  1. Ok. I've still got this issue and very annoying. This is an LG G5 phone and its brand new not even a year old. Now the issue is Bluetooth is hanging up on any custom tunes. So if I do like I normally do on my trip back and forth from Ontario, OR. I'll set up at home and fire up the iQuad app but it might nearly 20 miles of shutting down and starting up before I get iQuad to hook up on bluetooth. So like every 4-5 miles I shut the app down and fire it back up. I'll get a quick message about couldn't connect to device. By the time I get to about New Meadows 20 miles away it might hook up. Now if I want to for sure hook up first time then fire up iQuad switch to DEFAULT tune, then shut down iQuad. Now fire back uo iQuad it will hook up in under 30 seconds typically. Then I can switch to my custom tune without an issue. If I shut down the engine and restart I might be back to fighting it and might now. Most times on my trips I'm stopping to eat somewhere so I shut down the iQuad and go in with my cellphone to work on the web site. Now I'm back to the bluetooth fight again.
  2. Umm... They are both in the construction trade...
  3. I had the same problem all I did was flush the system out with some Walmart Supertech power steering fluid and that is gone. Fresh fluid does wonders. You not using ATF by chance are you?
  4. Again E85 is only 75% of the BTU value (81k BTU's) than normal clear gasoline has (114k BTU's). 1.5 gallons of ethanol has the same energy content as 1.0 gallon of gasoline.
  5. No. It wont. Timing is computer controlled unless you got a tuner. Octane is the sbility to RESIST ignition by compression. Like im running Mopar Performance PCM it requires 92 octane to prevent knock/ping issues. On that truck the timing is cranked up to 40* BTC.
  6. Just to let you know all bio fuels be it biodiesel or ethanol gas will alway be lower in BTUs. https://en.m.wikipedia.org/wiki/Gasoline_gallon_equivalent
  7. Mine can be hot after running the truck on the highway for 3 hours then get even hotter sitting in parking lot idling for 4 hours. But my daily driving locally arond home it stays rather cool to the touch.
  8. Ive made it to Parma. Most of you already know my cell number. Give me a shout.
  9. Sorry for there loss...
  10. Tone ring broke... Mine failed the same way. Just replace them as a pair.
  11. Where are you located at could you fill out your profile? Rocky Mountain Cummins is in Boise ID. I'll be in Ontario, OR all this week. If you want to get together.
  12. At least with my BigTex trailer I grease it regularly every year no issues with bearing failure from full hubs nor any issues with grease pushing the rear seal out. As for the RV I've got to hand pack those bearing but always end up with a full can of grease use for all 4 axles that's packing more grease in the hubs as well. As for tire balancing I'm going to just pickup a few boxes of BB's and put in about 6 ounces in to each tire when I replace my tire here soon. Just about down to the wear bars and will be needing good rubber for this coming winter too.
  13. OMG... Nick you not helping this...
  14. Let be real there... Geez....
  15. Come on gang... Time to get this thread going again...
  16. I've got a good question? If all the dealers are sold out and OEM is no longer manufactured so where is Geno's getting there fan clutches at? Is what Geno's is selling a true OEM fan clutch? Make you think a second...
  17. The alternator is shot. Replace... Anything over 0.1 AC volts at the BATT stud is an instant fail. Double check your electrical system for any ground modifications or noise filters added at the PCM. Remove all modifications and return the electrical back to factory layout and remove any addon's. This will make the noise easier to detect all the other modification mask or hide the issue making it tougher to test for or detect the issue.
  18. Just dart over to Harbor Freight and pick up a set of sockets from 1 to 2 inch. Then get a 3/4" ratchet and a 3/4 to 1" adapter. You'll be set. I've got the exact setup here and now you can do more than just the hub nut. How about hitch ball nuts, etc. Really handy to have at least this set.
  19. Officially I'm getting the RV out today and getting it hitched up and hauled to Parma, ID. So far I still only see @JAG1 and @IBMobile as a for sure.
  20. I would suggest hooking up with @AH64ID ...
  21. I taking my welders hood. Im going to drag my RV down tomorrow to Parma.
  22. @dripley if you do this rebuild you know you gotta make a write up of that...
