After Market Batteries - any recommendations ?
Just remember there is only 3 companies producing all the batteries. So name brand is meaningless for the most part. Make sure that it fits the vehicle CCA and size wise. After that make sure it fits your budget and somewhere you capable of dealing with for warranty work. Like myself I got WalMart batteries and can get to Walmart anywhere to replace them. As for doing group 31's it not required so folks believe its a much better set up but the batteries are physically larger than the tray. The extra CCA is pretty minimal. Bare minimum requirement is 750 CCA batteries so anything above that is a bonus. I can say my 820 CCA's are doing just fine in minus weather. There is other things that will make batteries perform better like good solid cables that are not corroded in the center of the copper. Good clean terminals without any lead oxide (black hard coating). I tend to favor lead acid batteries because I can clear 10 years of service with everything from truck/car batteries, to ATV's, motorcycles, and lawn mowers. As long as the battery is topped off with distilled water and charged properly and put away charged then the vehicle will start every morning no problem for better than a decade.
Help....Know just enough to be dangerous and having problems
Agreed... That won't change a thing being the port from the VP44 is very small so increasing the line size does absolutely nothing. Return port is on the left... I did a video long ago and the return flow rate does not improve with pressure. Only once it reaches 14 PSI its fairly steady from that point on.
K&N to BHAF Conversion Question?
Another wonderfully dusted engine caused from K&N filters... I can't answer for the K&N tube and box. But a stock tube and a piece of 4" exhaust pipe inside the neck of the BHAF will give support. I would follow the advise above. As for the tube it might be better to get a old stock tube if need be.
Trump our man?
I know this is kind of indirect but... Like my 3 weeks of working this fires around me I got a good clear look at how Gov't works versus local communities. There is a absolute rift between Gov't and local folks and it never goes away. This is because "Gov't is trained and knowledgeable" for said subject (fire fighting) so local information is meaningless because we have Gov't agencies that take care of everything (weather information, mapping, etc.). But when it all comes down the locals knew more about weather, how to fight the fire, roads and trails, etc. Same holds true for other cities or towns there is too much Gov't involvement in our daily life and Federal Gov't needs to go on a huge diet and budget cut. I mean huge!
Trump our man?
"Not I", said the fly...
Cummins Prices
Might be a time to upgrade the 1996 Dodge Ram to something a bit better...
Low beam on passenger side not working
Blown fuse? Bad bulb? Bad socket? Damaged wires? Headlight grounds is in the cab at the driver side kick panel. Not under the hood.
99 2500 / 15x5 SLM Enclosed LED Running Lights Don't Light Up
Put +12V power to the brown lead and ground the White lead. The trailer running lights should work. If so the circuit on the trailer is good. Now check the socket where the brown wire would be on the truck. There is a Trailer Relay in the PDC and there should be a fuse also for it as well. Make sure the trailer fuse and the relay are functional.
Trump our man?
Our founding fathers didn't work for the government for a pay check they all did it voluntary. No profit made. If our current system went back to that then the voting and out come would be greatly different.
I can give you a clue that Ed (Yankneck696) already has designed a awesome fuel cooler for these trucks that will improve fuel cooling performance. I was suppose to beta test the first series of cooler.... But his Dad died a of a stroke and there was personal issues occurring in the family so he's vanished off the radar for the time being. His design solved a bunch of different issues and had some bonuses too. I wish I could tell more but I can't.
Trump our man?
I tend to agree. The whole government system is broken. No matter who you vote for is corrupt. I think the only cure is the Good Lord's Judgement on man... There isn't anyone in the political system I can trust or would vote for to do his/her job. They all talk big during campaign time and then do the opposite when elected...
Still the problem remain for any external cooler has to make contact with the circuit board. Which it can't. This why the whole thing is based on fuel cooling...
FINALLY! Mr. Procrastination is installing his Mag Hytec Differtential Covers!
