  1. Might talk to Michael @ ISSPro Gauges he might be able to answer this.
  2. Just sent @Dynamic a PM to get his attention.
  3. Seriously I'm just a true stock suspension I've never modified mine at all. Basically just remove your leveling kit and return to stock.
  4. Always best to have pre turbo EGT than post turbo EGT.
  5. Not sure of the mileage on them at the moment. No. Black wall on both sides. As for the wheels they are not exactly what I wanted. But... They were cheap (traded for fixing a friend's well pump). Now at least the wheels are true compared to my last set of wheels at least 2 has excessive runout. So they might not look pretty but they straight and didn't require new tires right off.
  6. I'm not a fan of Toyo or Cooper tires. I've ran Coopers for about 1/2 a year and ended up giving them away because they are just too heavy of tire. Toyo has this problem too the carcass is very heavy and eats away at the MPG numbers. They might be a strong carcass for offroad but terrible for on highway MPG's. Both Toyo and Cooper in 265's had poor winter performance very slick tire. 235/85 R16 on stock 2nd gen steel 16x7 wheels. This is what I got left... Just rolled in the yard...
  7. Stock basket is still present untouched. Draw straw is not inside nor near the stock basket. My straw is in the open space of the tank without any reservoir or basket. Return line from the engine is still fed to the stock fuel basket. My AirDog return is in the filler neck away from the draw straw. My straw tip is only the thickness of a single quarter (coin) to the bottom. I've gone several times well below the 1/8 of tank and touched empty a few times without much issues.
  8. Like myself, I'll go back with Hankook Dynapro ATm again. These Hankook Dynapro ATm wore like iron and still going strong with all the round trips to Boise, Idaho.
  9. Sorry, it will squat like an old Ford truck as soon as you hitch up. Very common for level trucks to squat when they tow. Now if you left the front stock with the stock rake then it would be level when hitched. You could overcome the squatting issue with air bags but it will make the ride very harsh with the rear suspension tighten up with air bags. The part I hate is all the level trucks I meet on the highway at night towing are blinding you because the headlights are now too high. Empty you can see my rake... Loaded with 10,000 pounds of hay... Automatic level
  10. Fuse alone is risky. I'm not sure what the max limit of the MOSFET is. So its best to add the relay then put a good 10-15 amp fuse in. The only thing I could think of is get a brand new pump and measure the working load amp draw and make the fuse just maybe 1-2 Amps more. Got to remember as winter comes on the fuel thickens then the amp draw goes up. Even worse if there is frozen water and locks the rotor then the amp draw goes through the roof. Like last winter I seen a FASS 150 blow 20 Amp fuses left and right because of frozen water in the fuel.
  11. This is one reason I love my old school draw straw (without the basket). My return is the filler neck so the foam issue doesn't occur. Never have this issue at all. Still, to this day don't have any quarter tank issues either with a 12 year old AirDog 150.
  12. Got to remember people are quick to complain about a product but rarely do they report good service or products.
  13. Just send him a PM to get his attention to the post.
  14. The man you need to talk to is @Dynamic he is our site transmission guy.
  15. Try trading for a 2001 harness? I know there are a few things different from year to year.
  16. Most likely data crash on the CCD network being the mismatched modules.
  17. That is because stock lift pumps don't have protection relay. So when lockup motor occurs the high current burns the MOSFET in the ECM. As for the WTS light that is caused by high AC noise from the alternator damaging the RAM in the ECM causing boot errors that make it longer to boot as it keeps retry.
  18. Might be true... Sure won't blow out when it freezes either.
  19. Some place in Florida if I remember right. Russian folks?
  20. That's one of the problems with Smarty... It will reach 100% APPS signal at a mere 50% of pedal. There was a discussion about this in the Quadzilla thread. I know @Me78569 can fill you in with exact info about how Smarty just fools the APPS sensor values and makes it steep.
  21. The only place so far I've dealt with is Module Masters in Moscow, ID and they are a state of the art place. They rebuilt my ABS computer gave a good warranty for $130. I'm not sure if they will do a Cummins ECM though. I do know they do ECM's and PCM's for other vehicles. https://modulemaster.com/rebuilds/ https://modulemaster.com/rebuilds/shop/brakes/abs-modules/abs-kh-dodge/ Might try a request... https://modulemaster.com/rebuilds/repair-request/
  22. Here you go... Failed pressure plate.
  23. Might do a voltage drop test of main cable wiring. I've got a feeling you've might have a rotten battery cable that you disturbed and created this issue.
  24. I've got the rockets at 100% and attempting to catch up with you. At this rate I might give up on the 500k milestone and just start thinking of the BIG 1 MILLION...
  25. I'm going to ask the owner to bring the parts back so I can get pictures of it.
