Fan Clutch
Weird how some people have bad luck and other have good luck.
VP44 PSG5 limitations read/write
https://www.youtube.com/watch?v=MGaHaIXZioA
Ditch the Edge the sublevel control of smoke is not a good design. At least with the Quadzilla you can set the low boost fuel numbers below stock rate and tune out a majority of the smoke issues.
leaky brake booster
I've got to get my power steering fluid changed very soon before I'm looking down the road of doing this very same thing. So far I'm still all OEM parts on my power steering hydraulics parts. No leaks as of yet but my fluid is darkened and need to be changed.
Fan Clutch
Sorry but there is no way I'm going to pay that for OEM clutch... That's crazy... I'll switch back and buy two Haydens or Four Seasons fan clutches off of Rock Auto.
Because the first instruction after booting up the ECM is to light the WTS light and check IAT temperature and determine if grid heat is needed. If not the WTS light is only a bulb check. If there was bulb problem or wiring issue there would be P0381 error code. Watch you have to watch for is is the WTS light coming on instantly with the key or delaying a bit. The delay is caused from AC noise and the AC voltage managed to damage the ECM RAM so now its having problems booting up.
Fan Clutch
RockAuto even started selling the tough to fine stock engine fan too.
Quadzilla Shudder light throttle
Problem is I feel it on a manual 5 speed transmission too. There is no torque converter clutch to unlock for me. Normally feel it around 25-30 MPH range which most of the small town I travel are 25 MPH city speed limit. Closer I get to Ontario the more you get normal 35 MPH speed limits but traffic hold me down in the 30 MPH bracket and its felt again. @NoMercy Z06 try switching to ZERO level and see if it goes away. If so the whole problem is in the Quadzilla.
Fan Clutch
Ummm... I see 4 aftermarket companies... SKP, Hayden, Four Seasons, GPD...
Tire balance
Umm... Did you?
Tire balance
I'm going to consider doing balance beads, BB's or something this next set of tires I'm sick and tired of having the last 40% of the tires turning like junk scalloping the shoulders and getting out of balance more often. Rather crazy. Are your axles the Dexter EZ lube axles? You might want to look over the instructions on how to do it properly. So far no issues with my BigTex trailer which has Dexter EZ lube hubs.
I'm noticing this issue most so at higher fuel temperatures than at cooler temperatures. When I'm seeing 130 to 140*F of fuel temperature it tends to show up better. Cooler fuel temperatures tend to mask it. I've been playing to find all the variables that seem to make this possible.
Finally Smoke and Heat gone...
Shhh... It way too soon yet. I need to make it till October before seeing cold weather. Typical irrigation shut down date is October 15 because of freezing temperatures.
how to check out a non running 2nd gen
90% of the trucks that are for sale on Craig's List scare me. Most of them driven hard, put away wet and abused. Then once the bill is too high to fix it properly the owner gives up and sells the truck. So now you find an awesome deal on the Internet you better beware it most like got a secret or complete failure.
Seems like a lot of people that unlock secrets on these truck tend to all disappear at some point.
Fan Clutch
Manufacture only have to produce enough parts for warranty periods. You have to remember these engines are over 15 years old no manufacturer will continue building parts that long. So it is all going to be 3rd party reproduction of parts now.
Tire balance
Unless you go Dexter EZ lube axles. Bit of difference where this design allows you to pump all the dirty grease out where pushing grease into the ABS hole is bad idea because you can't push the dirty grease and debris out past the seal of the hub. So no our hubs are not a greaseable design because there is no way to remove the debris or dirty grease.
95 12 valve busted gear case
I say replace the gear case and the pin.
Fan Clutch
Still doing the same thing... 312k miles later... Still working as designed.
Yes more like 20k miles...
The crf450ish random question thread.
As far as I know all Blue Chip VP44 pumps have to be sent out to be placed on the Bosch 815 test stand. Any one can rebuild the mechanical part of the VP44 pump but as for the PSG only shops with Bosch 815 test stand can calibrate the PSG and flash the PSG with the calibration code. The last I knew Blue Chip does not have Bosch 815 test stand.
Wanting 30-50 more HP
Stock is 265/75 R16 typically. The other that is little bigger is the 235/85 R16 (1mm taller but 1.1 inches narrower). Highly suggest a BHAF over any other washable filter. I've seen way too many failed engines and turbos to K&N, S&B, AFe, etc. Just not a good idea to use a washable filter in the back country dust and dirt. Splash problems I've never had an issue with it being I run flood highway, creek crossing, deep snow, etc.
Purchased from DAP and was a Midwest Injection
Maybe for you... Here is my last trip from Ontario, OR at about 9pm in the evening... Here is today from home... Still smoky but always builds up towards evening time...
Mopar73 Full Eclipse Meet and Greet Camp Trip Aug 18th Thru the 21st 2017
I'm not sure how many are actually coming at this point? I know myself, @JAG1 and @IBMobile but that's all...
