to be able to help you by have the web site and a weird collection of people.
I have to agree with AH64ID about te roads here in Idaho and the impact they have on tire rubber. I typically see about 30-35k miles from tires. My biggest eater of tires is haulling firewood. The miles of hauing heavy up and down the mountain chews the rubber up fast. Even my exhaust brake eats the rubber quickly. But as for the formula its a good base line number to start from and tweak. I've been through 2 sets of tires now and never had a blow out or serious tire damage from poor inflation numbers.
Here you go gang. I've hit the jackpot and fond some more information on the Bosch VP44 Injection Pump. Now we can at least see what's in the pump a bit more...
Correct Clutch Pedal Adjustment
I've got a Southbend Con OFE single disc clutch and stock hydraulics and there is no adjust or need for adjustment.
I'm running 16" x 7" rims on both the 96 and the 02 both trucks with 235's now. Still if I over inflate on either truck I can measure a difference in tread wear from center to shoulder. You can see it a bit more with the eyes after running a dirt road. That's what got me think about the tire pressure vs. weight.
You can over-inflate your tire to improve your MPG numbers but now your tire wear becomes more in the centers and less on the shoulders. Traction on dirt roads is also reduced and ride is rougher. Using the math gives you a middle of the road for the weight you are now currently carrying. Good ride, good tire wear, good MPG numbers. It handles its weight just fine, traction on dirt roads is OK. Under-inflation you gain good amount of traction in loose dirt and on snow. But take a risk of blow out if hauling heavy. Then the tire wears more on the shoulders than in the centers. Usually the truck feels squirrelly and mushy. Between using a tread depth gauge and the math I can tune the pressures to get the best ride and tread life from the tire. Typically my MPG's are unaffected by using the formula for pressures. Being I'm now capable of reaching mid-20's when I want to with a empty truck.Ok lets use AH64ID table...245/75 R16 tire in the table list at 35 PSI at 1,700 pounds.Formula now...1700 / 3042 = 0.55 x 80 PSI = 44 PSI1865 / 3042 = 0.61 x 80 PSI = 49 PSI2030 / 3042 = 0.66 x 80 PSI = 53 PSI2205 / 3042 = 0.72 x 80 PSI = 58 PSI2335 / 3042 = 0.76 x 80 PSI = 61 PSI... I think you see a difference.
