  1. Start a new thread... I can't upload to this thread its got a corrupt file in it holding up the works... :banghead:
  2. Mopar1973Man replied to a post in a topic in Introductions
    Funny... I used to be a Fire Fighter for Salmon River Rural Fire Dept... Yeah I'm back and forth to McCall to get groceries... Not to mention I've got another gent down in New Meadows, ID that got his first 1992 Dodge Cummins 1st Gen and learning from the ground up...
  3. Mopar1973Man replied to a post in a topic in Introductions
    Lake Fork, Idaho... Wow! I drive through there all the time... Might just have to get together some time I'll hook you up with the information you need.
  4. Drawstraw isn't bad as long as you don't listen to the instructions or forum myths...
  5. New Meadows, ID dropped to 4.369... Small start hopfully to keep falling...
  6. Hey gang... Would you take a peek over here please... http://forum.mopar1973man.com/threads/4129-Experience-amp-Market?p=35508#post35508
  7. Personally a few cans of over cleaner do just as well...
  8. Good deal at least your "belt and suspenders" idea worked...
  9. Right from the fuel pump relay (Pin #87) in the PDC to the VP44 pump (Pin #7)
  10. Can't have flow without pressure. After doing the studying of the overflow valve by the time you get to 10 PSI the overflow valve is completely closed so flow is gone except for the flow to the injectors. Now if you coasting there is little to none. So at 14 PSI the flow will keep the VP44 cooled and lubed properly.
  11. Found mine at the shift tower of my NV4500... (Reverse switch)
  12. Yeah I would get the Edge hooked back up. It soon give you a slight boost to MPG numbers...
  13. Typically if you remove a part like the compressor you suppose to add back amount of oil to replace what was lost. Each part in the system will hold a certain amount of oil. Compressor holds the most.
  14. To add to Russ comments there... Yes the IAT sensor controls the initial use of the grid heaters before starting but after the engine is running it seems the Engine Coolant Sensor controls the post grid heater usage. I been running all winter with mine locked at 140*F and there is no grid heaters at key ON but after you start the grid heater cycle in and out. But now with warm weather I never see grid heaters any longer. So yes its possible for a intake temperature sensor (IAT) to fail within normal run specs and not throw a code but also be far off the mark from actual manifold temp. So this why I suggest using a live data tool to check the sensor value. Because like my setup I'm locked at set temp now no codes no issues. But now if the data tool can't be had you can just replace the sensor as a guess. They seem pretty cheap for $22 buck for a IAT sensor...
  15. I ran through the FSM and didn't find anything about bearing or anything on the steering column. You might have to just dive in and look...
  16. Only way to be sure is to get a Live Data tool and see what the value is. Check both the Engine Coolant and IAT Sensor. From a cold start both sensor should be the same. Then at full running temp the IAT should be about +40*F over outside air temp.
  17. $4.459 still in New Meadows as for today...
  18. Remember to check the fuel pressure as you drive...
  19. I don't suggest this with any flamable cleaning solvent... Vacuum motor might ignite the vapors...
  20. Well I guess the problem is gone... I checked today and the throughput in 385 KB/s :banghead: Gotta love the internet... Well I'm going to be finishing adding the files back to the system now...
