Aluminum Rim Failure
Well I got a set of modular aluminum wheels coming and a set of 235/85 R16 (14 ply) tires coming. Oh! Its going to hurt...
Saving the Printer... Cannon ImageClass MF4150
Like I found out a very expensive desktop... I got a laptop too but can't upgrade it. Too old! (Sony VAIO AMD 800 MHz)
Fuel sender failure?
Yeap... Fuel sender is shot... Mine was running out of fuel and showed 1/2 or 5/8 of tank... Its a dealer only item but cost only $70 bucks to replace...
Laptops sux... This old dog will never die... I've rebuild this same case since 2001 when I bought it... 2400 AMD then 3000 AMD up to now with dual core 5200 AMD... Never spent more than $500 on a upgrade...
Well gang... I finally got bit by the the aluminum rim cracking problem. When in to try and have another set of 235/85 R16 tire put on them and the shop person called me back in the shop and 3 of my rims where cracked. So now I'm shopping for rim and tires again.. I already dropped my rims off with a friend to have them recycled and hopefully he remembers to drop some pics of it on the web...
I've got a story for you all... I got a phone call not too long ago to help a local gent here with a 2001 Dodge Ram 1500 V8 that he had just change the clutch but someone had mickey moused the crank sensor. My first thing was I was going to print a copy of the error codes and take with me. I fired up the web site and start to print the error codes and realized at the last second that the printer is set for single side. So not to waste paper I flip the power switch off and back on to kill the printer job but left a half printed page jammed in the printer (PAPER JAM!). So I open it up and pull the toner out and carefully pulled the page out. Closed it up still got the error for paper jam. So I hauled to the job without notes.... Returned... Now I took the printer apart looking for broken parts. Trust me this Cannon ImageClass MF4150 printer is not exactly user friendly for taking apart. But I noticed a small piece of white plastic on the top on the printer thae was broken from somewhere. OK just look for the white plastic that is missing something. After about 1 hour I couldn't find nothing white broken... So I put it all back together again thinking maybe I disturbed it and maybe it would work. NOPE... Still a paper jam... Figuring I was SOL (Crap out of Luck) I would get the old Ink jet out and fire it up and use it. Well that was a mess. The printer is so old there isn't any 64 bit drivers first off and second off Lexmark doesn't have a full driver for it any longer (obsolete). Then to top it off the ink dried up... :banghead: Mopar Mom makes the comment "Well we aren't buying a new printer unless there is a hell of sale on them..." Great... I know that we both use the printer quite a bit. So knowing this I figured MF4150 is broke with a paper jam and I can't hurt it anymore that what it is... So I got more tools out and got busy tearing it down. Screw after screw I just keep removing everything and looking at every part for problems. I had a huge pile of parts on the floor and desk and just a gut printer frame with only the laser roller left. Careful I remove the paper guide on top and notice a spring was off its hook. Then notice the rod has a shutter flap that covers a eye that is totally mis-aligned. Could it be this easy? Well back to reassembly... Screw after screw re-assembled the print to the last 2 screws for the face and realized I had use to longer screw inside. Damn! So I had to tear it down a bit to find 2 longer screws or swap with the short ones. Got it back together and plugged in... No red light screaming Paper Jam! Right on... But I managed to save myself about $200 bucks on replacing a printer. Now why did it fail I realize now when I was pulling the paper out I was pull the up half of the page backward and the feeler arm was pulled backwards as well. When it bound up it popped the right side of the shaft up and released the spring for the shaft causing it to never return to a empty paper state but a paper jam state constantly. So I know better to try and pull from the top if I can or go very slowly...
Ball Joints - Nightmare!
Nevermind... Not enough coffee...
Bed Liner! Musta-quit, it doesn't fit!
Just measure the the bed rim at the front and at the rear ofthe bed and you'll see its not the same...
I got 185K on the clock before changing my bal joints. I'm still running factory brake pas after 185K miles. My VP44 injection pump has 136K miles on it.. What are you talking about...
P1689
Not always... I've seen now... [*]Bad ECM cause a P1689 [*]Bad Fuel Pump relay in the PDC cause a P1689 [*]Bad driver side ground cause a P1689 And a few more I can't remember right now...
no start, buzzing asd
I'm wondering if you have a bad ground or pinched wire somewhere for thing to get hot typically requires a short to ground or a weak ground to make circuit back feed in not typical manner...
Front pump seal
Ummm... From my old school days with 727 Transmission on V8 it might be a seal failure but more likely a front bearing had failed. It might be time to pull it out and have a shop at least look at the front bearing... I know its cheap to replace the seal but it sucks to have it start leaking again quickly after replacing... (Been there done that!)
ABS& Brake lights on the dash
Correct... But a bad front axle sensor will not effect the speedo...
PCM has nothing really to do with it... The Antilock Brake Controller sends it data out on the CCD network to be picked up by other devices. But it could be the controller is not the right one for the truck cause your issues... Now if the dealer had it hooked up to the scanner he should of been able to see the 3 wheel sensors (2 front axles and 1 rear axle). What it needs is same speed from all sensors all the the time and it should work. But if the controller is damaged or not the right one it might cause issues...
Rodent Combat!!
Ummm... Mine easy but not very big...
Sometimes the Dragon wins!
Right on...
I would try a new sensor...
transfer case leak
I kind of wonder if the gasket itsself on the tailshaft is damaged some how? Odd for a bolt to leak... Could pull the bolt and put some gasket maker on the threads if it passing through into the case...
More Riding and lots of damage
Your just plain but we all still care about ya...
P1689
Not a problem... Anymore information found on the VP44 and P1689 code? Did you try swapping the relays (fuel pump and horn)?
24 valve rough idle and hard to start hot or cold
Well I got you cover then... Go to NAPA and get a WH6820 it cost about $8 bucks... Needle Valve Adjustment As for pop testing. (Basic) http-~~-//www.youtube.com/watch?v=7jXX_rGqgGo
As for the fuel pressure gauge sounds like the sender is damaged from water hammer pulses... Did you install a needle valve and set it properly? As for the choppy idle could you hook up a OBDII scan tool and read the error codes? But if there is no error codes you might have to pop test the injectors it might have a damaged pintle needle and sticking some after it gets warmed up. But a pop test would most likely show this too...
Replaced VP44 and Lift Pump Truck won't start! HELP!!!!
That sure would do it... Those little sealing washers will make or break a seal for sure...
wont start
Here is the wiring for both the VP44 and the lift pump... VP44 Wiring... Take notice the fuel pump relay on top here. This is to supply power to the VP44... Now take notice to the ECM has to + power leads heading towards the lift pump but there is NO relay in the circuit. But it relize on the driverside ground for its connection too.
Fuel Filter
I've been running the fleetguard on the AD 150 and a fleetguard in the stock filter... As for the stock filter I open it up and peeked in not to long ago and notice the filter is starting to discolor after 50K miles so the double stack filters are really helping out. 136K miles and VP44 still singin'
