  1. Here is what is happening for my truck. Any power level above ZERO and any tune including DEFAULT tune will do this. ZERO level is clean and smooth no issues. Reflashed my Quadzilla with the current tune and even dumped my iQuad App and reinstalled.
  2. In my case you can shut every thing down and start the engine, iQuad, drive for 5 minutes, touch the power up 1 level and FREEZE. Has nothing to do with setting a tune or not.
  3. Apparently, there is a serious issue here.
  4. Exactly the same problem I'm having. I attempted to build two different tunes and any tune I build I have the same problem. Now here is how to recover back to functional. Shut down the app. Restart the app and quickly head to custom tuning and select DEFAULT tune. Then shut down the app again. Now restart and the app should function again without crashing. As long as you stay to the default tune. I'm having the same weird issue with just the standard Fueling tune. The only thing that is different I can't import my exported tunes here on the site. The import saves it to the App but doesn't display. Then if you try importing again it will tell you the tune already exist. Nothing is listed though... Hard to select a tune you can't see. Now on the default tune any power level above 0 will produce studdering issues in the 2-5% throttle range. I can hold the throttle and change levels as it hits 0 the engine runs smooth. Again if I create a tune then just changing the level will crash the app.
  5. A peek at mine 1.5 years ago...
  6. Even with my rebuild i asked for all the parts that were replaced. So I got to see all the worn bearings, the carbon syncros, and my broken mainshaft. Like i said before my rebuild the transmission was fully disassembled and the case was tanked then painted.
  7. Wow. I would have stopped at the first sign of the sludge in the openings and never installed the transmission. I had Weller truck in Boise rebuild my transmission and so far I'm just crossing over 50k miles and no issues to report really. I did have some shift issue early on after the install but that was a clutch issue more so than transmission. After installing a new South Bend Clutch all shift issues went away. Still, I would have never installed the transmission if I have seen sludge inside any opening or hole. Then means that your transmission was never rebuilt or you were given a core transmission. When mine was rebuilt I could tell it was fully broke down and tanked and repainted and very clean inside and out.
  8. Yeah I can't speak for the new 4th generation pumps. I know the raptors are junk I've got one at the house that ate the pump shaft with just the rubber seal. Weird?! I'm not fond of the adjustable fuel pressure regulator. I like the old spring and check ball they work the best. I know @Me78569 has a Pureflow pump that has zero issues. Might ask Me78569 about his...
  9. You could have my 11 year old AirDog 150 pump that has held 15 to 17 PSI the whole time.
  10. Might be in the same boat myself. Quad has a dead spot at 1 to 2% throttle and misses and studders. Above that it same to run normally. Unhook the Quad the problem doesn't exist normal throttle. Gotta call Spencer next...
  11. One thing most people won't tell you that hybrid doesn't travel too far without a charge. From what I've seen is about 15-20 miles tops. Out where I'm at they will not survive even one trip to the store or drive to work it's too far for any hybrid. I'm seeing about $1,500 to $2,000 roughly. Average life span of the battery is about 100k miles. Unless you have a power plant like mine. Solar and Hydro. Zero Emissions... Then down the road from my place is another hydro power plant. The majority of Idaho power comes from Oxbow dam on the snake river. https://en.wikipedia.org/wiki/Oxbow_Dam
  12. Same here I've got 4 rolls... Tie wire is handy you can make all kinds of tools with it. Like probe tips for electrical sockets, small snap ring tips can be made. List goes on and on.
  13. Ok I'm a bit off... BBI's are still a bit over $3,000. http://smartyresource.net/store/product/32-bbi-injector-set-stage-05-03-04/ http://smartyresource.net/store/product/13-bbi-injector-set-stage-4-20075/
  14. Just wait... Get a 3rd or 4th gen and start planning on injector changes every 100-150k miles. Looking at around $4,000 for quality set of new injectors. If you think you can just over look that fact so many people lose an engine over bad common rail injectors. Then there are people driving around with the grid heater light on. High return flow from bad injectors kind of a check engine light of injectors. So now we whine about $1,100 for injection pumps every 100-200k miles. Then if you happen to wipe out a CR engine then look towards about $6.000 to be rebuilt.
  15. Been I keep traveling for MoparMom behalf every other day even through nasty winter storms at temps as low as -35*F never had a single problem shifting. Now take the temperature and crank it up to as high as 115*F so far this summer and transmission temperature hover at about 160-170*F on average. Still shifting good. At least the NV4500 is cover now by an another good choice of lubricant. I fell for that scare too about how you could NEVER use any but the MOPAR fluid for years. Now to find out there are options and understand what you have to look for fluid wise. Also understand why Mopar created their own fluid line and why for both the NV4500 and NV5600 Transmission again most think its syncro the fluid was design for but actually the fluid was design around gear teeth temperatures.
