THANKS Al!!
Hmmm... Typically the sensor unscrews from the banjo. I've never seen a sensor that replaces the banjo out right. So you should be able to unscrew the sensor and replace it with a 1/8" NPT plug. BANJO BOLT - TAPPED - 12MM
4 Inch Exhaust Needed!!!
@MoparMom is a bit on the deaf side... Might be a good thing she'll know I've gotten home. Also, the louder exhaust will make my presence known to wildlife on the highway. One of the reasons I'm leaning back to the straight pipe exhaust. Typically I'm not a city person so I'm not really worried about the noise outside the truck. Just drone and cab loudness. My old 3" was great straight piped and really got quiet with the 3" NAPA muffler which was nice but then again wildlife became more of an issue. @Taz has a 4" straight pipe exhaust with a 5" tip sounds good on the highway and in the cab, it's not bad at all. Deer and other animal tend to take notice of the sound of the truck more when it got a note that is loud enough.
ALERT - Oregon Gun Law
Need to speak up people are you might lose your ability to carry a fire arm. I'm a open carry person and refuse to let any law enforcement to just take away my fire arm for no reason. http://silenceisconsent.net/oregon-governor-just-signed-gun-confiscation-law-needs-go-viral/
Mopar73 Full Eclipse Meet and Greet Camp Trip Aug 18th Thru the 21st 2017
Back up and running fresh VP44 installed... (Left Daniel - IBMobile, Middle MoparMom, Right Jennifer) During the replacement phase...
Installed 19.5's on the Pimp Truck
Ummm... So which one did you do of both?
2nd Gen CB/HAM Radio Installation. Picture Heavy
Thank you for the wonderful comments... I'll get that post moved over very soon... Done... Now in article form here.
Torque Converter Lock / Unlock Issues
No. Like right now I'm fighting an alternator AC issue but by the time the alternator cools the AC noise drops back to normal levels. Like yesterday I was hauling the RV home and the under hood temps were rather high. The cruise control was making some weird changes coasting in the wrong times then accelerating at other times when it should be coasting. Once the alternator cooled off as I got to Council, ID and there was cooler air the problem disappeared. So no it's not always a constant everyday problem and this is why I highly suggest you do not use any wiring mods or ground relocations because you are capable of sensing the problem early and given plenty of warning of the issue.
@Shainer could I move this over to the article database please?
I know you guys went to the 19.5 for the wear factor. So curious what size are you running of tire and wheels. At the rate I'm going I might jump in this pool at some time. Be cool to see links of products you guy bought too.
Quadzilla iQuad bluetooth issues
I'll double check for that. Seem I started this show with the CANBus plug wired backwards.
Is it a vp44 issue or an injector issue?
I'd be concerned about the valve being bent too. Being the piston had to of hit the valve at the point it was stuck open.
I'm looking at the MBRP exhaust system right now. They have a full line of stainless steel exhaust system from single to duals. With and without mufflers (single).
Well... On my way home tonight my exhaust system started to fall apart. I lost the section between the muffler and the U section over the axle. Time to give up on the old stock pipe and replace it completely. I need a 4 inch exhaust system that comes with a flow through muffler and straight pipe. I'm wanting something that is designed to combat road salt and rusting for a long time. Time to see what you all suggest for the exhaust system. At this point, my truck is parked and I'll be using the 96 Dodge Ram 1500 for the time being till I get the new exhaust or manage to make a turn down for my existing system. So I need to get to work tomorrow on @IBMobile VP44 install.
Updated iquad app still the same
Might get rid off all the versions that are obsolete or not suppose to be used. Would be nice if all versions where in categories. Seems like a long smudge of different versions, years, etc for Dodge. Few for Ford and Chevy.
- Is it a vp44 issue or an injector issue?
I have to ask how in the neck did you mess up a pushed? There is no reason to mess with the valve train to install injectors.- Quadzilla iQuad bluetooth issues
Ok. To clear up the idea of noise I've combined both the OBDLink and iQuad on my LG G5 phone being it can handle two blue devices at once. Still randomly iQuad app refuses to start even if it's the only Bluetooth signal. Still randomly seeing the message of couldn't connect to the device. Eventually enough trying to connect I does finally start and continue to load all 43 items and now display gauges. Then I can fire up the OBDLink app and it connects instantly. Still the iQuad app randomly struggles to hook up on Bluetooth signal.- Hey Dripley
Fake tater... OMG... Really???- Oil change interval question
I look at two things cost of operation and longevity. Being I put down lots of miles and cost of operation is important as is longevity being I want to keep failures at minimum. Being last month I cleared 4,200 miles for the month.- Is it a vp44 issue or an injector issue?
Takes 3 hours to bench test a VP44 pump from start to end on a Bosch 815 test stand. This why the 150 labor rate for bench testing. Ive been using DAP or Vulcan Performance. Both supply Industrial Injection or Midwest Injection (DAP).- White Smoke after injector install
Yeah I know but it creates leaks.- Wheels and Tire Setup
- Going to look at this tonight
Now you nearly doubled the cost of oil changes just in doing oil testing. So consider the balance here you might be able to extend at doubling the cost of the oil change or just stay with standard interval and petroleum oil. Typically it right around 50 to 60 a oil change for my self between NAPA oil filter and what ever oil is on sale. Like my last oil change was 57 out the door with filter. - Is it a vp44 issue or an injector issue?
