  1. This tale is all but closed now. I got my rebuilt turbo about 2pm this afternoon from theBrown Man. Dropped everything grabbed the box and shot pictures of my pretty new turbo.So I prompty packed up and hauled down to the shop. During assembly all fasteners where coated in a liberal coating of anti-seize. Install my new BHAF not to risk the thought of debris in the old filter ruining the new turbo. I still got to drill my hole for the filter minder later. So to prime the turbo with oil I pull the fuel pump relay and cranked on the engine till oil pressure was shown on the gauge. Then plugged in the relay and fire it up. Music to my ears! The Cummins is back in action again. So I rolled it outside and proceeded to clean up tools and things while the truck idled and warmed up. 5-10 minutes later I hopped in and rolled down the road toward the fire house light and easy keeping boost mellow. Turned around head back for the house and on got it a bit and 2nd gear the tires broke loose. Shifted to 3rd got into again and tires barked. The butt dyno was happy as hell. Came back home left it idling. Paint was burning off the exhaust housing. Checked for oil leaks and all was good. So I grab some tools and my jacket and hauled for town. Oh man is so nice to have the beast back. So after a trip to town and playing I came back installed the whistle ring and change over to my 235's tires since winter snow is fading away fast here. Went for another test run and damn truck keeps breaking the tires loose if you get into the throttle in either 2nd or 3rd gears... So I'm extremely happy.
  2. Yes across the battery terminals. Look at your DC volts then flip right over to AC volts it should not be above 0.1 volts.
  3. So what there it get up at 6am for? Sun not even up around here. Everything is closed... Since I work mostly from home what there to get up early for?
  4. Showered, shaved, dressed, ate breakfast, open the gate for the Brown truck... "Hurry up Mr. Brown Man!"
  5. Trust me I'm just and waiting for it to come tomorrow I'll be up early start a fire in the shop stove and get it warm in the shop. come on Mr. Brown Man... I'll even have the gate open for him!
  6. That it will. But you might lose a bit of MPG from it.
  7. The only thing to verify is the sensors. (Cam or Cam/Crank) I can never remember which year that crank sensors ended. But there was a change in the tone wheel on the cam when the crank sensor was obsoleted.W&F is right you want to swap the ECM over too.
  8. I got ahold of GOS performance and had them track down my turbo. It's suppose to be on the brown truck tomorrow. So I'm getting all warm and fuzzy about this I can finally get the truck rolling again...
  9. I won't go there I'm sure ISX would gladly mount his camera under the truck to show you that. As for blow by typically it increase with boost pressure just the way things are. But I would say it going to be the vacuum lines are off first. If that all checks out then next step would be doing a compression test to verify the cylinder health.
  10. I typically use a high quality DVM like a Fluke or similar. check you DC volts then flip to AC and see if its over 0.1 Volts AC if its higher its a fail. http-~~-//www.youtube.com/watch?v=UveGtGuswBw
  11. Don't get me started with that... Air Starters and Jake Brake are the Best sound bytes!
  12. Dumb question here. Could someone explain why they would hold open the exhaust valve? I thought it was to hold closed the valve to create pressure to create braking force like the exhaust brake? Someone school me on this... :shrug:EDIT: Nevermind I found my own answer...
  13. Correct... That was back in 2007 at Merdian Motorsports in Merdian Idaho...
  14. Here you go... Male fittings (JIC) http://www.vulcanperformance.com/JIC-AN-adapters-s/187.htm Female fittings (Push loc JIC) http://www.vulcanperformance.com/Pushlock-Fittings-s/186.htm
  15. Air Bleed... Mag x10 Let's say that a single strand of 14 AWG copper wire will not fit but a single strand of 16 AWG will... Not very scientific measurement but gives you an idea of size its very very small hole.
  16. Hey... He got up early and drove from Boise, Idaho to see me.
  17. Everything looks good so far. Just need to add fuel. I don't see any weakness so far to worry about.
  18. Geez... Picky picky picky...
  19. Yea... Pplayx3 came out to the house to meet me in person and talk a bit of shop. He's driving a good looking 99 Dodge 3/4 ton. Street machine, that is totally stock and most likely going to stay that way for long time according to Pplayx3. He should pop on the site this evening and respond...
  20. :thumbup2: 2 thumbs up here... I didn't watch the game at all... Not a football fan...
  21. Not really. Because the overflow valve is the limiting factor. With the check ball and the size of orfice I doubt there would be any gains to oversizing the return line. Then on top of that there is no need for exceeding 20 PSI because by 14 PSI the overflow valve is open and flowing strong.
