New Tire Size found 235's to 245's
Finally it has been done. Fresh rubber in 245/75 R16. Ill admit the trucks much better and steering is lighter with 245 compared to the 235s. Running the Hankook ATm again being I'm getting 60 k to 65k from a set. I'm ready for winter time bring it on.
Second Gen - Trans bogging down when cold
I would talk to @Dynamic he's our site transmission guru. I'm going to bet there is a torque converter issue.
Weird issue with brake pedal feel and PS pump
No. There isn't but it would be nice to have on there... Give me a break in working from the front seat of the truck.
You mean a drain plug in the steering gear box. That would drain every bit of fluid quickly.
What are the best headlight packages?
Between the Morimoto D2S and the PIAA 530 LED's you're looking at $1,000 in lighting... The Morimoto went up in price with the D2S lens versus the H1 Mini's that most use. Then 2 day freight... https://shop.retroshop.us/ProductDetails.asp?ProductCode=2G.RAM.RETRO
Looks like a normal light to me... Yeah spendy... But mine where a package deal everything assembled just install. I upgraded to the Morimoto D2S lens.
Still remember even with the filter you still need to change the fluid every 30k miles. Then while you're there might as well change the filter. I've got to ask what did you pay for the filter?
...or some of us went to 35w HID headlights. Then 18w watt LED driving lights.
iQuad Boost Readings Lower than Boost Gauge
Known problem mine is the same way. I'm also running expensive ISSPro EV2 boost gauge.
Kinda No Start Condition (Broke Down 4 months)
Suction lines will never leak outwards or drip they will constantly suck air in allowing fuel to return to the tank causing loss of prime. In other words if air is introduced the injectors will not fire. Air is compressible.
Old article on 275rv injectors.. still ok?
I'm getting ready to send my OEM stock injectors in and get new nozzles and popped on the high side 310 to 315 bar. Closing in on 100k miles on these 7 x0.0085 injectors.
Oil Pressure and oil type
Synthetic oil are not required. Most of the big milestone guys are strictly petroleum oils. I suggest you get the oil pressure tested.
Power Steering Pump
Finally, I'll be looking into replacing the power steering pump. Not that it quit pumping. The reservoir is leaking. The seal between the pump body and reservoir can is weeping fluid out and leaving signs of power steering fluid on the floor after a night.
All I can say is call and ask.
Rear end clank?
Standard greasable NAPA U-Joint (SKF)
Truth...
Well my views on what happened to my rear end
Curious what ratio are you running?
Light under hood
@Dieselfuture I'm the same way I normally have my Maglite LED flashlight on my right side of my belt. It's part of my daily dress code. I carry a flashlight in the door pocket of my truck. So I'm typically well covered for light. I like the LED idea because now your hands are free and the light is provided.
Blower motor inop
Light under hood
Finally got a hold of @War Eagle and we found the article for the lighting...
Windshield wiper. Upgrade to faster?
Yes. That is an option just don't get carried away with water pressure. Then pull the tubing off the pump bottom to drain the reservoir. If you're in a hurry you could turn the key on push the wash button till its empty.
Exhaust system info
Mopar1973Man replied to Tittle Diesel Performance's topic in 2nd Generation Dodge 24 Valve PowertrainMight be easier to just replace the entire exhaust with a new kit. Unknown if you can get the right tail section for length and everything without seeing the existing system and what you've got.
LMC truck is correct. There is actually two versions of that seal really. The one you seal where its just a foam rubber seal and then there is a second version that has a conceal flap that hangs down to conceal the wiring along the cowl.
Washer reservoir is a PITA to pull. There is two dimples of plastic that you have to use 2 flat blade screwdrivers to get released then you can slide it up off the fan shroud. Then you can clean out your bottle and fix any issues you might have.
Quadzilla display project
MacroDroid... Look it up on Google Play. https://play.google.com/store/apps/details?id=com.arlosoft.macrodroid&hl=en_US It might help you solve that problem.
