  1. As long as rhe jacket is black yor fine. Blue jacket line typically is petro only.
  2. Yes. B2 diesel scored around 220 HFRR compared to 474 HFRR at 200:1 ratio 2 cycle oil. Lower is better. Only problem is biodiesel is typical high in cetane which makes it lower in BTU content.
  3. Head over the article section and you'll find articles on A/C recharging. Ive been doing it now for about 5 years.
  4. Thank you @dieselautopower for coming over here and handling this thread...
  5. I would avoid the Biodiesel in the winter time. The problem is there is no anti-gel product for biodiesel so when the temperatures get cold enough the bio part will separate from the diesel and sink to the bottom and turn solid. I've been using B5 over in Oregon now for the week which is about 10 cents higher than Idaho petroleum diesel but when you figure paying for 2 cycle oil it just about washes out. Now as for MPG of B5 biodiesel there is no measurable gain I've seen yet using biodiesel. Being I'm traveling a minimum of 250 miles trip to Ontario, OR. Which comes out to 750 miles a week, 3,000 miles a month. So I've got plenty of road time testing biodiesel I've even switched back to Idaho petroleum diesel a few tanks and no real change in MPG's.
  6. Buy the line yourself and replace it. If you had the vacuum pump and the manifold gauge set you could do the rest of the job recharging the system.
  7. Talk to Peter at South Bend Clutch...
  8. Here is my truck and RV on a trip pad scale.
  9. 10:27 MST it's 80*F here as well.
  10. UPDATE: Flashed... Be testing on the way down... UPDATE: I've got the flash done. Quick test drive but weather is not hot yet. Studder seems less but we'll see by the time I reach Ontario at 100+*F weather today. Also the crashing seems to be gone now. I'll see what happens on future start ups.
  11. I know the truth of the Oregon weather being I'm on the east side every other day and seeing 100-110*F temps in the cab of the truck sitting in the shade of a pine tree waiting for @MoparMom . Yeah it's been hot in Ontario, Oregon. Like yesterday it was over 105*F in McCall, Idaho. It was cooler down in Pollock, Idaho where I was doing the clutch job. As for RV A/C I'm trying to get some help from friends in Parma, ID so I've got a place to drag the RV for the eclipse event. The land owner (Gary) is going to rig me up a RV 30 Amp plug for my RV. I know that its going to hot as hell down there. I know my A/C will hold up but the best it can do is about 75-78*F inside on a 100-105*F day. This is only a single unit RV. Not bad...
  12. Personally, I would want to see the company web page, warranty documentation, etc. Then call and interview the company. BEFORE even considering dealing with an EBay page. Way too many times I've seen people stung by BS EBay pages and companies that fly by night. If a company is real and serious they should have their own web page and full disclosure of products, services, etc.
  13. The shop is OK. Too small in my book. The two post lift is in the wrong placement on the floor and the vehicle can't be brought in far enough so you can get out of the truck without squeezing past the door jammed again the lift post. Very poorly setup. Then with the truck on the floor you can barely walk in front of it and no way to way behind it jammed again the door. So it looks impressive but poorly setup. As for the ceramic clutches I'm totally shocked so many people are listening to the wrong hype on the market. "Oh, you gotta buy a ceramic clutch it will not slip one bit." This is true but it sure mills the pressure plate and flywheel down to nothing. Just like I'll never use ceramic brake pads because of the same reason you end up eating the rotors before the pads.
  14. I float around 7,400 to 7,600 depending on cargo and passengers. I hit the scales maybe twice a year.
  15. Here I am again changing another ceramic clutch today. Nice to do it at the owner's house and he's got a two post lift. But the same problem clutch friction material is in good shape but the flywheel and the pressure plate are gone. No hotspots. This clutch barely made 40k miles and was slipping. Owner install just a stock rate clutch and called it good.
  16. I'll do this in the morning and try it for the trip down...
  17. Yes. No. Doesn't matter. I can shut down wait 30 seconds. Start everything up. wait another 30 second touch power level up or down and it crashes the iQuad app. Now the recovery method I found to get back to Default tune is to shut down the crashed app. Quickly fire up the app again go in and change to default tune. Shut down the app again after waiting about 30-60 second for it to bluetooth over. Then when you fire back up it works again. Also noticed that any custom tune the app has serious trouble making connection. Some time its 3-4 try before it hooks up on custom tunes. But if you flip back to DEFAULT then it nearly instantly it pops right up so there is nasty code hanging the app up. Does nothing the tune never shows up in the list. If you repeat with the same name it says the tune already exist but nothing is in the tune list.
  18. Let try to data log again. The last one I email mailed to myself disappeared into thin air. I can't run any custom tune now it will crash the iQuad App. As before the crash problem it did matter what tune you used it was the same problem on any level above ZERO.
  19. Pretty sure ill check.
  20. The whole trick is keeping the fire on the ground and keep a defenseable space around your home.
  21. AirDog 150 and now heading to 12 years old. Still going strong. Power relay and fuse.
  22. No. Mine is near idle range. Ill try and do a video of the display values.
  23. Bigger the injectors the worse it gets. Stock you can't hear it or feel it. The 75HP VCOs now really produce a nasty miss. Checked a few time 0 level is clean but any level above 0 will prosuce the problem.
  24. Ill respond to this in more depth when i get home. You'll be surprised how much you can do with 300 gallons and pencil line.
