slipped my clutch.
Funny to hear about the ol' 50wt gear lube being used as well...
Quadzilla Shudder light throttle
All you did with that flash is move the starting point of the problem to 1,000 RPM then it starts it misfire after 1,000 RPM up to 1,200 or so. So this still points out the low end of the Quadzilla is doing something to skip or misfire cylinders. Again set for level 0 no issue.
Leaking slave cylinder
Did I read that right you are running a NAPA clutch?
Quadzilla iQuad bluetooth issues
This is my next one to shot a video of. I'll catch this one sometime today with video camera showing how many time it fails before connection.
4 Inch Exhaust Needed!!!
One last shot I'm going to make my phone calls today and see who can do the best deal for stainless 4 inch exhaust system without a muffler. Yeah I'm going back to straight pipe.
Also I've used NAPA master/slave cylinders as well.
Loss of throttle
Need to read error codes and report back your error codes. Then also check fuel pressure and report back both idle and WOT fuel pressure.
Nope. Because if I completely unplug the Quadzilla there is no problem hence how I found this issue in the first place.
Fuel sump and airdog fp150 install
The only thing I will warn about is DOT inspections might not go over very well. I know its controversial about top vs bottom draw tanks on diesel vehicles. Depends on how people read the rules on fuel supply system rules. There are states that require vehicle inspections and this kind of mod may or may not pass. I posted to remind folks of offroad usage and consider what happens if you snag your sump or filters on your AirDog or FASS. Being I deal with a lot of rancher trucks that travel offroad quite a bit I've heard all the stories of the damages from offroad operation. As for your setup CumminsTech, I think it's fine as long as you on pavement or dirt roads. The only think else I would mention is winter time operation where having the filters out of the cold wind will run better and handle gelling better.
Down Sized Injectors
Hmmm... I'm close to your setup... DAP VCO 7x0.0085 Injectors Holset HX35/40 Hybrid 60/60/12 Quadzilla Adrenaline (Untapped currently) I'll admit that with an empty truck and not towing I can stand on the throttle at it super hard to reach 1,200*F. Now towing my RV using @Me78569 Towing tune it was pretty tough to get excessive EGT's that reached the 1,300*F limit I've got set. Daily driving I've got no smoke for the most part.
Yeah and no. If the ECM applies power from the anti-stall feature then it could possibly create that issue as well. As long as it hits that throttle amount then YES it will stutter and miss. If the Quadzilla is on level ZERO no issues.
Most noticeable rolling in parking lots where speed and throttle are low. Like rolling in my driveway sounds sick with a nasty miss as I roll in the yard on light throttle. All I got to do is switch to level ZERO it's gone smooth as silk every time. If I let off the throttle it disappears. Throttle harder it disappears. Another spot is in small towns where speed limits are as low as 15 to 25 MPH shows its ugly head and sounds nasty.
Now since my exhaust rotten off the muffler. I now shorten it up to the good stuff left and put a turn down on it. You can really hear the miss now there is no muffler and open pipe under the cab. Again any Quadzilla setting above ZERO will produce the miss. Zero is smooth and clean. I know I've got to get a video of it but I'm trying to find my tripod for my camera. Hard to hold the camera and my phone at the same time attempting to record as I hold the throttle (about 2% TPS 900 RPM) and change levels up and down. https://youtu.be/4Tq1gQewzpE
I gather you don't go offroad much? The places I got I would of taken both Airdog filter and wiped them off and that sump too. This is fine for a pavement princess but I'd never install it for an offroad vehicle. Back in my high stepping days of hauling firewood. (Temporarily suspended...) Stepping over logs, stumps, rocks, limbs, etc. Didn't matter just got the job done. Ask me about the huge dent in my floorboard in the passenger side.
I'd replace both master and slave cylinders as a pair...
2000 Dodge cummins 24 valve vaccum hose
There is a lot of options of hiding the tubing in different areas.
Fuel Leak at #5 cylinder
Darn misalignment issues. Funny how the wrong order of installing parts will create such strange issues.
Teardown and Rebuild
That's why I'm bouncing just a little bit over the stock line. Won't impact the longevity and the efficiency too bad. Like for me it about travelling 4,000 a month, keeping getting MoparMom to dialysis, and get me back and forth to jobs so I can keep the bills paid.
Truck Avatar
Give me a little time and I'll build a write up about it really soon.
Quadzilla Adrenaline V2 Testing
Another vote for removing all the old versions on the iQuad app it would reduce the confusion. Then categorize all the existing and remain versions.
Is it a vp44 issue or an injector issue?
Up north Cummins engines are idled for many hours in the subzero temperatures. Basically the oil pressure low limits are 10 PSI at idle and 30 PSI at 2,000 RPM's.
Great Songs
This song fits me...
ALERT - Oregon Gun Law
I'm an open carry person. I cross back and forth into Oregon state all the time for MoparMom's dialysis treatments. I'm not going to let any law enforcement officer or government official just decide to remove my firearm from me. Kind of like my trip down to Parma, ID for the eclipse event and meeting @JAG1 and @IBMobile I was still open carrying my pistol even then. Where I live 911 call could be an hour wait for help. So it up to myself to protect my family and me.
Mopar73 Full Eclipse Meet and Greet Camp Trip Aug 18th Thru the 21st 2017
I'll admit. Daniel (IBMobile) and Jennifer are wonderful people. After spending the time installing his injection pump and working on his truck its been a pleasure spending time with Daniel and Jennifer. Of course, MoparMom and Jennifer went their own direction to enjoy conversation and IBMobile and I got busy getting at injection pump installed. I wish I could spend more time with them and show them more around the area I'm sure they would have enjoyed the experience. Maybe another time we can build another get-together camping trip where we all can enjoy some free time. Be safe Daniel and Jennifer and enjoy your vacation trip...
This is the only thing I will disagree with. The injector to connector tube seal would only leak into the return rail. The leakage on the manifold would only be the high pressure line to connector tube or the o-ring. Now if there is a puddle of fuel on the cap area of the nut it will expand out and weep on the manifold. Typically in about a week time it will dry up and be fine. You can check with a can of brake clean on a warm engine then drive again if it continues to get wet then its connector tube or o-ring issues.
