  1. Even after two updates. The roughness is still there. Easy to detect if you hold the throttle at 1,100 RPM's then while holding the hold steady just go from level 0 to level 2 and you'll feel the engine start to skip and miss. Turn back to zero and the miss/shake is gone. @Me78569 to bad your not going to the eclipse event... You could look this over...
  2. My Azpen A729 Android Tablet does the same thing with the missing needles. As for the crashing make sure you are up to date on the mobile app and the flash on the Quadzilla. Everything should be in the download area.
  3. First off you never test at the battery... Only at the alternator. So the RED probe goes to the BATT stud on the alternator and the black probe goes to the case of the alternator or the negative battery terminal.
  4. KDP Struck again... (Killer Dowel Pin) You need to pull the cam out and replace the entire gear case.
  5. Darn... Thanks for the try though... I was hoping to find some information on the timing yet...
  6. If you have a compression gauge and a starter you should be able to do a compression test o verify cylinder health. Injection and injection pump is a separate story. So while the injectors are out you can have them pop tested. Since there is no VP44 you need to open the gear case remove the gear or install a VP44 before the compression test.
  7. @AH64ID Since you are tuner guru of Smarty what would be the optimal timing for cruising state? (Of course 24v engine)
  8. Let say most of the 5th gear nut problem is depending on the person driving. Like my first NV4500 lasted 260k miles and I broke the mainshaft at the 3rd/4th shift ring. Never had a 5th gear nut issue ever. Now after the rebuild I got the fully splined main shaft so I'm good there. The other thing is most people don't know that the 5th gear nut is torqued to roughly 600 foot pounds. So all these YouTube fools out there beating the nut on with a chisel and hammer is an idiot because they never get the nut torqued properly.
  9. I'm on my second South Bend Clutch. First one lasted 140k miles roughly and had a lot of hard and heavy use towing and skidding trees.
  10. That's not good. Did you install a Timbo's APPS? You need to check for the 5V signal voltage to the APPS. Then check for good signal ground.
  11. Vulcan Performance... I've got a set of his silicone boots and so far holding up good.
  12. I would say the VP44 is shot being the P0216 code is present. Most of the VP44's tend to get stuck in full retard timing and produce excessive white smoke.
  13. With fuel fittings I don't like to use any kind of thread sealants or tapes. To much risk of any sealant getting into the fuel system and be drawn into the VP44 and creating issues. If it makes past that it will for sure get caught in the crossover tubes and restrict flow. I've always used brass fitting which typically are self-sealing just a matter of tightening enough.
  14. I still get that now and then... Now since I flipped that belt over 180* now its stay pretty quiet.
  15. Need to find about $100 DVM that has a 2V AC scale. Then measure from the BATT post on the alternator and the case ground. It should measure less than 0.05 or 50 mV AC. Anything over 0.1 AC Volt is an instant fail. Just because you replaced the alternator does not mean its good. I've seen several brand new alternators come out of the box failing the AC noise test. Matter of fact I was chasing a lopey idle issue and took my alternator to be tested on the bench it was 1.1 AC volts at full load. Comparing the new alternator in the box was 1.7 AC volts at full load. I told the tech never mind I'll keep my alternator. Keep in mind my test is a zero load test vs test stand is a full load this way the fail voltage is way different. Being most people can't get the alternator at full load safely on the vehicle without causing damage.
  16. Dang... Now both @Me78569 and @dripley are both not coming... So that means so far I only know of @JAG1 coming for sure...
  17. The reason why I said this... Because now you tampered with it and if you pull it out and the guy wants to be a pain the tail he can at a drop of a hat say you did something that causes the transmission to fail. Then void the warranty and now you stuck with a failed transmission again that you get to rebuild again. Yeah, it's a pain in the tail to pull it out again but its better off letting the rebuild be responsible for the failures.
  18. Best to get your year of modules. Being there is the different changes there the years.
  19. Had the same problem with my 75HP SACs now im running 75HP VCOs. Seems OK for now.
  20. I would of never done any repairs under warranty i would of sent back the transmission to be rebuilt again as a warranty claim.
  21. I've also done a few of the Hawaii islands. Awesome place to go. Also done a bit a scuba diving off the islands too. Man that was a long time ago back when I was in my 20's.
  22. Still fighting the low end rattle.
  23. Actually, from what I read on the Internet the 5k is the brightest light you can get for the most part. As you go up from there the amount of light is reduced as it changes to blue and violet colors. As you go down past 3k the light turns more yellow and the light is reduced again. So the 4k to 5k realm is about the brightest you can get. The 4k is more to the yellowish side where the 5k is more to the bluish side.
