Headlight
Most likely the plug itself is worn out. I would consider replacing the plug before it melts. I've seen this happen a few times where the plug get weak connection and the plug melts to the headlight bulb socket. Then its a royal pain in the rear to get out and also you possibly lose the headlight bulb too.
47re shift solenoid ?
I've got to ask how many miles are on it too? Might be time to just freshen everything up in inside or maybe just a governor pressure solenoid and sensor.
Intake manifold gasket install
I would remove all 6 lines and do it right. Still need to scrape off the old gasket material kind of tough with all the other stuff in the way.
Been skunked...
This is fine but now attempt to get that mixture spray the same way the skunk did from the highway across my bumper, grill, radiator, coolers, front of the engine, etc. Might be a bit fun try to spray baking soda solution through a spray bottle.
Rocks in fuel tank (serious question)
Good bet right there... Being diesel fuel tank typically don't get dirty if you getting good clean fuel without water. After 15 years I know the inside of my fuel tank is still clean. No, I do not use fuel cleaners. No, I do not use biofuels. Petroleum diesel is not dirty if you buying from quality places.
Brake Pads
2001.5 has neither... It's 4 way disc brakes and no load valve.
New: Delo 400 SDE SAE 15W-40
I noticed this same oil down at the local Chevron Station. I was talking to my buddy that runs the shop side and was doing an oil change on a Ford 7.3L Diesel and was shocked to see he carried the oil and was rather clueless of the changes.
Quadzilla Adrenaline V2 Testing
In a way, I wish it was statewide (Idaho) for all the lame punk kids and their truck would have to clean their junk up and quit blowing large clouds of smoke. Down in Boise I run across Ford and Chevy constantly wanting to roll a big cloud on everyone. What's more, fun is whipping then from light to light and not making any smoke at all.
Brake Pads
That was my suggestion being I can pull down so hard through the gear on the exhaust brake to get the rear tire hopping. Nothing like a manual transmission going down through the gear on an exhaust brake and never touching the service brake pedal. You also blocked the other option. 3rd Gen caliper and rotors are supposed to be a good upgrade. So looking for performance pads all I can say is you going to have to hunt till you find something.
Be careful with that... I've got a good contact with Ada County smog testing in Boise ID that I've been talking too. There is one customer that did something similar. He came in with the tuner at 50% and ran the test and passed the test. Then he cranked up the tuner and smoked out the tech. The reported him and denied his future registration of his truck for being a ...
Stolen 1995 Truck
Sorry your truck was not recovered...
Sac or vco
Same here the SAC +75 HP (7x0.0085) flowed like +90 HP because of the pintle mods that have been done. Of course, DAP (Jacob) told me this as well.
5.9 from rigby ID
Field lead is the green and blue wires on the back of the alternator. As for the Quadzilla your wrong... You need to unplug the CANBus, Unplug the wire tap, then unplug and reconnect the MAP sensor back to stock. If you just unplug the big connector you end up with error codes and limp mode.
Re-gearing for the Cummins
Just remember larger wheels and tires will mean less braking performance and shorter brake life span. This will increase wear in the steering and suspension parts on the front axle. That being said I'm a bigger fan of re-gearing the axle than installing larger wheels and tires. Just consider I've got 301k miles now and only 1 set of ball joints, 1 track bar. Still got factory tie rod ends, steering box and power steering pump. I've only done 1 brake pad change back at 185k so I'm good till about 360k miles yet. Smaller and lighter wheels mean less wear on steering parts and better MPG's being I'm still holding 27.2 MPG as a high mark.
5.9 from rigby ID
Might check the AC noise from the alternator. I just did a service call to a local Dodge owner with the same problem and it was a dying Bank's tuner that was killed off by excessive AC noise. This case closely fits what you're saying but I'm not 100% sure your gaps are the same. Try unhooking the Quadzilla and testing again. Then also unplug the field lead and test drive again.
Been skunked...
Got up this morning and the shop smells kind of skunky.
Brakes
I did this to my 3/4" ratchet and bent the handle of the ratchet. Be careful on the amount of force your apply when using a cheater bar.
Been skunked...
Tuesday's run to Boise for @MoparMom I was following another vehicle which slowed down quickly and steered clear of a wandering skunk. I had little choices for avoiding the skunk. So I mashed on the brakes and come to complete stop so I didn't crush the little fella. Sad to say he sprayed the entire front of the truck with his scent. I've learned that the scent is a oil based material and very powerful smell. As for where I was sprayed across the front bumper and grill as well as under the truck in the engine area. Now the purple degreaser works awesome for cleaning that stuff off the chrome and grill just rinses right off with a power washer and the degreaser. I did do some reading that if the spray gets on the paint you might have to repaint the vehicle because the scent/spray will actually penetrate all the way to the metal. https://www.drbeasleys.com/blog/2014/09/05/mystery-behind-skunk-ruined-new-car/
5.9 from rigby ID
4" is plenty... 5" is overkill. I'm still running 3" without a single issue. Mileage tuner... LOL I'm still fighting to figure out the best mileage tune. I do know that IAT temperature is very important to that MPG number. Always doing better on hot days than cold days. Timing plays a roll too but how much and when is the questions I'm still trying to math out. For MPG reasons you want an IAT temperature between 100 and 140*F for optimal running. Cold Air when it falls below 80*F IAT it takes a rather good hit to the numbers.
47re tranny problems
It would be in the output shaft of the transmission. I would follow @Dynamic suggestions on the governor pressure solenoids.
TV cable is easy to set according to the FSM books you just need to make sure they move together. So start with excessive slack in the cable and keep tightening till the cable just starts to move together and should move through a full range of movement with the throttle so if the throttle is WOT the throttle valve on the transmission should be wide open as well.
Popped a P0118 code today
@joecool911 PM sent...
fan clutch
Never heard of that one?... Double stacking seals? Is there enough room to do that safely?
Weather Stripping
Try here... http://www.lmctruck.com/
Also, check the output speed sensor it could create an issue too if it's failing.
