Some more mods on their way....
I'm curious how it all turns out...
What's up with my AirDog
Ummm... If I'm not missing something but AirDog is a lifetime warranty...Why not give good old Pureflow a call and see what they say...
Just For Mike
- transmission....life sucks
Hydraulics bleeding down dragging the clutch... Bad pilot bearing and dragging the input shaft...- Just For Mike
Ha Got you beat... High School - Monroe High - over 1,000 worth of Seniors... Classrooms are at least 100 people if not more... Some of the building are 2 story... Then the area I lived in... What is knows as the Valley... Near LA.... Now you know where I can from to where I'm now living... In the middle of Nowhere Idaho...- Injectors 75 hp
RV275 (+40 HP) are good for a mild gain without a bunch of excessive smoke and will gain slightly on the MPG's... (1-2). Going above 75 HP injector tends to get rather smokey and lose of MPG's. Not exactly a streetable. As for rebuilding it basically replacing the pintle and nozzle then re-pop testing the injector...- Troubleshooting dead end on dead pedal. Apologize for a long thread in advance
Hmmm... Interesting... Make sense though when you think about it... ABS module senses the wheel speed from the rear axle and at speeds below say 20-25 MPH its in torque management so it will accelerate slower. So if the ABS module was bad then the ECM would run in torque management mode all the time... (Thinking out loud) But this is the first time I've heard of this...- Photography - Snapshots of the Day
Beatuiful moths... If I'm not mistaken the 2nd one is a hummingbird moth... Use to see them around the old Steelhead Inn when I managed it...- Nobus trouble
No Bus on the odometer is refering to the CCD Network bus to the gauge cluster...- Just For Mike
I grew up in Mission Hills, Ca... Which is only a short drive from Los Angeles...Now imagnie over 500,000 people in a 5 mile square... Picture above is a population of about 400 people... Trust me I'd rather grow up in Idaho than California...- Just For Mike
Ummm... But the sad truth is Riggins, ID is a desert... With summer temps as high as 120*F... Here is Riggins, ID exactly 1 mile long and 1/4 mile wide...- Photography - Snapshots of the Day
Ummm... No...- Just For Mike
:lmao:Oh... That's just plain wrong...- Help 911 Diesel Down
Well I guess you need a VP44...- Photography - Snapshots of the Day
Yeah I know... Seriously I do the same thing come summer time with firewood ($150 a cord - ChaChing!) (Cummins Skidder... )- Steering column gauge mount?
+1 (Showing support for the effort!)- Photography - Snapshots of the Day
And you need a Cummins?? Heck I plow that much with my neighbors ATV...- What's with CR's and Smoke?
Here is a bit more on the subject... http://www.docstoc.com/docs/56990019/Diesel-Combustion-System-With-Re-entrant-Piston-Bowl---Patent-7431012#viewer-area- HX35 wastegate control - overboosting issue
Hook up with ISX he's created a boost regulator that actually works rather well for his 12V 97...- Steering column gauge mount?
Wild & Free is right... I would jump on one of those if I could buy one...- Lock N Stitch
Yea... So true... There is a guy in Boise, ID that I went down to see person and he's got a 05 Dodge 3500 CR Cummins it still runs but you can hear at startup how weak the compression is. Once it running it got so much blowby that if you unscrew the cap it will shoot it up of your hand at least a foot into the air. You actually hear a POP when it happens... CR Engine are famous for the injector failures... Just like 24V's are famous for VP44 failures... The only difference is when a CR goes down it can take the pistons and the block with it.- Finished my Fooler
Thinking back on this again... Q: Could you get a picture of the switch? Q: Where did you buy the switch at? (Link to web site please) I love the design idea and would like to get more information on this change so I can included it in the write up of the site so others can have the option too.- Transmission woes
Sounds familar... Mom's old 1976 Dodge PowerWagon did the same thing I blew the front seal but what caused it was a failed input shaft bearing mind you what I'm comparing to is a 727 trans from long ago to the 47RE... Needless to say I replaced the seal which was cheap ($5) and had it blow out again in a short order...- It's alive!
Nothing hard on install... If you pulling the bed then just route the hose and go... Just consider you mounting location of your pump where the water and debris won't beat it up.- Fuel prices thread...
Now I don't feel so bad... But doesn't that suck just a few hundred miles eastward in US the fuel prices fall... - transmission....life sucks
