Oil change
At least my junk isn't blowing oil all over the place. Mine does leak a bit around the gear case and burn a bit through valve seals.
Towing toy hauler
Vulcan Performance.
EGT's after the turbo
True. But why?
Just lot easier to look at how hot the fire is leaving the head than attempting to do math and figuring out from post temps. I really don't care what the temps are after the turbo. I do care above the fire leaving the head that it not hot enough to damage pistons or the turbo. Back to using pre-turbo temperatures. Why make it complicated with math and figures when you just drill a pre turbo port and be done.
Oil change
Make it 300k+ junk... Typically any "name brand oil" with API of CI-4 and above with a viscosity of 15w-40. Gotta ask @dorkweed about his 84k oil change on SuperTech.
Emissions time is here
Just remember two things that will not work when in this state. Exhaust Brake High Idle Kit Both these products require the IVS in the APPS to toggle to idle position for them to function. With what @Me78569 is suggesting will work for smog reasons but will also disable the device I listed above.
Towing toy hauler
I ran RV275 and +50HP injectors with a stock HX35W turbo. You can go up to +100HP injectors on a stock HX35W.
Wheels and Tire Setup
All I can say is just wait till winter time or wet season. You are going to hate those tires poking out like that. I finally got mine tucked back under the fenders. After driving all winter and spring I started hating every 20 miles looking for a service station so I could clean the side windows. 20-30 miles the windows were so coated with salt and mud that you couldn't see in the mirrors to pass any one or lane change safely.
Towing toy hauler
4" is fine... No reason for 5". Even stock 3" will not hamper performance being after 15 years of stock 3" exhaust I've done very well at setting high MPG numbers in the past and performance is still awesome.
Towing toy hauler
I've confirm the turbo specs on the HX35 is correct. Just the injector sizes don't seem right though. I know the injectors I've got are 7 x 0.0085 for +75 HP. Here is what I stole off of DAP site...
Towing toy hauler
As you see all 2nd gen list 245s for tires on the 2500 series. Even though most 4WD were 265s.
Towing toy hauler
Towing toy hauler
3500 series yes... 2500 was 265's for 4WD I'm sure of. As for the 235's the only series I knew for sure was the 3500. This goes back to the argument of the information posted in the door jam about tire size and information. Which 90% of the time is untrue. Even both of my truck post wrong information. My 2002 states 245/75 R16 was stock (wrong it was manufactured with 265/75 R16) then my 1996 states 215/75 R16 was stock (it was manufactured with 235/85 R16). So as for the 245's I think that was more of 2WD series tire personally I've never seen it on any tire as of yet. Still in all getting back to the OP there should be any issue towing with his combo. Might just have to add more fuel and it would pull better.
NO BUS NO START NOW NO CRANK? HELP PLEASE
Here is the starting circuit for our trucks. I know the J/C in the PDC that is a ground bar inside this is the same bar that has ground for the fuel pump relay too.
Towing toy hauler
I know the 245/75R17 is not factory. They are about 0.1" to 0.3" smaller depending and what you compare them too. This makes the rev per mile for your tires 660 Rev/mile. This should have the effect of smaller final gears making towing easier. My 235/85 R16 are taller and narrower or 265/75 R16 are taller and wider. Typically the stock size is 245/75 R16 for 2WD trucks and 265/75 R16 for 4WD. This is only rule of thumb... I've seen 2WD truck sold with 265/75 R16 as well. https://tiresize.com/calculator/
Bears in the trash? Problem solved!
I'm surprised the bear didn't attack the animated clown...
Shocks
So my current pressures I'm 60 front 40 in the rear. So using your tables I would be 50 in the front and 30 in the rear. MPG??? Just for fun, I'll try your table and pressures.
