  1. Same here... What looks horrid is a leveled truck towing a trailer and having the headlights in the sky, rear bump sagging down like a squatting Ford. Best not to level the truck also fewer issues with the front axle
  2. Way too many think you can toss a lift kit/leveling kit and larger tires and everything works. Sorry, it doesn't work that way you need to get the geometry of the front axle back to the way it was without the lift or leveling kit. Axle angles are all wrong after a lift. Typically longer control arms that adjustable will help as well as the adjustable track bar. Then you have to consider the leveraging forces of the larger tire and what it's doing to tie rod ends, wheel bearings and ball joints. Soi now you have to consider larger rational mass and larger leveraging forces on stock parts and people wonder why the "Cool Look" cost so much...
  3. Two wire plug. Green and blue wires.
  4. Set for level 1 and enjoy. Any sublevel will work. Any level 2-5 will still work but do nothing more than Level 1 because there is no wire tap.
  5. Pull the field lead from the alternator when it starts happening. If it goes away then its AC noise from a failed diode. I've see rare cases where diodes break a solder joint and randomly make and break the connection. Where temperature could play a roll on how the broken part may expand and contract.
  6. Typically we buy an AirDog or FASS fuel systems. Like myself, I've got a 11-year-old AirDog 150 and still working just fine. I was lucky and got one of the older Airdog pumps that were built the right way. You can run the CanBus connector but not the wire tap. I'm doing the same thing with my Quadzilla right now no wire tap but still running the CanBus.
  7. No. All 6 injectors have to pulled and pop tested. There is no test that can be done without removal. No. Because you need to be able to see the nozzle and if it pissy as you rise up in pressure. It should remain closed till you reach pop pressure. As injectors wear the pop pressure gets lower and the injector becomes pissy. A failed injector(s) don't normal change in smoke or anything it might get a random misfire but not always. As pop pressure falls it just advancing timing. The spray quality might degrade and it might not. All depends on the failure. That's possible for the growing oil but would explain the loss of prime because the oil would seal the leak after the pressure faded. Crossover o-ring could produce a loss of prime but typically the manifold would be moist or wet with fuel from the leak.
  8. Yeah I know. I'm pointing out the fact if the front band is getting low and thin the rest of the wearable parts like clutches (direct and over drive), torque converter clutch, and the rear band are going to be getting thin too. Very rare for just a single part to be getting thin and the rest are good yet. Typically they all wear out together...
  9. Just remember Blue Chip is NOT on my list of Certified VP44 rebuilders. They do not have a Bosch 815 test stand either to test pumps or flash PSG's so this is why the sell pumps with USED PSG units.
  10. You might be able to do this but how about the direct and overdrive clutches I bet they are getting low too.
  11. Vulcan Performance sells industrial injection and DAP sells both industrial injection and midwest injection. Both rebuilders are certified Bosch rebuilders.
  12. Even for owning a gasoline 5.9L V8 with a 46RE (Dynamic Built) transmission its head and shoulders above stock. 1-2 and 2-3 are very firm shifting and let you know that this is not a stock transmission. Gear hold back is much improved now compared to stock which was like putting the truck in neutral on a steep grade. MPG wise it can produce good MPG's as long as you not running excessive fast or playing too much on the streets. If I had a 47RE in a Cummins I would repeat the build again with Jon at Dynamic. No questions asked.
  13. Just for the information value I'll post up what billet is all about. http://victorylibrary.com/mopar/billet-c.htm
  14. You need to drop in once in awhile there is always someone talking transmissions here.
  15. Error codes will not self-erase till 40 warm up cycles have been completed without any more errors recorded.
  16. That article I need to complete putting the wiring maps into...
  17. I would read over the link that @jlbayes posted and review you electrical for the ECM to the APPS. The signal for the PCM is between the ECM and PCM but typical its the APPS to ECM.
  18. @Dynamic is an awesome transmission builder.
  19. I would wipe everything down and clean all surfaces and reuse them. Just make sure to clean all the grit and dirt off all the parts before assembly.
  20. I'm closing in on 300k really quick. 298k and still rolling the highways. So I've might of had a few failures (transmission, wheel bearing, etc) but nothing last forever. I'll still gladly hop on the seat and haul anywhere at the drop of a hat.
  21. Would you be willing to document out the wiring and everything you did to make this work I'm sure there is others out there that would like to be able to do this.
  22. This right here is how this whole mistake of Mopar1973Man.Com came to existing... I did the whole forum thing trying to figure out my first bad injection pump failure back in 2004. Then got the answer I needed. Got the pumps (lift and VP44) under warranty. Then I contniued to pay it forward. My daily notes and learning grow to the point I started building web pages and articles which started the web site in 2005... The rest you all know the story...
  23. Educated guess... I would say the thrust washer and thrust plate are worn but when it cooled off the oil thickens and part contract a bit filling the void.
  24. Another reason I'll stay to the OEM box... I can't see paying $700 for any steering box. I just looked on RockAuto and ranging from $150 to $300 for steering gear box. Rebuild kits for OEM box is $14 to $17 very simple to rebuild yourself. I'm only 2k from 300k miles on this steering box.
  25. Might be helpful to data log your run with your truck and post the Quadzilla data log.
