Milestone
Dang Dorkweed I think we fixed the early death of VP44 injection pumps with this stuff... Even if mine failed now I still be happy with the lifespan of the pump but... No... It continues to keep on pulling anything tied to the rear of the truck..
Texas Heat
Hijacking threads... But its all good here we aren't going to bite your head off about it but we might slobber all over your pictures though... Very interesting about the oil field info... But as for the cold icy pictures I've had enough of the cold... Seriously... My max temp today is 53*F and raining... I got up this morning in Council, ID to about 38*F... WTH is going on with the weather???
Rodent Combat!!
Dang... The war continues on doesn't it? Wow!
More Riding and lots of damage
He must be healing if he's working the site over and coming up with ideas...
P1689
FASS, Raptor or AirDog is fine... But no FASS DDRP... The DDRP doesn't have the volume nor does it correct the plumbing problems. As for the P0606 is a ECM failure code... Something happened there. Hmmm... But since the code hasn't returned I won't worry to much... But now if it comes back then you'll have to deal with the ECM.
Aluminum Rim Failure
Load Range G - 3,750# (7,500#) Load Range E - 3,042# (6,084#) Funny rear axle GAWR is 6,084# for 2500 Dodge Ram's... Hey the rims where a good price and I could pass that up... A set of Pacer 16x7 rims with Load Range G tires 235/85 R16 for $1,100.00... Not bad really...
Exhaust Size
What little tidbit I can provide here is that I know most people with 4" exhaust on mild moded engis say <450HP has done quite well. But as for 5" its debatable but some say too big of a pipe causes the exhaust to cool too fasts and hang in the pipe causing a loss of performance. (Heresay)
New sub-section possibility?
Sounds like a wonderful idea...
Black Smoke
Remember on thing... "Boost doesn't make power fuel does" So now saying that you can still have good power and lower boost pressure and still make good power but now your EGT's rise quickly. This is the most common problem with guys getting large injectors... Lots of smoke but not enough boost to clear the smoke and control the EGT's. Even when I blew a single 6mm bolt out of the manifold I was down to a max boost pressure of 8 PSI still had all the power I want but smoke and EGT's... Holy chit dude! The whole thing cause by 1 single 6mm bolt popping out of manifold.
That's what my steel white spoke rim are for my rescue boat of tire... And they did exactly that! Now to get ready to day to get the new rims and rubber! (Bling!)
Black Smoke
No... OBDII can't see that... Just like the 2nd Gen 24V... Only different is the CR is electrically fired not pressure. Like said before lack of boost pressure... Might be time to throw some gauges in...
Silencer Ring Removal Question
It was confirmed years ago on a dyno by a fellow Cummins owner they ran with and without a silencer ring and both runs basically where the same. So no there is no change in performance just sound...
This is a commercial...
OMG... Thats funny...
Texas Heat
I'm nearly out of firewood! Burned nearly 12.5 cords...
P1689
That explains it... AirTex doesn't have the volume rate you need... Airtex is like 35-40 GPH... Then all the stock plumbing is restrictive...
Question how much do they weigh a piece (tire & wheel both)???
Texas Heat
Someone hitch on to that 95-100*F weather and tow some up here to central Idaho... Man today is going to max out as 59*F again... Cold, breezy, and cloudy... Nasty weather... Give me some weather worth drinking beer over Geez?!?!
P1689
Too much restriction or air leak... You got to go back over the fuel system... From 18 at idle I got to 16 PSI at 80 MPH at WOT... 2-3 PSI drop is fine but a 9 PSI drop is a serious problem... * Stock fuel system (which I doubt since your at 18 PSI)* Suction restriction* Still got the stock line between the VP44 and stock filter* Suction air leak* Defective lift pump
Check out this thread on Jeep Forum...
I got about 3-4 pages in and quit for the moment...
Go to this link... http://www.jeepforum.com/forum/f11/96-jeep-cherokee-need-opinions-1149721/ Then read post 1 and then post 2
Dana 70 Problems
Good picture tho...
p602
Smarty... It's causing the error code... If you reset to stock and clear the codes you'll be fine... But as soon as you run a Smarty program the error will show up... Of course because you modifying the stock fueling tables in the ECM and the checksum doesn't match any longer...
P1689
Fuel pressure... (Idle and WOT operation at highway speed).
6 Driving Tactics to Save Gas This Summer
Reason being is because all them are produced from Naptha (coleman fuel), Mineral Spirits (paint thinner), Napthalene (moth balls), Xylene (paint thinner) all of these have much lower BTU content compared to the diesel fuel. Just look up the MSDS sheet on any of them...
