Airdog pressure
I've got my pressure gauge setup in the line before the VP44. (Old School Big Line). I'm also running the stock fuel filter to with my AirDog 150. As for fuel pressure I just re-adjusted mine with a extra shim and sitting at 18 PSI at idle and 16 at WOT. As of filter change when I get to 15 PSI I will change filters on the AirDog again. But like my last filter change the pressure didn't rise again. This is because the check ball in the regulator got crammed down in the coils of the spring so when I pulled it back out the pressure rose again. So I figure might as well add a extra shim to it...
greeting from swamprat
Welcome to the site SwampRat... But what is the problem by chance?
More Riding and lots of damage
ISX you crazy fool... Well at least you alive and OK but I'm sure your not going to try that twice are you???
wont start
Correct... The fuel pump realy is the power supply to the VP44 NOT the lift pump on the side of the block...
Building a LOT of HEAT!!
So does my Edge Comp on 5x5... But I never exceed 200*F towing my trailer... Even pulling 6% grades at 55 MPH. But you sure hear the fan lock up and sound like a turbo prop trying to take off... The cooling system is plenty big to handle some of the bigest loads but AH64ID does have a point thermostat and coolant flush is cheap insurance for the summer time.
temp problem 06 dakota
Shorting temp lead to ground tripping the light? Bad trans temp sensor?
Not I... But you might shop around... I'm sure there is better than NAPA...
Ball Joints - Nightmare!
Ummm... Errr... Ummm... I think I figure out another way of getting them out before I go that far...
Low power, some smoke, rough idle
sound like the carbon track is wore out for sure... Strange... There was no codes...
Propane Tank Gauge?
No joke... http://www.google.com/search?q=clear+propane+bottles&rls=com.microsoft:en-us&ie=UTF-8&oe=UTF-8&startIndex=&startPage=1&rlz=1I7ADFA_en#q=clear+propane+bottles&hl=en&rls=com.microsoft:en-us&rlz=1I7ADFA_en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=4ZXqTY34MYGasAOwq8n5DQ&ved=0CE4QrQQ&bav=on.2,or.r_gc.r_pw.&fp=830c3e2a07ee9aae&biw=1659&bih=882 There you go a Google Shopping page full of them...
At the time it was rather serious note watch poor James holding his thigh and limping out the door of the shop. Now looking back on it... It still rather scary but funny too... One of these days I got to do the driver side...
Door Dinger
No on the 96 the door buzzer is a seperate unit.
Propane Tank Gauge?
Here is a better option... Or buy propane tank with actual gauges built in like fork lift style tanks do... They are still out there...
Door Dinger
If you find the box under the dash you could take some silcone put a blob on the speaker opening. Then it would be muffled. But if you deside you want the dinger then all you got to do is peel the silcone off the speaker grill.
Camping in West Warren, Mass... Unbelieveable heavy weather
I was wondering about you and all the storms up there but it seem your home safe and sound... Yeah when the wind is blowing it no fun to be dragging a TT behind the Cummins.
Door Dinger
You don't... It part of the Central Timer Module (CTM) under the dash... If you unplug it you lose a bunch of stuff like wipers, etc...
Normally the fan makes alot of noise during lock up so if you not hearing a turbo prop your fan isn't working.
Chrysler will buy the 6.2% the Gov. still has!
Wow! Cool Dodge will be privately owned once again!
Rodent Combat!!
Man those little critters are getting into everything... I'll admit (knockin' on wood) no problems with mice in the houses, trucks, or the TT (Travel Trailer). Ol' Mickey Mouse must just like you...
Fan Clutch. Being that the temps were OK towing. But as soon as you where crawling around the parking lot there was no wind blowing through the radiator (fan not locking) so it kept rising till it ran to the RED zone and tripped the ... So I would check the fan clutch first...
Norcold refridgerator... propane operation trouble
Yes I do... Open up the exterior access panel and look inside the burner area. You'll see the spark electrode inside the burner chamber this electrode does 2 things ignites the gas to light the flame but also tells the computer if the flame has blown out or not ignited. So I would clean the ignitor carefully and clean the burner base so the arc will jump to the burner to light and also be sure the flame touching the electrode. As for the C it means the DC battery is too low. Flame Rectification sensing[1].pdf norcold refriderator.pdf
Ceramic Brakes
I'll admit exhaust brakes are not cheap ($800-$900)... But they pay themself off in a very short order. As for learning how to get the most out of a exhaust brake and driving style will take time to learn. As for myself I hate driving Mom's 96 Dodge gasser. No exhaust brake to slow me down... I've also gone hunt for a stick that doesn't exist then stomp hard on the brake pedal thinking its a clutch...
Ceramic Brakes
Hmmm... Here is something to consider. I own a 2002 Dodge Cummins haul firewwod every summer out of the high country (2-3 cords a trip). Would you believe I've never done a brake job yet on my truck with 185K miles on the clock. Why??? Because I've got a exhaust brake which does 90% of all my brake work. So my brake last extremely long. Exhaust brake are designed for manual tranny truck but can be retro fitted to automatics too... But next set of brake pads will be the cheapest ones I can find...
wont start
Typically most all aftermarket pump have a control relay unless its one of the cheap factory replacement pump like FASS DDRP or simular. Not sure on ECM replacement but I know that the VIN number has to flash into it... I know Dodge gets there ECM blank and you must bring the truck to them and have it flashed.
Just an old man in life ... but one of the newer ones here
Welcome to the site. There is alot of knowledgeable people here that can help you out with more everyday issues of one type or another. So post plenty of question and we'll try to answer them if not we'll find someone that can...
