The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
Doesn't connect to the MAP sensor at all. Connects to the ECT (Engine Coolant Temperature) and the IAT (Intake Air Temperature) sensors.
Headlight options
The ones I got are clear.
Quadzilla Adrenaline V2 Testing
Trying to wrap my head around what you are saying. According to your sig info your running BBI Stage 1 injectors. I understand you are flowing more fuel for your duration time. Here is someone with CR experience and difference of the fuel system and performance module makes it tough... Arrgh... I wish there was a better way to explaining the whole tuning process. More to level of Common Joe without Dyno use. I'm still trying to figure out how to spot optimal tuning using live data from the OBDII port. I even considered jump on the UDC just to try it but after firing up the software and looking at the level of confusion I returned the Smarty and gave up on that idea till I can get the tuning figured out on something simple like Quadzilla.
Odd spot for coolant.
Should be close to the coolant temperature typically.
Oil cooler is into the coolant jacket right there. So the oil cooler could be leaking.
Vulcan DS1-2 Draw Straw Upgrade
I'm sure someone has done that upgrade. I've done the old school draw straw. Still to this day no issues 12 years later.
Headlight options
Then you better haggle that out with @JAG1 being he wants to buy them too.
Methyl content for water/meth
You were right I did a bit of searching...
Going to Oregon...
Myself I would just still carry concealed. They have to find it first and yes I'm willing to take that risk too. It's not like I'm out to make trouble but to just insure my protection. Does this mean breaking some rules? YES. Like currently I travel in and out of Oregon all the time conceal carry or open carry. Does it worry me? NO. Will I continue to do so? YES. Every Day I'm taking MoparMom to Dialysis I cross into Oregon with my firearm and never had an issue as of yet. The only time my firearm leaves my side is to enter the medical clinics beyond that I've always got my firearm on me. To this day I've never be bothered to present my conceal carry permit nor has any peace office ever asked me about my weapon. Typically I get a "Thank You" for being an American and carrying a weapon.
Headlight options
Light pattern was still too narrow. Even with 4 bulbs burning still the light wasn't where it needed to be. So after seeing a friend Morimoto I bailed out of the sport headlights idea and went after the HIDs.
Can you explain why? I'm curious why you would drop the pilot injection go only with single injection event.
Headlight options
No longer... Gave up went to Morimoto HIDs.
Overheat job?
I've seen the bottom 5 inches of my radiator caked shut from mud. The only way you can clean that out is to pull the radiator out and clean it with a garden hose or power washer.
4 Inch Exhaust Needed!!!
So far I've been liking the 4" Diamond Eye Muffled exhaust. Very Very quiet. Even the exhaust brake is quiet you do hear the hiss but it toned down. I hear more turbine noise than exhaust noise now. Acceleration is improved over the 3" inch exhaust. Still after a week of driving back and forth to Ontario, OR there is ZERO change in EGT's still running 600*F at 65 MPH like my 3" exhaust did. I'm going to check over my MPG and hand math and see if there is any gains.
Torque Converter Lock / Unlock Issues
Best to test as close to the alternator as possible. Like a stud on the alternator case that is clean and bare metal would be best.
Lets see who you are!
Quadzilla V2 Custom Tunes
Learned something myself. If you creating fueling curves using exponential growth calculator like I do 4% is too steep and makes the acceleration feel notchy. About 2-3% is about the steepest you want to use. http://www.rapidtables.com/calc/math/exponential-growth-calculator.htm
Just my OBDLink LX sees CR rail pressures looking at several stock trucks I've seen in the range of 16,000 to 18,000 PSI typically. As for the VP44 injection I know we have to reach over 310 bar to just pop the injectors. Your right. We've got to pump each line to over 310 bar to get spray. CR I've seen roughly 5,000 PSI at idle (IIRC) which is about 344 bar. Like my current injectors are popped at 308 (4467.16 PSI) to 312 bar (4525.18 PSI). As for VP44 trucks I know the starting point but as for high point... That's unknown to me... 155 Bar = 2248.08 PSI 150 Bar = 2175.57 PSI
Better be higher... Just to pop the injectors on VP44 is 310 bar. Just checking 18,000 PSI which I've seen on CR engines as a measured high pressure turns into...
Going to look at this tonight
Time for pictures of what you are doing...
Quadzilla Shudder light throttle
didn't try again but later on...
Built a tune starting at a 100% and using 2% exponential growth. Still in the 1,000 to 1,499 is the nasty miss. Like after completely warming it up and driving back in my driveway it was missing right at 1,100 RPM's. Another spot on a frontage road driving slow around 25 MPH it missing good. Touch the Quadzilla to ZERO it's gone... I know its a Quadzilla issue. If I turn it to level 0 its gone. If I unplug the Quadzilla completely its gone.
Dang Dripley your head and shoulders above... (Just gotta poke at ya! )
Loss of throttle
Typically the AirDog pump doesn't whine. If it's that loud you might want to investigate a bit more. Make sure the AirDog not in contact of the cab floor. You might make sure it on the inside of the frame rail. What is your current fuel pressure idling and WOT (at highway speeds)? It could be excessive high fuel pressure making the pump whine. They make a series for 12V which are capable of producing 30-40 PSI which is way too high for the VP44 which is happy at 15-17 PSI.
- Quadzilla customization
