Ok this is starting to make me mad
I'm not a Cummins parts fan being most parts are NOT produced by Cummins and not worth the money. I've seen failed head gaskets (Cummins HG made by BLK) in under 1k miles, Cummins thermostats (made by Mr. Gasket). They are not that sensitive being Timbos APPS is not even a Cummins product or designed for our engine but it works for over 250k miles till mine finally wore out. Just consider the high idle switch again not designed by Cummins but it works no issue by hundreds for people. Again not that sensitive.
New Turbo
For 50 HP injectors stock turbo should be fine. I'm running 150 HP injectors on my stock HX35W (54/60/12). Climbing 7,500 into Bridgeport, CA. No EGT issues at all. My biggest problem was transmission temp that was running high from head winds. Total weight was 17,500 pounds. Boost limited to 35 PSI. Again my final ratio is 3.69 running on 245/75 R16 tires. This is the huge part having proper final ratio. Might be pizza cutter but no EGT issues.
Angry & can't do it anymore, serious iQuad timing issues
I'm starting to think a 64/71/14 is just too big of a turbo. Being I'm on a stock HX35W turbo (54/60/12) with 150HP injectors and EGTs are still controlled. Made my trip to Bridgeport, CA and haul my RV to 7,500 feet of elevation. The total weight scaled was 17,500 pounds total truck and trailer. I ran level 3. The only problem I had was head wind which got the trans temp up to 220°F. No EGT issues. My boost is limited to 35 PSI total.
Did you contact @Auto Computer Specialist and discuss with them?
Thinking I have a boost leak
I'm think turbo cap for pressurizing the intake and air system for testing. Not a blowby test because blowby test you can pass with a cracked piston but would fail if a compression test was done.
I made mine from just plumbing parts at the hardware store. Drilled a hole and installed a air chuck.
2nd Brand New Redhead Popping
Should of done a blue top steering box. Yeah I've had a few issues but Ryan took care of me promptly. He also took the time to verify what was going on with the box and steering. @Blue-Top Steering
2000 24v crank sensor issue
Tach signal is dropping out and ECM is in limp mode trying to keep it running. Might try the new sensor. While the sensor is out you might want to check the tone wheel inside to see if it loose on the crank. I've seen one case here on the website where the tone wheel got loose and was tore off the crank.
What shocks are you running and why?
Both Beast and Thor are KYB currently. Last batch of shocks was Rancho shocks. Lasted a good 150k miles.
DIY vp 44 and ECM. It runs, very happy
Oh fuel pressure during cranking should be 7 to 12 PSI max. Anything over 12 PSI will cause over advancement and not start hence why there is a relay mod to hold the lift pump off till started for the troublesome cases.
Max boost only with WG hose pinched
I'm using my stock HX35W turbo against my +150 HP injectors (7 x0.010 popped at 320 bar). Towed my RV and ATV in the back roughly 17,500 pounds total weight. No EGTs issues. Gearing is extremely important. I'm 3.55 gears but with 245/75 R16 tires I'm 3.69 final to the ground so EGTs are rarely even an issue.
Finally on our way to Florida!
Remember the DemonRats want all the teenagers to have 15 dollar an hour burger flipper. What do you think prices of the burger is going to be?
Replacing head gasket
You could jump the fuel pump relay to supply power to the VP44. Hard to tell really some just seems to ooze and others will spray the hood.
Yup everything is going up in price. Heck you can't get a hambuger in Riggins ID for less than 13 bucks.
Dude that's better than Mono Village. Nice place. You need to look up a few members in Florida and see if you can meet some of the gang.
Fel Pro head gasket gave up in 4k miles
Nope. I had to be over 55 PSI on boost, then my drive pressure was thru the roof which made the cylinder pressures high enough to blow my fuel system out (greater than 4,500 psi) which was enough to blow the gasket. I was also running high timing too. That gasket blew with ARP 425 studs torqued to 125 ft/lbs. Second failed gasket was a defective gasket (Cummins OE) and it blew out sitting in the parking lot and started pissing coolant and not even running. Gasket material let go of the metal base in several place. Now in all back together and torqued to 135 ft/lbs now. No issues towing all the way to Cally and back home to Idaho. That was with head winds and constant boost at 30 PSI and cruise set at either 55 or 60 MPH. 1,100°F EGTs for miles.
Too much fuel pressure at cranking will over advance the timing making nearly impossible to start. Double check the light is coming on instantly with the key. If the wait to start light isn't coming on it will not start because the fuel pump relay will not power up the VP44 nor any other ECM device till that wait to start lights up. Without the ECM booted up it is dead. It will crank but not start.
Tappet or Pushrod Cover Leaking Oil
Yup. Why I normal don't use any sealants where gaskets or seals were installed with silicone. The only place I know where silicone is used on the entire truck... Front and rear differential covers Transfer case halves. Gear case cover. Those places I use grey RTV. No issues I'm at 444k miles and no leaks currently maybe the oil pan gasket.
Keep us up to date. Enjoy...
Good turbo for 150Hp injectors would be 62/68/12 but 64/64/12 (assuming on the 12cm housing) might not work very good. Even my hybrid turbo was a 60/60/12 and it spooled to 53 to 57 PSI but the 12cm housing was killing the drive pressure why my head gasket blew.
Mopar1973Man's Adventure to California
I've got no problem with being different and wild. I see it this way tattoo's are permanent, piercings rather painful, etc. Again I can change a hair as quick as changing hats. I can go back to work and I don't have to keep it. Oh trust me ive got fun plans for that wig yet.
I'm safely home and in one piece. This closes out this thread more or less. Idaho was quite different to come home to. All the fields south of Council ID are bright green and like emerald carpet. Certain comfort of rolling it to your home area and just knowing your home. TNow the weekend task of unpacking and getting ready for the work week. I've got ton of phone calls and now gotta get my work plan started for the week.
Well my first leg in Oregon without wind oh my Gawd. EGTs are 400 degrees cooler. I'm now stating to see much better MPG. Trans is staying almost 40 degrees cooler. Wind is a huge factor. Back to travelling...
Good morning all... My last leg home starts early being ive got a long day. I've got about 5 hours of travel left. Still got to restock food for home and also move back into the house today. @JAG1 called last night to let me he enjoyed the trip. Found out we both made good travel being he made the southern border to Oregon. It was a very enjoyable trip being with long time friends from the website. I hope others start to consider creating their own get together's in their local areas. There is some much to learn from other members. Im looking forward to doing this again.
I'm on my way home since 8am PDT. It's been super windy. Bucking a head wind since I hit I80 east. Fastest I can safely travel is 55 to maybe 60 MPH. Bucking 30 to 40MPH win had 135 miles burned up 18.7 gallons. Ouch. Then fighting the transmission temps. Once I got on US95 and backed down everything was fine. Made from camp Annett's Mono Village to McDermitt, NV. I'm spent and camping in the casino lot tonight.
