ABS Module Problems?
I would call warranty on ABS module if it was repaired or rebuilt.
Normal or Not? AC cycle with Heat
Should be pretty solid. Might cycle if super humid. Thats when the evaporator gets covered in ice.
High EGTs, Boost Maxes Out
Very possible... Still you should hear the pulsing sounds from the manifold as a ticking noise. Still you should hear it. Not to mention you'll see the black carbon tracks. Possible. You would have to pull the turbo to verify the wastegate is truly shut. Good question. Boost gauge should be used over the Quadzilla boost display. Mine is no where close after about 20 PSI is starts skewing badly. Funny part is mine is reverse. WOT my Quadzilla recorded me with a max boost of 69 PSI. Seriously doubt that... Where my ISSPro only shows the typical 47 to 49 PSI.
New tail lights came today
I wouldn't worry most modern vehicles today run halo lighting and in white LEDs. As long as the turn signal turns amber in the front then your fine. Like most modern car cancel the white halo and switch to amber turn signals. I've got switchback LED's in both trucks now still no issues with them either locally or on trips for the last year or so.
Even a 5 PSI loss of boost should be audible. Just pulling the the wastegate line and one manifold bolt out and it very loud and you won't miss that. With that those 2 leaks on my truck this only dropped me from the 47 to 42 PSI of boost. Still not adding up.
Something isn't adding up. My first set of +50HP I was getting over 35 PSI. Then upgraded to +75HP (7 x 0.0085) I was just touching 40 PSI. Then now with current +150HP (7 x 0.010) I'm nearly 50 PSI.
Might be... Depends on the air temperature in the evaporator. As the intake air cools the lo side pressure will fall and cause the lo side switch to cycle in and out. If the outside air is near 35*F it will cycle. Below this typically is will not even start at all because now the lo side pressure will fall so far that prevents the A/C from starting. I would check the pressure just to be safe on a warm day.
Discussion about when and where.....
Doesn't affect me much... Where I like to camp or travel to there is no internet or cell service typically. All building get locked up, gate is closed and locked. Neighbors are informed. Since I travel where there is no signal I've don't have any way to post up pictures of my travel till I return home. Like my last spot I barely have 1X signal for my cell phone and could make a phone call but no internet. Like Eileen's T-Mobile didn't work at all no signal at all. I'm on Verizon which all the local towers are Verizon owned. My next adventure might be well beyond cellphones here soon.
I've got an article for both sides of the 2nd gens... 98.5 to 02 Then the older... 94 to 98...
7 x 0.010 @ 320 bar and HX35/40 Hybrid turbo (60/60/12) I'm smacking 47-49 PSI. Using my Quad Tunes. I'm slowly working on a good towing tune.
coronavirus protection
Those are eight 50w solar panel on a solid frame. Facing south and about 45* up. By summer the sun is 90* above us and during the winter the sun arc is very low in the south about 4 hours of light. Then the other thing I did yesterday is going to save us 50 a month by loading up my BigTex trailer and truck bed with the last of Eileen's stuff from storage. Got home just in time last night before today's rain storm. I'll be unloading the trailer and the truck at some point today.
1st post and need advice and or help ?
Vacuum leak will push oil out of the crankcase vent. Vacuum pump can be rebuilt. I sell the kits here.
Should I get a cold air intake for my 5.9 Cummins?
Daily driver optimal temp is 100 to 140*F... Below 80*F IAT there is about a 4* timing advancement. (roughly 40*F outside).
Questions about Ubuntu
Ubuntu is a serious OS system. If you want give me a call I can school you in Linux. Virus free software. Server ready. Even business ready. Binds to Android devices instantly. 10 years experience in Ubuntu Linux 14 years experience in CentOS Linux Just give me a call at 208-315-1470 (cell) or 208-628-3645 (home). I can school you up in Linux. I left Microsoft products behind in 2008 and never looked back ever. I've even figure out how to run the Quadzilla tuner against Linux for flash updates of the Quadzilla Module. As you can see my Samsung S10+ is bound to my computer and I can make text message, phone calls, etc from my computer. Few more days and the new version of Ubuntu 20.04 LTS will be released. I'm still running 18.04.4 LTS... https://www.omgubuntu.co.uk/2019/10/ubuntu-20-04-release-features
I have the Dreaded P1689 Code
Swapping relays might just fix a power issues which can produce a p1689 code. Might be a good time to do the W-T ground wire mod for the VP44.
Correct they are facing south. Manual setup facing south. Only eight 50w panels for a total of 400w of charging power. As the season goes toward winter it difficult to get much light be the sun is so deep in the south and little time that the sun is even up in the sky. I've got a 20 ton wood splitter as well towed by the ATV. This tree came down during the winter missed both houses and landed right next to Devin's tree. Devin is my step son that passed away at the age of 7. Carefully tired pulling the tree and the top broke out just before Devin's tree. Now I had to cut block out so I could possibly pull the fallen tree past Devin's tree. Needless to say it came out smooth as button, plowing dirt in my yard but I kept pulling. I only used the 1996 Dodge I didn't even fire up the diesel. Quickly I had a step son name Devin that was with me for 7 years. I with another relationship Valerie Aranada and Devin Aranada (RIP). Sad part is that Devin died from brain issues and serve ADHD as well. That little Blue Spruce tree has been the tree that everyone is buried under. I'll pull a bit of Mom there, with Dad and Devin. Now I can fix the water line the tree pull apart as it slide down the hill when it fell. That was my main project the weather is improving and we need irrigation water very soon. Then I can ride the 1/3 mile to get to my head gate and fire up the water for the year.
Moving to almost the great white north.
The only thing I got to ask are you above the flood stage? Sure would suck to buy house on the river and have it flood out.
Black Hawy Rapids - Camping spot
Don't own one yet...
Boost sensor location?
Totally agree...
Like Eileen told me today she wants to go back to the spot again. It was nice and quiet there.
Yup has myself working on other truck. Yeah for some of us running much higher boost like myself 47 to 49 PSI. Then consider the bigger guys with twins.
Map boost sensor failing edge
Not good... It produces max boost signal and screws the fuel map up.
BLM Lands and National Forest boundaries
I use both methods quite a bit. Google Maps is much easier, Garmin on the other hand is more of a pain being you must type the destination. When Google Maps you can control by voice commands.
Be careful those hollow bolts break off easy. I do not suggest boost bolts because of how easy is to break off either the tubing and the bolt itsself.
