  1. You might want to edit your profile to include your location at least City and State. I'm curious where you are at. Like here it suppose to rain tonight already down to 43*F.
  2. Be really careful here. Once you start down this road it get rather hairy quick. Don't think you can just put a leveling kit on and everything just works. Sorry you have to realize the changes in the axle geometry and how it impacts steering and performance. Then you going to add the oversized tires on top it's also going to impact the steering and longevity of the steering parts as well. Might consider looking into the correct control arm lengths for your lift / leveling kit. This will help a bunch in correcting the geometry of the axle again. Be aware this will impact final gearing of the truck so if your doing the 35" I highly suggest you re do the gearing on the axle(s) to 4.10. I've got a local gent that's running 37" tires and was having to build way more power just to twist the tires with 3.55 gears. Now after swapping to 4.10 the truck way more powerful and fuel mileage is way up.
  3. Mickey doesn't look so good. I think he needs to put his back into the hub more to get it stopped...
  4. Typically that's going to be either steering gear box needs adjustments to take the slack out or tie rod ends are getting sloppy. Man, you are getting the rough end of the stick these days...
  5. Correction... 25 degrees at 55 MPH in 4th gear.
  6. Remember if data is being transmitted it will jump up and down. Those voltage are while the system is at rest. Might cycle the key off and pause 10 seconds and back on. Then pause awhile and see if the voltages are closer. It tells that it's not shorted to... Ground +5V 12V
  7. Seriously... Timing is a key factor in high MPGs and performance. The whole thing that is that you don't want too much timing and blow the head gasket or too little and being wasteful. Like my latest change looks promising but it pretty steep timing. Running about 23.2 degrees at 65 MPH in 5th gear. Amazing high running 55 MPH in 4th like 24 degrees. Need to run this tank and see the results but looking good. Strange to see lower EGTs yet.
  8. To a degree it is...
  9. Good use for the boost limit...
  10. I'm in the process of trying to clean up my Economy Tune still. Really close to calling this a release edition. I'm not going to place it in the download area yet till I'm sure the numbers are productive. iQuad-Economy-2017-10-07-08.41.181666734247.json
  11. You got to remember that the torque converter is going to dictate the RPM that truck is going to run at RPM wise. Like if you have a lower than stall converter and large injectors with a Smarty with little to no fuel to boost control you going to have a smoke issue. As for which gear the transmission is running in is based on spring tension and hydraulic pressure for 1st, 2nd, and 3rd gear. This is based on TV cable adjustments and valve body setup more so.
  12. Stock on most truck is NOT the door stricker. Like on my 02 it shows that goofy 245 size but it came stock with 265/75 R16. Like my 1996 Dodge Ram 1500 shows 225/75 R16 but came stock with 235/85 R16... So calibrate for 265's I bet its right on the money...
  13. Basically, any Android head unit or Android device (cell phone, tablet, etc.) should be able to do that task for you. None of are in a competitive mode at all really other than tuning to clear up smoke and improve daily driver performance. Like I came from an Edge Comp that was rather dirty and impossible to clean up because of the lack of tuning and timing controls.
  14. Tune data or data logs. As for building tunes I would start with the default tune and tweak it slowly. Default Quadzilla tune isn't bad starting place. As for what works on my truck may or may not work for you. Like I'm running nearly 23* worth of cruise timing.
  15. Plan on it... Trying to get my calibration on the Dash Command good and then flip over to the Edge Comp.
  16. The only thing I can say is either take the time and clean the EGR system or delete it. Personally I would just delete. Most people want to hold on the warranty so that tosses back to cleaning the system out.
  17. Still trying to gain back my high MPG number like with my old stockish injectors and dirty Edge Comp. So far I'm still about 3 to 4 MPG lower with my current setup.
  18. Same here. Stock tuning is extremely Smokey and EGTs are much higher. Towing would be nuts.
  19. Probe pins 3 and 11 on the OBDII port do this in reference to ground. Normal CCD voltage should be 2.49 and 2.51 volts. If the voltage is not these numbers then that leg of the CCD bus is the problem.
  20. Fact is that the CANBus fuel value is from 0 to 4095. All the stack does is fool the TPS or APPS signal to 4095 sooner with less APPS signal. Like @Me78569 shown with data logs of just the Smarty alone it can reach full fuel signal below 50% APPS signal. I really doubt the stack will make any more power.
  21. Yes, the ECM needs to be flashed to enable the high idle software. Most all trucks have the high idle software disabled. You can use a Smarty tuner or have the dealer do it with a DRBIII tool.
  22. Trust me turbo mounted exhaust brake will not affect your towing ability. That is 10,000 pound of hay. I've towed much heavier loads and never had EGT issue even with 3" exhaust.
  23. The biggest thing people call me for is attempting to clean the smoke up at the same time wishing to get the most from there larger injectors. That's a tough call to do with a Smarty S-03. Ive worked with several people that are pretty firm about keeping the Smarty because of their larger tires and need speedo tweaking. Smarty typically works well with stockish injectors but more the person modifies the truck improperly the harder it is to clean up.
