2nd 3rd 47 RE tranny Problem
He's a great guy and will be able to guide you through your problem on your transmission. France is a bit too far to go for help. Might be fun to have you place a member pin on the member's map also fill out your location in your profile so people will know. I've had a few member now that popped up in countries outside the US. Just city and country is plenty.
Shocks
Most likely the tire pressures are too high. This one reason I run two different tire pressures because if I left the tires inflated for towing then the ride is really harsh when I'm not towing.
trreed's upgrade thread
My spring mod is similar but instead of coiled like his my is a 90* tail in the center of the coil preventing the ball from sneaking into the coil.
Engine miss
Your injectors have to be removed from the engine and then taken to a shop to be pop tested.
Engine miss
Possible... Typically I noticed the miss more so during idling state.
Engine miss
Welcome... Err um... Mopar Man... I would start out testing the alternator for excessive AC noise.
Welcome Jeremy... The best person to get a hold of is @Dynamic he is the site transmission guy.
Shocks
Personally, I think there is way too much hype for Bilstein shocks.
Front main seal
Here is my write up...
My ProForm Hiit Trainer Pro Elliptical Is Making A Worrisome Noise
Youtube or Facebook both... You might consider using Facebook. Sure make logging in much easier when you have long passwords. Being I've got 32-64 character passwords I can log into Facebook then let Facebook log me into my site securely. So I only need to unlock facebook then I can log into most other site using my Facebook account. This is a huge life saver being typing long passwords on a cellphone is a royal pain in the . So either way you look at it, you need an account on either Facebook or Youtube (Google). I would say stay with Google more so. You can use your Google account also to log into the site as well. Mopar1973Man can use - Facebook, Google, Linkedin, etc.
All I get is Idle and High Idle
AC voltage was what? We need to hear the results.
Wheels and Tire Setup
True they are... I had to straighten out the out of balance issue and was experimenting with higher pressure and lower pressures. Adding +10 PSI to calculated number help take the bounce out. -5 PSI helped take the cupping out of the shoulders from excessive runout on the previous wheels. They will be worn out by this fall and be needing to be replaced.
Shocks
I'm running Rancho 5000 series shocks with over 100k miles on them and still doing excellent towing heavy, offroad travel, or on highway travel.
August 2017 Eclipse camping
I know the feeling... I've got a spot here locally called "No Tellum Creek". I'm not telling where the creek is nor the camp spot.
Mine, I'm running 60 PSI front, and 40 PSI on the rear. Towing I just inflate the rear to 60 PSI and I'm able to handle 18,000 pounds GCW.
Test your alternator for excessive AC noise. I've got a feeling the VP44 is fine but the ECM is going south. APPS sensor has two validation switch so as soon as it goes to throttling mode it's now jumping to high idle and that it which means there is an ECM fueling map issue caused from AC noise.
High Idle switch
This is the newest revision. The old version that Ed Grafton produced like @Me78569 said have the wires soldered to the back of the switch. Ed's design is prone to failure because of the weight of the cable pulling the contacts out of the switch. The new version removes the tension on the switch contacts being they are all soldered into a PCB. This is the older Ed Grafton series... Notice there is no PCB...
Dropping below idle
Yes... I hate to say it my +75HP injectors from DAP did this. They turned out to be carboned fouled. I'm in the process of sending them back to be looked at. Mine was much worse it would drop to 500 then surge to 1,000 RPM and continue till you stopped. Then idle at a perfect 800 RPM. Then if you launched again it was prone to stalling out.
Any body men?
Don't forget the other bigger tools... Bigger hammers, bigger come-a-long, etc.
Worth trying....Olive Oil on truck.
I wonder how much dust the oil is going to collect?
Front end lift questions
Jack it up by the frame. Allow the axle to hang barely. Remove the tires. Remove the shocks. Then remove the shims.
Stuttering that I can't quite figure out
@Me78569 is right. Make sure to rehook the MAP sensor then you should be able to just unplug the Quadzilla module.
Dead pedal! Apps Calibration! Help!!!!!!
Which APPS sensor are you using? So many people adjust the APPS sensor wrong or too high creating issues. Before I can advise more II need to know which APPS sensor you are using.
Torque Converter to Flexplate Loose Bolts
I tend to agree it's much easier to build the auto than attempting to convert to a manual.
P245A code
P245A is a EGR voltage issue. https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2007-up-114/code-p245a-158708/#post1585136
