Mopar73 Full Eclipse Meet and Greet Camp Trip Aug 18th Thru the 21st 2017
@IBMobile did you get my txt of the invoice and tracking number? @MoparMom has a surgery today and then dialysis tomorrow then we are hitching up and hauling home.
White Smoke after injector install
Did you tighten the injectors first or the crossovers? Crossover first then the injectors is the proper order. Lots of people do it backwards creating a high pressure leak because the crossover tube cant seat right if the injector is already locked in place.
Seat Covers
WalMart and a bit of custom cutting for the seat belt. They hold up quite good.
Strange vp44 wiring issues
Did the donor truck have security features? This might be what is causing the no start.
Hey Dripley
Ive lived in Idaho for 27 years now and never seen field of potatoes. Wheat, corn, mint, onions, rape seed, and many other things.
Oil change interval question
Its nice on CR trucks when you have an hour meter.
At least its being handled and he's got a RV to live out of till parts come.
New Flash!!! IBMobile isn't so Mobile any longer. He is currently stuck in Riggins, ID with a dead VP44 injection pump. I've got a VP44 ordered up for him and going to be heading back up there soon to take care of his downed truck. He's in an RV park and in safe hands for the moment.
Fifth gear nut
One listed above will work.
trreed's upgrade thread
Running 5k bulbs in my Morimoto D2S lights. Slightly on the bluish side not bad. Still can see the reflection off the bottom edge of road signs during the daylight hours.
VP44 PSG5 limitations read/write
TV cable adjustment is part of the issue. When adjusted properly the throttle and transmission shouldstart together, move together and end together. Your sounds like too much slack in the cable so throttle is moving quite a distance before the transmission valve does.
writing my own tunes
MM3 is sold without tunes. Touch comes with canned tunes. Im sure of that.
Hey Dripley
Ill keep huntIng for potatoes... Even though I'm in Idaho...
Is it a vp44 issue or an injector issue?
Stuck in mobile world for now... Thanks.
Could you ask lf you ask if they have a Bosch 815 test stand if anyone happens to stop in. Ill add them to my list of Bosch rebuilders.
Quadzilla iQuad bluetooth issues
It was fully loading any tune after I battled to make Bluetooth connection. After it connects everything works fine.
Hey Dripley
Checked all my plugs. No issue I can see. Still very strange the DEFAULT tune will pop instantly every time. So if it fails just go to default tune. Shut down the app. Fire app back up fires up in under 3 to 5 seconds. Then switch to your custom tune. Lot of extra steps but work every time without fail. Leave it on a custom tune the you fight connecting the Bluetooth. Strange?
Quadzilla Shudder light throttle
As for the shudder / miss. When I got to the Eclipse camp of JAG1 and IBMobile I was able to reproduce the miss really good and it was skipping a cylinder out right. Thenn if I changed to the 0 level it was gone. Right around the 2% level still and about 900 RPM last I checked. This will not reproduce on cold engine or cool fuel temp best to be nice and hot. IAT above 120*F, Fuel Temp above 120*F and Coolant in the 195*F range will show the best. Cooler the temps less you can notice it. As for that day I've been driving for over 350 miles. So the truck was nice and toasty and produced the miss really well. Short trip days like from home to Riggins which is 15 miles is hard to pick it out.
Still did not resolve this issue with the update. Still getting the message could not connect to device then it quits trying. Then you go to the setting tell it to connect again. Again get the message back Can't connect to the deivce within about 15 seconds. I did this loop 6 times till it finally connected on bluetooth and displayed the initialization screen as shown above. So your software changes has done nothing in regards to bluetooth connection failures I'm having.
iQuad freezing with custom tunes
Same here...
Waiting patiently for a copy of the update hoping to resolve some issues...
Very strange to have the light fade away and get dark for just a brief moment and then reverse to getting brighter again. Happen really fast here in Parma, ID.
Hey Dripley
Its quick... Lasted very short time here good view with old welders hood.
Fifth gear nut
Might check the specs on the updated torque king (iirc) shaft and nut. That why I think is higher torque value.
