Head gasket blown - Coolant leak
I'm sure @dripley is happy you are not eating his kin. Thanks for the donation.
6.7 won't regen 5500 2014 strip chassis
What error codes did you have? I'm pretty sure those sensors can be viewed on a live data tool and see if there functional.
4X4 bearing Hubs and ABS Discussion....
Absolutely... Once you put that much heat into the rotor it's going to radiate into the unit bearing cooking the grease. This is why I'm a big fan of manual transmissions and exhaust brakes. Automatics can do well too but with 4 gears it hard to get a selection of gear that prevents long brake usage I've got this problem with mt 96 Dodge half ton with the 46RE transmission.
Bully Dog GT+
I know Smarty / Mads Electronics doesn't have any deleted tunes either. For the same reason. In any case it's tough to find a tuner now that has delete functions for removing the stock exhaust.
Can you do this?
- Another failed AD
Must be part of the loose nut behind the wheel problem. Everything is on the driver side that is an issue maybe the driver? Hmmm... Seriously if you ever make it to the west side I want a shot at that truck. I bet I can straighten that mess out once and for all.- 4X4 bearing Hubs and ABS Discussion....
Lets put it this way don't get all wrapped up in finding Timken bearing. Let's just say the all fail just the same so why spend more money on a brand that will fail just the same way. I've been running SKF bearings and get roughly 150k to 180k from a set of unit bearings.- Drain plug for auto transmission, where to put it?
Pictures?- Weird issue with brake pedal feel and PS pump
Since the first flush. If it wasn't for the external rusting of the input shaft on my OEM steering box I'd still have it today. Still working with my OEM power steering pump. Zero wear was inside the steering gearbox and very clean with zero sludge.- 4X4 bearing Hubs and ABS Discussion....
Tone ring broke loose. Same problem I had with mine once I replace both unit bearings as a pair ABS light is gone.- Head gasket blown - Coolant leak
Well first off I've got to Thank a forum member... But first the story... After going back and forth with it not going to be ready today to being ready at 3:30pm. I finally got ahold of MoparMom and told her we'll be going after the head when she is done with dialysis treatment. After an one hour drive to the shop. I'm greeted by Justin telling me... "Whatever your doing and the friends you have you better keep doing what you are doing." I'm very puzzled to this comment. Justin tosses the invoice on the counter and sure enough one of the members here made a payment on my bill. That member happens to be @portlandareae28 . It shocked the heck out of me. The comment I heard from Justin that Portlandareae28 has been very pleased with the help I've given him and he wanted to return the favor. Sir, you are a saint thank you from the bottom of my heart. 18 Valve guides 24 Valve seals Pressure test Resurfaced deck My Total $871.25- Head gasket blown - Coolant leak
Actually I got lucky it got finished up today. Ill post more when I get home.- VP44 question
Your hearing the rollers and shoes rattling around typically the fuel pressure would load the rollers and shoes against the cam ring. Totally normal.- Head gasket blown - Coolant leak
Dang. I'm delayed. I've got to do a second trip back down to Caldwell, ID on Friday to get the head.- Tranny lunges in gear/odd shifts 40mph max
Nope. Just install see if it shifts better.- Weird issue with brake pedal feel and PS pump
Ask yourself the question would you wash the oil filter and reuse it? I sure wouldn't.- OK, new blower motor & resistor, maybe still a issue
Check your plugs for heat damage. The last one I looked at the blower motor pigtail was lightly melted and contact were heat stressed. After the own replace it worked fine.- Tranny lunges in gear/odd shifts 40mph max
Output speed sensor is in the tailshaft area of the transmission. As for @Dynamic that's why I keep tagging him hopefully he responses or you could send private message to him.- Thank you for the quick shipping!
I've got to public say "Thank You" to @dieselautopower and staff for pulling off the shipping in a timely manner so I had all the parts here for putting the head back on the truck. Gasket kit showed yesterday and the studs as well. Jacob and staff "Thank You" for the quick service and getting the parts here in a quick fashion.- Head gasket blown - Coolant leak
I've got to public say "Thank You" to @dieselautopower and staff for pulling off the shipping in a timely manner so I had all the parts here for putting the head back on the truck. Gasket kit showed yesterday and the studs as well. Jacob and staff "Thank You" for the quick service and getting the parts here in a quick fashion. Now I just got to go get the head from Northwest Machine today and bring it home.- New Tire Size found 235's to 245's
I say give it a try. You won't be sorry. The RPM difference is small but the economy and power difference is pretty moderate.- Fuel Tank Module Check Valve
Can relocate the pump. That particular pump has a small discharge port designed to use a banjo bolt. He would need a normal Raptor first.- Tranny lunges in gear/odd shifts 40mph max
Nope, you did it right. The check gauges are because of the battery voltage dove under 12.00 volts. So this most likely means there is a problem possibly with the output speed sensor or transmission possibly. You might want to talk to @Dynamic about this issue he should be able to give you more clues.- Another Rectifier/Diodes Failure
I'm not sure now about the Bosch diodes. I've done a bit of searching but turning up very little information on the Bosch side.- Fuel Tank Module Check Valve
Perosnally, I would get out of the stock sender. Install a draw straw of some sort. The stock in-tank pump is restrictive from the get-go. All the factory plumbing is too small measuring out at 6mm ID (.24 inch ID). Then pumps are not design to lift or suck fuel long distances. You'll need to get the other pump to relocate it on the frame back towards the tank. Then the DDRP pump directly plugs into the ECM so if anything electrically happens to the Raptor the ECM is going to fry. I've not had much to say positive about your setup I'm sorry... - Another failed AD