I would opt for 80w-90 lubes. Like poor JL_Welding found out the 80w-140 was so thick it wouldn't get out to the bearings fast enough. Even with the differential tipped with a floor jack it took over 30 minutes to even get lube to the end of the axle bearings.
Tepee Fire
Just to let you all know what still going on. I'm still at home but the fire continues to burn. or... http://inciweb.nwcg.gov/photos/IDPAF/2015-08-14-1651-Teepee-Springs/picts/2015_09_03-13.39.56.584-CDT.jpeg
Sidewalk Art Left By a Child
potatoes, potatoes, and more potatoes
Funny Idaho has very little sales of Biodiesel. Oregon is B% minimum.
injector power rating
Vulcan Performance is another good provider of injectors. I got Vulcan +50 HP injectors now.
I can tell you Duramax uses a cooler for fuel supply too and I can tell you the location under the truck is poor. The cooler ends up packed with mud and debris so the cooler is worthless. Also make sure to have a thermostat too because the fuel temp gets too cool it will cause the truck to start up backwards. I've seen several reports of home made coolers on VP44's doing this and having 5 or 6 reverse gear and only 1 forward gear. Fuel temperature also affects timing so excessively cold will over advance the timing so warmer fuel tend to retard. Again this why I don't suggest the coolers and not worried about it. If it does run backwards the engine will be ruined in a short time being there is no oil pressure.
Left turn signal doesn't blink with headlights on
Unknown... You might have to poke around a bit I know its there some where.
Most all potato production is down in the south east corner of the state. The famous potato comment is a bit over blown being that there is more wheat grow that potatoes. There is also rape seed (canola oil), barely, hay (alfalfa hay), etc. As for potatoes I've live here on the west side for 25 years and never seen a potato farm yet.
Now that's potato country but not out here on the west side.
Low pressure/no pressure fuel leak.
That not going to guarantee it to be leak free. As a matter of fact I did exactly that and bought 6 new connector tubes with o-rings. Now number 6 has been slow weeping for a few months. One day I'll deal with it.
They do but mostly in the south part of the state. Most of the west side (where I'm at) is all wheat fields. (Grangeville Idaho)
Cooler will do absolutely nothing As you see there is a air space between the circuit board and the cover and the cover is plastic then the out cover is aluminium. So external coolers don't work at all being you attempt to cool the plastic body and not the circuit that is heated to the temp of the fuel. There is also the possibility the sensor in the pump is bad or off. Like I said there is only be one report of a over heat. I would check with a IR gun. There is more heat in the aluminium body that that plastic cover will do anything about... I still say the PSG is damaged from electrical noise that heat. Which is very possibly how the fuel temp sensor is off because of electrical damage.
As long as the overflow valve is open and fuel pressure is above 14 PSI then your returning to the tank. Then if you keep better than 1/2 tank of fuel then the fuel temperature is typically lower. But temperature related failures tend to alway be pointed at the fuel supply issue which isn't always true. Like most people are shocked to find out a typical summer high temperature is Riggins, ID is 110-115*F like this summer it hit 117*F for one day. So We have the super hot summers here. My injection pump has 201k miles and 9 years old and not had a single problem with extreme heat. I've measure the fuel temp in the tank as high as 140-150*F easy. As for electronic they will withstand huge amounts of heat non-operating. Liked I've left my laptop in the truck on a summer day turned off and it will survive cab temperature no problem. Remove it from the truck and turn it on and allow the fan to cool it down before work with it no problem. Same kind of circuit boards ans solder. Heck the CPU temp of a normal PC can reach well in the 160-180*F under full load. Got to remember the heat soak of the engine can be as high as 190-200*F so I'm sure that used a solder well above the worse heat soak temps. This why I go back to power supply more so. Because if it was temperature related issue we would hear a ton of people losing VP44 in the southern states like Texas and such. Still even in desert states no one is reporting a P0168 codes. From the Cummins Books...