Shocks
Not all table are created equal... This Michelin weight to pressure table. Same sized tire and capacity... 35 = 45 PSI (10 PSI different with Michelin) 40 = 48 PSI 45 = 52 PSI 50 = 57 PSI 55 = 60 PSI 60 = 63 PSI 65 = 68 PSI 70 = 72 PSI 75 = 76 PSI Still in all this would with either table have my rear axle pressure below the 35 PSI because tire weight is only 1430 pounds (Axle weight 2860 / 2). So would a person gamble with 30 PSI at 1,430# ??? 1430# / 3042 = 0.47 x 80 = 37 PSI (Currently set to 40)
Shocks
Just for fun comparing... 35 PSI 1700# = 1700 / 3042 = 0.55 x 80 = 44 PSI 40 PSI 1870# = 1870 / 3042 = 0.61 x 80 = 49 PSI 45 PSI 2030# = 2030 / 3042 = 0.66 x 80 = 53 PSI 50 PSI 2205# = 2205 / 3042 = 0.72 x 80 = 57 PSI 55 PSI 2335# = 2335 / 3042 = 0.76 x 80 = 61 PSI 60 PSI 2485# = 2485 / 3042 = 0.81 x 80 = 65 PSI 65 PSI 2623# = 2623 / 3042 = 0.86 x 80 = 68 PSI 70 PSI 2765# = 2765 / 3042 = 0.90 x 80 = 72 PSI 75 PSI 2905# = 2905 / 3042 = 0.95 x 80 = 76 PSI 80 PSI 3042# = 3042 / 3042 = 1.0 x 80 = 80 PSI I think I'll keep my math thank you... 9 PSI drop at the low side of the scale is rather way too soft for the amount of weight.
Shocks
Empty tire pressures for my truck are... 60 PSI Front 40 PSI Rear Now what will it carry??? 60 / 80 = 0.75 x 3042 = 2281 x 2 = 4563 pounds on the front axle 40 / 80 = 0.5 x 3042 =1521 x 2 = 3042 pounds on the rear axle 7605 pounds carry weight My truck actually scales at about 7,400 pounds with Mom, Diesel and myself in the truck. Trailer towing 60 PSI Front 60 PSI Rear Now what will it carry??? 60 / 80 = 0.75 x 3042 = 2281 x 2 = 4563 pounds on the front and rear axle 9126 pounds carry weight (Remember the truck is rated for 8,800 GVWR) 5200 + 6084 = 11,284 pounds carry capacity. I hardly doubt your anywhere near that empty. Even doubtful with your RV. I know it big and heavy but 2,484 over GVWR...
Mopar73 Full Eclipse Meet and Greet Camp Trip Aug 18th Thru the 21st 2017
Come on guys don't forget to hit the GOING button on the calendar... So far I only know of 2 people going. Attendees JAG1 Mopar1973Man IBMobile Declined AH64ID
Explain your jumper wire... The PDC under the hood doesn't have any ground connections except inside which requires you to split the case open. The fuse panel in the cab has no grounds that I know off. FASS fuel pressure is because the return line is either kinked shut or the ball and spring is malfunctioning.
Quart low every month?
Gasoline engines have vacuum at the manifold so all you need is worn valve seals and it will draw in small amounts of oil into to the combustion chamber.
August 2017 Eclipse camping
Good luck...I don't even have a site yet I might just drive back and forth. Unknown what I'm doing as of yet. Can't spend what you don't have...
Towing toy hauler
Gear ratio (3.55:1) and tire (30.4 inch tall) are perfect. With your 6 speed transmission you are the same as I am for your top two gears. I'm also running 31 inch tires and 3.55 gears. Just I'm running a 5 speed. NV4500 5th Gear -> 0.75 -=- 0.73 <- NV6500 6th Gear NV4500 4th Gear -> 1:1 -=- 1:1 <- NV5600 5th Gear Gearing and transmission are fine and nothing else needs to be done. As a matter of fact I'm towing a 31' Jayco travel trailer and have nearly the same setup just adding injectors will change the towing ability. Ttime to go up in fuel. Time for some larger injectors maybe a turbo depending on how big of injectors you jump up to. https://mopar1973man.com/garage/vehicle/103-2000-jayco-eagle-296-fbs/
