TCC lock-up issue with a screwy T.P.S
I've got to ask how are you testing the AC noise at the back of the alternator or at the batteries? Also what brand of meter are you using? What setting are you using on the meter to do the testing? Just seems odd you've got the hunting problem but no AC noise... APPS sensor will not cause hunting issues. I would consider a Timbo's APPS before another Mopar or stock APPS sensor again.
351C Overheating Issue
Need to answer Wild & Free's questions. I'm going to also lean towards head gaskets. 3 miles is nothing for distance and shouldn't be pushing coolant out that fast. Apparently getting pressure from somewhere.
Fuel Pressure Gauge Bleed out
You can see the snubber on the end of the needle valve...
Slightly early... Typically I'm winterizing at about October 20th. This year we are seeing 35*F mornings at September 24th... It should warm up this week but for how long who knows...
The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
If anyone needs Smarty support there is Smarty Resource which is providing the same support as well. Smarty Resource is also vendor here on the site as well. https://mopar1973man.com/forum/152-bbi-injectors-smarty-resource/
Quadzilla V2 Custom Tunes
Double check your wire tap. You should be able to push over 35 PSI. I would steepen the fuel table more start out at about 105% and using a exponential calculator use a growth rate of about 3 to 3.5% that should get just enough lag to light the turbo and then pour on the fuel. I'm running slightly more with +75 HP (7x0.0085) injectors and HX35/40 turbo I can just about light the tires up without tapping the pump. But you do have more weight. I've got to ask also are you running oversized tires possibly? This will make a huge impact on gearing and will make the truck struggle to pull the weight.
Another idea. Leave the valve alone and pick up a snubber from ISSPro and install it after the valve. This way you can still shut the line down and the snubber does the job of the cracking the needle valve. 3 years now and ZERO issues on ISSPro electric gauge.
No problem I ran the Edge Comp against the MPG mode for several years. What it will do is fool the IAT to a summer like temperature. The ECM and Edge Tuner will adjust timing as usual for those summer temps. This will be more RETARDED than typical winter timing. Cold air tend to promote some very advanced timing which is counter productive for MPG's.
Custom Quadzilla Tuning R & D Thread
1600 bar is 23,206.04 PSI which happens to be close to the same as a common rail engine.
Anyone Ever Travel/ Camp the Black Hills of N. Dakota?
Many, many year ago as a kid. Don't remember much.
Valve Spring seller?
@jlbayes would be a good guy to talk to about this.
Might got over to SmartyResource.com and ask about getting a new Smarty and having it unlocked. Ask for Brian over there.
Nope... No issues at all. The only thing you might look into testing is the impact against your tune using the MPG mode. All it does is raise the IAT temperature and retard the timing back in the winter time to promote better MPG's.
Truck Revs and then Dies in Traffic
Marginally high. It will work yet but randomly cause issues. My last alternator was right there floating the 0.04 to 0.05 realm and create a random surge in the cruise control. Remember I'm a manual with fly by wire cruise so instead of the torque converter issues like a automatic has I get the cruise control issues.
Absolutely... That is one of the ways to enable the high idle like I've done with my truck years ago.
Thanks for the review of the product. This will help other potential buyers.
@jimmy97458 Could I get you to put your review in the store?
Remember every filter change or anytime you open the fuel system you're going to introduce air back to that line so bleeding is just a temporary fix.
Don't bother. You can bleed it out but it will get air bubbles again. What's your fuel pressure?
SCan gauge II
Ah... I remember a person that sold his buck board and upgraded to 24V Cummins...
Wont crank just clicks
The common failure is the starter contacts...
Adrenaline v2 tuning help
Going to move to the this to the Quadzilla forum for better visibility.
Quadzilla fuel trip and instant mpg
Dang...
SCan gauge II
If you got Android phone and tablet. http://www.obdlink.com/mxbt/ I'm still running the LX series which is fine for the Dodge truck but limited on the newer vehicles. More likely you need to learn about your device you are going to use. Like my LG G5 phone can handle 2 Bluetooth devices at once. The second device could be an audio device as well. (Car stereo or Bluetooth head set) Give you an idea of my vehicle setup... Then finding out I've got a missing feature on my phone I've managed to add the feature back as a hack on a second phone number. If you didn't know Linux and Android are the same family. Hence why I've got all Linux PC's, Linux Servers, and Android Cellphones.
