Vehicle Log App - Simply Auto
Well gang... I might just retire the old method of written hand logs and finally move up to an electronics means of logging fuel and maintenance on the trucks. I found an app named Simply Auto for Android. https://play.google.com/store/apps/details?id=mrigapps.andriod.fuelcons&hl=en_US The part I like about it is that is for the $4 dollars you can have 3 different drivers/devices adding to the logs. For example, if you have your phone on you and you add fuel to the vehicle your wife/girlfriend device/phone will be updated as well. If she now takes the vehicle and has an oil change done she can update the app and you'll know the task has been done. Then you have all your data on the cloud and never have to worry about losing your information. I went ahead and inputted all my logs for the 1996 Dodge 1500 and then went over to the web page and logged in and you can see my data for the 1996 Dodge 1500 truck now. Nice to see my last tank of fuel I hit 17.05 MPG. As you page through all the data provided you'll find out there is a ton of different things this app can do. You can even log trips for mileage for medical or for tax reasons or for reimbursement. You can make all your maintenance logs custom values for anything you wish time wise, mileage or both (which ever happens first).
Hurricane Florence
Yeah, being I was the one with the fire this summer. You be careful and safe. Hide the Cummins somewhere safe. If it was me I would be driving inland more for a night or two for safety being your on the road for now. Hopefully your Wife and family will be safe.
Bad oil leak
Got to be nice with these hoses even if they are stainless steel braid. If it's in my way to fully remove the entire hose from the engine. Then when I reinstall I put it right back with the same curve in the same position again not to flex on the hose too much. This includes the turbo supply line too.
Another failed AD
On the flip side, I've got the AirDog 150 which I purchased back in 2006. The first pump head lasted 13 years and 250k miles. I'm on my second pump head now and no problems at all. Filters are going 60k miles a cycle and pressure are really stable at 15-17 PSI all the time including illegal speeds up to 100 MPH. Never drops. Then I've still got my stock fuel filter housing and its not a restriction at all. It's a bonus being that all fuel is double filtered before consumed but the VP44 and injectors. Even my VP44 lasted 243k miles before failing with a P0216 code where the timing was stuck at full advancement.
Po216, blue smoke from exhaust
Simple solution. Build a tune that has a less aggressive fuel curve and then make it 7 levels. This way you can float on level 4 which would be 25% wiretap. Then I would set the wiretap for only 1200us pulse. You could just drop to level 3 and be strictly CANBus fuel and not even worry about it.
Another failed AD
Challenge accepted...
5 and 6 speed owners
Now since I changed to 245s tires I'm shifting up at 1,500 to 1,700 RPMs easy. I'm in 4th gear by 25 MPH and in 5th gear by 35 MPH... NV4500 transmission.
Quadzilla Adrenaline Economy and MPG
Stock it would float about 18-19 MPG. Edge Comp is where I started my study of the IAT and that was back when I hit the ball out of the park at 27.2 MPG hand math. Now on the Quadzilla but new injectors, different turbo, new VP44, etc. Now I'm now starting to rise up to 19-21 MPG. fairly constant. Basically in a nutshell. IAT wise the temperature offset is roughly 30-40*F over outside temperature. This value applies to both my trucks 1996 Dodge 1500 5.9L V8 gas engine and the 2002 Dodge 2500 5.9L Cummins.
Take notice to the 1/2" pipe plug. Right between the MAP and IAT sensors. Guess what? That is a coolant passage. This is why I started studying the 180*F thermostat instead of trying to move the sensor. Being moving the sensor isn't going to help. Being the 180*F seems to trim off about -10*F been the coolant temperature is lower.
Another failed AD
Ummm... I still got the old school ball and spring. No adjustable regulator. When I changed the pump I only changed the pump head!
Another failed AD
Darn EPA and smog test places looking for error codes.
Don't do this it will create issues with error codes from IAT not sensing grid heater temp change. Yeah, there is a grid heater error code on some years. The other thing is the cooler temp fouls the timing tables for the stock truck when you move the IAT. The IAT can't be moved it does make an effect in timing and degrades performance typically. Remember my MPG fooler fools for 143*F of IAT and some gains are found there for MPG's. Making this cooler or allowing to drop below 80*F will make the ECM kick in nearly +3 to +4 degrees of timing on top. Cooler IAT temps is not a solution... Hence why my produce came into existence... So, moving the sensor is not an option. Just for fun my 1996 Dodge 1500 V8 5.9L has much HIGHER IAT temps than the Cummins. It can range as high as 170*F with heat soak. All cold air intake is in place too. The funny part is the very same sensor is used. I'm even running a 180*F thermostat now from the stock 190*F.
Another failed AD
Technically I should be in the same game as you now with pump heads we will see what shakes out. Being you have the adjustable regulator you might look into checking the regulator and see if there are any problems with it. Hanging parts, worn parts, etc.
Track Bar and other Suspension Options
Dodge Offroad is slow to getting parts out from what I understand everything is built per order basis and takes time. If it wasn't for your lift you could follow me. I've got a high mileage success rate for all suspension with 300k or on tie rods, heading for 200k for ball joints, track bars are well in the 150k mile range. Most don't want to follow me because the secret is the smaller tires and wheels I'm using and no lift or leveling.
Another failed AD
Then there are lucky ones like me. 13 years on the first one. Now heading out on my second pump head from AirDog. The only thing I've got a random problem with is pressure I know the problem is the way I bent the spring so the ball gets hung up where it can't close completely and the presssure falls lower than typical. After a bit the ball finds its center again and pressure stay ay 17 PSI.
Another dead VP44
I thought the same thing as well... I didn't know of anyone able to get new pump bodies.
Head gasket blown - Coolant leak
That worse case scenario. Valves, guides, seal, check for true, etc. Already got leaking valve seal now. Guides? Won't know till he can look at it. My first problem is getting the head off and letting a shop look it over. The shop I'm dealing with deals with mostly Cummins engines.
I'll most likely replace mine with new one being the number of miles I put down per year. I really don't want to do this job twice in the same year.
Fuel pressure gauge.
- P0237 Code
- Head gasket blown - Coolant leak
Your pockets must be deeper than mine. I've got hard enough time trying to scrape up $1,000 just to have the head serviced. I still not ordered a gasket set. Then I've got to order head bolts at least. I've got to get moving along with this project I need this truck for winter time for sure.- ECM gone. What about VP
Actually the codes are on the ECM ad the bus is down to the ECM so it can't report.- The Future of Trucks
Maybe you should get out of the city. There are leather crafters out there today making all these wares. Strange though you so these kinds of shops in small towns but never see them in big cities. That because today we are blending down fuel and taking out the energy. If you looked at the BTU's of the old school leaded gasoline back then it contained much more BTU's Then unleaded refined more BTU's out. Now we are dumping Ethanol into the fuel in different blends ratios. Again stripping more BTU's out of the fuel. https://en.wikipedia.org/wiki/Gasoline_gallon_equivalent Right there you need more fuel to produce the same amount of work so actually, we are working backward requiring more fuel to do the same amount of work.- Morimoto M Led projector retrofit.
Dumb question. I kind of know the answer. With the LED Morimoto's I've got to ask will the beam have enough heat to shed snow or ice off the lens? I know the PIAA 18w LED driving lights I've got now are too weak to shed snow they will freeze over in a winter storm. I'm not sure if there is any heat produced by the LED on the Morimoto.- New turbo
Even @trreed would have a good idea of what to get. - P0237 Code
