  1. If you going to use any battery maintainer make sure to check the electrolyte levels monthly. Even though most battery chargers tend to charge at a very low rate and very safe the battery will still vent moisture from the battery over time and dry out. Event the battery bank here at the house uses about 1-2 quarts of distilled water a month. My Rv uses about 4-8 ounces of distilled water a month and so does the truck. This is one reason why AGM and sealed batteries tend to fail at a shorter life span vs. wet cell batteries because no matter what you do or how slow you charge the battery it will vent moisture as the cells warm and expand. This will never change. Now once the plates are allowed to dry or partial dry then the cell is ruined permanently. Even if you re-load with distilled water and recharge it ruined it will never have the same capacity again. Batteries are a weird animal being they create large amount of current flow chemically between lead plates and acid/water mixture. As the battery discharges then the chemical changes occur to the plates and the electrolyte mixture. So yes. Its best to keep it on a charger. But remember to keep an eye on the electrolyte levels and you'll get long life from your batteries. My first set of OE batteries went 10 years and could of gone farther but didn't want to push.
  2. I just use 100w fog lights instead of modding the stock headlights. I was kind of happy about that last night with the heavy snow storm and them being mounted below the front bumper. Very easy to see long distance compared to the factory head lights.
  3. Your can't because too much torque is lost in the ... Your tires are too tall, too heavy and too wide.
  4. That's the ultimate stack set up. Myself I'm running Edge Comp and RV275's and got excellent power, Good MPG's, excellent street manners (little to no smoke at all), and enough power to break the tires loose in 2nd and 3rd gears.
  5. Just because the alternator is new or even rebuilt I always suggest bench testing before you leave the store. Sure it bad o go through all the trouble and get it installed to find another bad diode. It just best to test before you leave the store.Split the case in half and the diodes are typically just bolted to the rear case. Few screws and wires and change yourself if you can buy the diodes. When I was a pup I use to rebuild the 73 Dodge Charger alternator myself because brushes where about 10-12 bucks and diodes where like 20 bucks. Cheaper than 110 for a new alternator.
  6. Simple to fix...Downgrade your brakes to 2nd Gen rotors and grab a set of 16" rims and your good to go... Heck the more I keep playing with tires and rims the more I want to drop down to 215's. Even lighter yet.Since the turbo was installed I swapped back to the 235's and just bounced back to my 23 MPG on my trip down to Ontario, OR and 21 MPG fighting a snow storm home. Just doesn't get any better...
  7. Well I use a lot of products or stuff that most never even heard of. But are typically found in big chain stores. Like Simple Green. If I just posted Zep Orange Degreaser most would be like Huh? No. I wish... Most of all the fund donated to the site is re-invested back in the site one way or another. There is a rare time or two when people send me gifts by snail mail solely for me.
  8. Heck I just drove the last hour home from Ontario, OR in near white conditions. 235's held up fine. Mine are not even a mud / snow tire but a trailer tire with a Load Range G (3,750# 14 ply). Excellent tire for on-road use but don't stand up to the dirt roads to well.
  9. From here on out I will find a 235/85 R16 mud / snow tire and place it on my steel rim and use them for winter purpose. As for the stock 265/75 R16 I will most likely never buy those again just way to heavy only gain 1.5 to 2 inches in wide for tread face but add a whole 25 pounds per tire more. I'm already back to my 235's now.
  10. Get a hold of Bob Wagner. http://www.smartypower.com/ Phone: 1-888-225-7637 (Toll Free) Out of Area: (253) 735-6281
  11. Crazy idea. Could you find a live data tool like a ScanGauge II and monitor your IAT temps?
  12. I spray on Zep and let it soak on a slightly warm engine about 140*F and then wait a few minutes and blast it off.
  13. Here is my set up with heat shield.I did notice with my newer BHAF the plastic is much thicker and I had to hollow out a spot so the grommet could be use.
  14. Delayed... MoparMom wasn't feel too hot this mornings so trying for tomorrow...
  15. I was in the BHAF. I've found all the piece of the hose clamp the two thumb tabs and the ring itself. After slinging it around a enough time it spit it back up into the BHAF. But I might not of seen the ring fall out when I pulled the tube off. But the 2 thumb tabs were inside the BHAF.
  16. Here is how to do it. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/24-air-system/122-turbo-inspection
  17. My irrigation system is about 116 PSI at the hose and does a wonderful job of cleaning all the grease and grime off the engine. This allows me to keep track of oil leaks and where they are coming from. Everytime the truck gets washed the engine and all the underside is rinsed off too.
  18. Hey Gang...I got called out for a fire call tonight. Basically it was a local woman driving home from work and fell asleep at the wheel. Make matters even more interesting the total trip from town to her house is about 5 miles and she was less that 0.1 from home where she went in at. She was not hurt but the vehicle is totalled.So why I'm posting this I know lot of you drive long distances at times. Please... If your not feeling good or just not firing on all 6 cylinder please make a phone call and get a ride home. No sense in getting hurt or damaging your vehicle just because you going to push those last few miles home. I'm posting this because I care about all you and don't want to see you get hurt.
  19. I guess during my removal of the filter it fell out on the floor of my shop and I found it today cleaning the shop floor.This is what did all this...
  20. Yeah replace the diodes. That's what filters out the noise and the diodes are just wore out or poor quality. You might be able to get just the diodes from alternator shop and do it yourself.Also you might double check with a high quality meter if you don't have one. Fluke or similar should be accurate. A good alternator like my two truck got are between 0.02 and 0.03 Volts AC.
  21. I'll even add if you want you could add you ride information to the article database too. Just get a hold of me and I'll create account for you and then you can post up your ride over there. Maybe even get some of you to help out with write ups.
  22. Well I'm going to get a good night's sleep and then get up tomorrow and give the ol' girl a proper cleaning and shining up. Knock off the winter grime and get ready for nice day ride to Ontario, OR or Boise, ID in the next day or so.