  16. Some of that you got to look at from both sides. Like I've got a buddy down here with G56 trans and using ATF+4 and having shifting issues now. So if he switches up to another GL-4 rated fluid (any name) its not going to resolve the pre-existing shift issues. Like in his case it could be clutch hydros giving some issues maybe? So being truthful about a fluid and how it working is rather hard with existing issues or outside issues impacting shift quality. Like in my case I started out with a fresh rebuilt transmission and worn clutch so my shift quality improved after the clutch replacement. This just points out not all stated issues are lubricant created. Great... I'm glad you are happy with your choice of fluid. I just want people to see there is more than just one brand of Synthetic Lubricant on the market. There are several brands on the market.
  17. Very true... Did you also know there is GL-1 through GL-6 which Gl-1 to GL-3 and GL-6 is obsolete now. But the rating is still held. As torque and power increase with vehicles most transmissions are now using GL-4 or GL-5 lubricants. Like The GetRag transmission was in the early years of the Dodge Cummins trucks. As for the G56 actually that was DC way of cutting corners and saving some money by not having to stock a special gear lubricant for the G56 transmission. (At least what I understand).
  18. Kind of like ATF+4 the specified fluid for the G56 transmission but so many people believe the specified fluid isn't making the grade. Just like going back in history with the Getrag 5 speed transmission running on 10w-30 engine oil (IIRC). Not even in the GL range at all. So I tend to watch specs and specification not exactly have to follow them. Kind of like, here is one 308k miles on the clock I've never ran ATF+4 in my transfer case. Yes I know the transfer case is specified to have ATF+4. I've always filled it with ATF+3 or Dexrtron. No harm or damage has occured to my transfer case from using an out of spec fluid. Kind of like another group using tractor transmission fluid in 47RE transmissions again some have had good results. So we can go on and on about specs... Doesn't mean the end of the world or your transmission. At least I'm using a Synthetic Transmission Lubricant, close to the same viscosity at the operational temperature a bit thicker in the cold but synthetics always flowed better in the cold. At least the fluid I have currently is GL-4 rated. The two weakness on the NV4500 was the gear teeth getting hot and popping and the carbon fiber syncros. Being the GL-4 covers the carbon fiber syncros and the viscosity is plenty thick shouldn't have much issues. Daily driver and towing...
  19. When I first started this a year ago the page was different and did state it was a GL-1 to GL-4 fluid. Then over the months that past that page is no longer in existance the data page is gone now. So I know the site page and data has been changed that why I'm willing to battle this being I remember seeing that Mobil was, in fact, a GL-4 product when I purchased it during the transmission rebuild. Being my warranty is up back in February I've not seen any signs of any transmission problems. So between when I purchased the oil and now the page data and URL have changed. Why? I got no idea... So far I'm very pleased. There is zero color change in the last check of the fluid. I will admit the amount over filled I'm running is pushing some fluid out the vent very minor amount. Still got to get the truck tilted quite a ways to keep from pouring out the fill hole. Every time I've checked the fluid color it still looks bucket fresh yet no color difference. I'm just under 50k miles. Still laying down 250 to 270 miles every other day and still handshaking that stick with no problems. Oh I've found several other folks that have been using same fluid in there NV4500, NV5600 and G56 transmissions. I've not hear of any issues as of yet.
  20. Also look at the sway bar link the stud is bent at a 45-degree angle. Axle angle is wrong most likely because of the lift and creating new geometry on the axle because if the geometry was correct that sway bar link wouldn't be bent over at a 45-degree angle. Redneck lift kit. I've seen too many of these and people trash good trucks just to look cool then when it cost too much to fix they sell it.
  21. That because I provided product number and other information off my bucket. Like I learned today no manufacturer can place a API rating on a container unless it actually does meet the API rating. So like they explained to me what I see on the bucket label with the MT-1 and GL-4 it does MEET the API standard. May not exceed the standard but does have to meet the requirement for the GL-4 or any API rating to be placed on the label. So this is not a misprint in my photo Mobil does meet the GL-4 API standard. https://mopar1973man.com/storage/attachments/monthly_2017_07/DSCF4231.JPG.01d0fc29c90050aeb4ea931dd75678a4.JPG
  22. I'm back... I've done my own phone calls on the subject to Mobil... Truth, Mobil states product 103158 Mobil Synthetic Transmission Fluid 50 has API rating GL-4. They cannot mark a container with a specification that it does not meet because of legal issues and/or warranty issues. After discussing this matter with the tech I will have an email by later this evening stating that the product 103158 that I'm currently using is indeed carrying the API standard of GL-4. Yes, it's also MT-1 but meets both GL-4 and MT-1 API standards.
  23. I never suggest stretching the spring way too hard to hit the mark. I highly suggest replacing the spring and check ball. Then if you need adjusting the pressure then use washers for shims on the spring.
