  1. I did not bother with balancing but it does run smooth as silk after the rebuilding with new u-joints and the centering ball.
  2. Hard call on the photo. I've got an updated case but the hole seems smaller. I'll have to dig up that photo. @dripley yes that is the KDP (Killer Dowl Pin). Just look closely if the dowel pin can slide out if so you should tab it. I'm never thought of deforming the hole.
  3. Hua? The green and blue wires on the back of the alternator. No tools needs just squeeze the release tab and pull. The alternator fuse you'll need an 8mm socket to remove.
  4. @dripley just keep in mind the front seal is a dust lip and tends to cut into the crank. Now the polished ring behind is the actual oil seal riding area. So that groove your pointing at is caused from all the dust piling up at the front dust lip. Even mine had a groove too. I just installed another seal and moved on.
  5. With a good fuel system, I idle a17 PSI and drop to 15-16 PSI WOT at nearly 100 MPH. This depends on fuel temperature. Warmer the fuel the better it holds pressure.
  6. There are some of us without TV and can't watch it. The only time I watch the show is when I find them on YouTube.
  7. Since I've got an aftermarket stereo the lead is not in use in the adapter plug so I used it for all my dash lighting for my aftermarket stuff. This lead goes to my terminal block at the knee bolster on the driver side then branches out and powers gauge lighting.
  8. I imagine it's possible being the chain store tensioners could have plastic bushings and other soft metals that may fail rapidly. As for the tensioner I got from NAPA it pretty beefy design and I've checked it for movement. Now as for the tensioner movement look towards a deformed belt. Like my belt has a small spot where the arm wiggles as it passes by every revolution.
  9. Turn the belt around backwards and try again. That's how I fixed my squeak.
  10. Left hand threads for the fan clutch. So it reverse.
  11. Yes sir.. 1/8 inch air brake line.
  12. Mine is remote mounted to the driver side fender. This gives time for the pulses to fade over distance. Then if you have to test the gauge you can add a test and add your test gauge. Easy access and way less problems.
  13. Typically there is a spring that holds the lower half of the basket down in the tank bottom. I would consider going to a drawstraw or something else if the basket is damaged. You only going to fight that problem over and over. You could order the Jeep basket from Vulcan Performance.
  14. It does hurt the gauge or gauge senders. Closer you are to the VP44 the stronger the water hammer pulses are and the more damage it does to the gauge. Don't hurt the VP44 one bit but get rather expensive to constantly replacing gauges or senders.
  15. The owner called me today and had a p0232 code. Truck runs fine but can't erase the code. Unplug the VP44 and still, the code remains. Now if he removed the fuel pump relay in the PDC it would erase the code but return instantly if the relay was plugged back in. This owner also admitted to having a BD noise filter as well. I told him to test the alternator for excessive AC noise. Back to the VP44 code, he mentions he had a second pump. So I had him just plug it in without installing the pump and the code erased and stayed out. So again another AC noise story that ate a VP44 because the owner was battling the torque converter lock up issue and ate the VP44 with excessive AC noise.
  16. I got a job that a 2001 Dodge was having lock up issues typically. Now the owner had the BD noise filter, the APPS wiring mod and ground mods. Still in all the truck ran with a surge and dropping of power. The old alternator I measured at 0.1 to nearly 0.2 volts AC. He replaced the alternator I measured today and its right about 0.04 to 0.05 marginal. Still the loss of power and surging. The owner has a Bank's tuner on so I opted to removing the MAP leads and return to stock and the Wire Tap. Went for a test drive and the problem is gone. Moral of this post is alternator noise can do damage to even 3rd party device like tuners.
  17. I'm running a Jacobs brake (Sold by Dodge) but they are no longer sold. So I would suggest a PacBrake for you.
  18. Path... /Internal Storage/Android/data/com.quadzillapower.iQuad/cache This is where exports are stored. So you need to export it to something like Email to get it on the directory.
  19. Disconnect the field lead on the alternator and see if the problem goes away. If so the alternator is bad...
  20. Would be better to put an exhaust brake on and then you rarely touch the brake pedal. I service my brakes every 180-190k miles now with stock 16" wheels and stock OEM calipers. Exhaust brake has no technical wear and will extend the brake life quite a bit even with city driving. @portlandareae28 you might not know this but I drive to Boise every other day for @MoparMom to get dialysis. So I'm in Boise traffic every Tuesday, Thursday, and Saturday. Exhaust brake works wonderfully in reducing brake wear. Labor book calls for 4 hours to R&R a VP44. I typically now do then in 1.5 hours without thinking.
  21. Be careful there is a lot of wannabes electrical hacks out there that think they have all the answer on how to create better electrical. ECM, PCM and VP44 all get there ground from the passenger side battery negative terminal. As for the VP44 power that is the fuel pump relay in the PDC if there was a problem power wise it will throw a P1689 code. Since the code is not present I would have to say most likely not true. As for the P0216 there is nothing you can do to fix it and the VP44 is going to have to be replaced. I've now lost my second VP44 to P0216 codes. The first one last 50k miles (under warranty). The second one went 243k miles and the finally died last month. P0382 your grid heater solenoid is either disconnected or failed. P0222 is a failed APPS sensor that is not reporting the proper validation signals to the ECM.
  22. There is only one other place for fuel to enter the crankcase which is the front seal of the VP44. Typically this could happen of the fuel pressure is driven well above 20 PSI on a weak or worn front VP44 seal. Most typically though the bad injector is the cause of the fuel in the oil.
  23. Stock APPS sensor is safe at 0.4 to 0.5 volts. Timbo APPS doesn't have a voltage setting it completely mechanical. Wells APPS is safe at 0.5 to 0.6 volts. The voltage adjustment is not for anything else but the idle validation switches. This has zero to do with transmission shifting, or lock up.
