Quadzilla Adrenaline Economy and MPG
I realize that but the fact I just tapped on it and then closed it without making a setting then it locked up the app and would not connect till I set it for 0 or 1, "null" is not a valid value. Then the App will connect again. Just be aware its an issue that can cause someone connection problems.
Quadzilla display project
Ummm... The last ticket I've ever got was back 26 years ago. Been awhile since I've really been pulled over and picked on. I've had one a year ago but local cops don't bother with me once I pull my Idaho County ID for search and rescue. But the suction cup idea is something to be aware of. Even my Garmin and it constantly falling off the glass and laying in the bottom of the dash. Scares the crap out you at night when it does fall.
Let me catch up here... Ok I just did the latest update and flip back over to the V2 Quadzilla Only profile. After moving all my setting over by hand. Import issues from last time. I did run into a small issue that needs to be looked into. I manage to tap on the MPG reset option and the setting open and it of course is blank. Option of 0 or 1 allowed. I just closed the option and the app crashed. it needs a check for a valid variable before allowing to close. Still to this day I still have a random issue with getting the display started sometimes having to stop the truck, shutdown completely, shutdown the app, start the App, now start the truck again. Other than that it just tries once to connect and remain disconnected forever. Never tries again unless you do the full shutdown. So I'm up and running with the latest flash and set up on the Quadzilla V2 only tune. Let's see how the numbers stack this go around. As for fuel logs... I updated... As for the Sep. 2nd that was when I installed a 180*F thermostat. Then Sept 4th I just changed from 235's tires to 245's tires. Used Chris O's tool to adjust the ABS module for proper revs per mile. Verified to the GPS. I'm ready, guns are loaded...
I've got a suction cup Garmin GPS and hate that dang thing it falls off the glass quite often. I've got it tucked quite low on the glass so it's not noticed by law enforcement.
Another thing to be aware of... Just be aware of the suction cup laws for windshield mounting. Make sure there is other options for mounting the screen. https://blog.proclipusa.com/suction-cup-windshield-mounts/ States in Which Suction Cup Windshield Mounts Are Illegal Alabama Colorado Connecticut Delaware Georgia Idaho Illinois Louisiana Maine Montana Nebraska New Jersey New Mexico New York North Dakota Oklahoma Oregon Virginia Washington Washington, D.C. West Virginia
My dually
Looking closely at the body lines the look about right the illusion appears to be the skirt being crush slightly along the bottom edge of the bed that makes it look that way.
Oddball 24V DTC's active.
Now you might want to look into doing the @W-T ground wire mod to protect your ECM from future damage.
Oil Pressure and oil type
Like an old TDR article... Designed at the time of the release of CJ-4 oils. TDR57_Oil.pdf Then if you ask @cajflynn about oil changes on his 1.3 MILLION mile truck 2001 Dodge he was doing 20k oil changes. Hauling heavy boats. Then ask @dorkweed about his 84k oil change on nothing more than WalMart SuperTech 15w-40. There more to it with the filters he was running at the time and Blackstone testing. This is why I tend to disregard the short Schedule "B" because so few people actually fit that short change interval. Every winter here drops to -30*F at least. Every time I get to Ontario OR is nothing but stop and go driving. I've been known to idle the engine up to 3 hours with heat or A/C on to keep comfortable. I'm not going to fry or freeze. Every time I leave the pavement is a dirt road. Heck, my driveway is a dirt road. EXCLUDED - all my trips are over 100 miles typically. Typically I can put down 250-300 miles per day. Then every time I was on the interstate (85 MPH) heading to Boise, ID this summer. temps in the 105 to 110 realm. Just towed my RV trailer to Ontario last week. I work for the local fire dept so every time I get a page I can and have jumped in the seat and ran. No warm up. (Rattlesnake fire, ID) Every time I go get firewood and down in the southern Idaho area is nothing but desert. I'm still not going to change oil every 3,750k. So looking at @cajflynn that was doing hotshot work and hauling heavy boats should been changing oil every 3 to 4 days then. Myself I would be changing oil every 12 days that would increase the cost operation considerably. So in one year I would have to change 17 times vs 8 times on the Schedule A
Up yet?
@MoparMom said to tell you Dave that she is not getting up for something that ugly. As for me... I'm nearly done with my 2nd cup of liquid jump starting.
Very few people fit the schedule"B" realm.
Fuel shut off
Basically, the solenoid is internally shorted out. You'll have to replace it.
ECM gone. What about VP
I would have the ECM rebuilt. Is that Raptor on a relay? Or is it a DDRP Raptor?
Way too early. Right out of the owners manual is 7.5k miles. Even my 1996 Dodge 1500 is 6k miles on an oil change.
Fuel shut off
There is two parts to the solenoid. There is pull and hold. Now with the key on will it hold the fuel arm up? Check the risible links at the battery common to burn them.
'The Boost Bus'
Friends don't let friends play with Ford products without the proper safety equipment. At least no one will know it's you driving the Ford...
Hard to find parts resources
Now there is an idea. In a shaded area just keep applying CLR to the nozzle till it starts to flow. Just maybe you can do it without pulling the nozzle.
All I got to say is make it bigger than the Smarty Touch screen. That thing is smaller than my LG G5 screen now. I don't want to squint to see the gauges. Remember us old farts out here with crappy eyesight and needing bifocals.
Weird issue with brake pedal feel and PS pump
@IBMobile Dirty rat you still have that photo...
New Tire Size found 235's to 245's
Bolt Length for Stock Air Horn and Heater Grid
Ummm... I was born and raised in Los Angeles, CA. Didn't leave there until I was 20 years old. Now I'm 48 this year. Now I'm just another crazy Idaho redneck. I left California for that reason. Crazy libtards.
Suspention Bolt Backed out
You've got it... Jack up the frame and let the axle hang free. You might have to adjust the axle height with a floor jack a bit to align the bolt again. I've done control arm replacements but typically I do it one control arm at a time.
OMG I was laughing my for that one...
I'm surprise they (EPA) are so picky that an air horn has to be factory... OMG. EPA needs to calm down...
Knocking brakes
I'm still on the bet it the rotor are either cracked in the slots and deforming as they heat up causing the knocking noise. Again you'll have to pull the rotors and have them check for runout and cracks. Even if the runout is good you could still have a crack that only deforms with braking heat causing the knocking noise. You could have him send a set of rotors but being slotted they will most likely do the same thing again.
