Muffed it up!! Drat!!
ASD (Automatic Shut Down) Relay in is in the PDC (Power Distribution Center) under the hood. I would check and see if the relay is lose or corroded up..
MPG fooler - Design phase
Drat... The weather got me pinned for about 1-2 weeks till the wind lets up... :banghead:
DTC troubleshooting
Comments in blue... The only thing left is to go to a dealer and let them use there $6000 DRBIII tool and tell you if the speed sensors are working (or not) and the ABS computer is working (or not). But I'm going to say there is a mis-match in sensors yet. Because if the ABS computer was actually out the speedometer would be dead... Speed sensor -> ABS computer -> CCD Network -> Instrument panel -> Speedometer Also remember the ABS/BRAKE light will not reset till the vehicle is moving.
Airdog question
20 PSI is the undocumented high limit.
Airdog question
There is a second spring included that jacks it up to 17-19 PSI... Or like I did I used a shim washer on the spring and adjsted it to 17 PSI... As a matter of fact it time to do some maintenance on my AD150...
O2 sensor
Yea I agree it would be fun to play with EFI Live on a 24V engine... But I think your right we are the red headed step child of the family of Cummins.. I hate to say it but there is no comparing gas engine to diesel to totally different worlds...
1.000.000 Miles Yet???
I told him to aim for 2 million now...
maybe.... just maybe.... it's starting to like me?
Or worse like your Avatar...
Well I'm going to be taking the TT out in the next few day's I'll bring along the video camera and such and document a run down to Boise, ID...
Front wheel bearings
D'Oh!
What Could Be Left?
Hmmm... I got to get ahold of JL and find out what going on I've gotten a few email about posting issues???
Sometimes all it need is a bit of TLC and the truck behaves much better...
No power to OBD II port!
Check the IOD (Ignition Off Draw) fuse its the one in the cab fuse panel with the funky clip over it.
What type of clutch?
I'm close to 400 HP to the ground and the Southbend Con OFE clutch holds really good and tight...
O2 sensor
The only thing a O2 sensor would be used for is smoke control. Just like on gasser the O2 sensor detect rich/lean conditions and tunes the fuel accordingly to the load and speed.
Can i use prestone dex cool antifreeze
The only one that can be mixed is the yellow it can be mixed with either green or orange but not both.
Just emailed him again to see if there is a update of if it actually rolls over or 999,999 ???
Just 7 minutes ago I go the email... It has been done... Congrads to CajFlynn for making 1 million miles with a 2001 Dodge Cummins... Also the milestone page has been update as well... http://mopar.mopar1973man.com/cummins/milestone/milestones.htm
100 miles to go...
02 non dodge isb
I'd would consider just changing the ECM with your old engine then you know the data bus is the same thing... If not you could have the ECM flashed to match the Dodge. (I think ??? )
There you go... Post it up on CumminsForum I sure some punk would buy it for $12K...
Sorry that won't wash here... Some of use actually know the history of you truck...
Five damper questions.
It all one piece. No you don't have to mark its position. Just pull the 4 bolts and remove. Clean it with a mild degreaser. http://mopar.mopar1973man.com/cummins/2ndgen24v/maintenance/damper/damper.htm
Changing the 2009 6.7 fuel filter.
I hear a few mods coming on. Like a relocated fuel filter with updated media...
Another email tonight... Go man go!
