  1. Klein Bottle Computer http://www.kleinbottlecomputer.com/collections/all-services/products/dodge-1 There is another gent here that found a spot in Florida...
  2. I thought the model number specified the gears... 48RE = 4 Speed, 800 foot pound of torque (flywheel), R ???, Electronic.
  3. I've got no problem but mine was coming in at 2am and pissin' the dog off. Of course you can't see the darn bear at night in the dark.
  4. Man there is days I'm glad I've not updated to the newer diesel with DPF and EGR systems. So are you going to write up your adventures of deleting all this stuff? I'm really curious of what you have to do to get over this problem.
  5. So what exactly is the difference from old school OD OFF and the new tow haul mode?
  6. Disconnect the positives as well. Several devices get connection to ground through the frame so unhooking the negative terminal disables the batteries but doesn't disable all the grounds. Like every thing in the dash is grounded to the driver side kick panel.
  7. I get those critters too.
  8. As far as I've seen most dual disc clutches are more designed for racing than daily driving.
  9. Sorry... I've never had a ECM failure yet in 246k miles.
  10. As far as I know it just drops from 4th to 3rd. For Tow/Haul....
  11. What I know a change of axle. I don't think the axle stubs are the same.
  12. Same for the rear you need caliper and brackets as well.
  13. Sound like a simple fix. It the pistons have gorwn in size with caked on brake fluid. Just remove them and clean the pistons up. As for doing the 3rd Gen brake up grade as far as I know they do fix both front and read axles but you must change tires and wheels.
  14. No double side tape or gluing required. Just tuck it right into the window channel and the glass pinches it into place. It can't be removed with the windows rolled up. You can leave your windows down 1-2 inches and vent the cab all day long. Just lower the windows a little bit and using any vent setting other than MAX A/C will draw air through faster. So like defogging glass turn your DEF on and it will pull more air into the glass. Another is put it on A/C (not MAX A/C) and crack your windows and it will cool the cab off faster.
  15. JAG1 got me WeatherTec for my truck. Then there is Lund Int. is another brand.
  16. More here on Jade Helm http://en.wikipedia.org/wiki/Jade_Helm_15_conspiracy_theory
  17. I'm super curious on how that going to work out with expanding the body and get it all welded back together and paint ready.
  18. Not as bad as you think. If I shot a picture from the driver eye angle there width is no different.
  19. This summer maybe... I want to get a new set of banner sticker going for the windshield but I just need time to finish things. Turn down the Edge Comp naw... As for the gauges I took the challenge of the electric gauges to see if I can keep fuel pressure gauges from blowing senders. So far so good and hold good. I've got a design set up with Eric at Vulcan Performance on the sender brackets. So a solution is in the future. Another feature is the gauges are programmable.
  20. http://news.yahoo.com/thousands-bikers-gather-washington-honor-vets-023451819.html
  21. http://www.stevequayle.com/index.php?s=33&d=1429 At the present time Texas is under attack. The Men and Women of the state of Texas have stood up, and spoke out, against the plans (Jade Helm 15) that the military, police and state representatives have in store for them to take their freedoms. Texas had the courage to speak out, now it’s time for the rest of this nation to back them up. I am requesting all prayer warriors, all individuals under the current 40 day fast and all Christians of this nation to take a knee! Pray to our father, JESUS CHRIST OF NAZARETH, and ask that he and GOD’S Angels intercede now, and push back the manmade storms that are being sent to weaken the state of Texas. Pray this in the name of JESUS CHRIST OF NAZERATH. SealMan……..
  22. Do you have gauges? Boost & Pyrometer? Might give us a clue to whats going on. Thinking there is a KSB sensor on the manifold and a valve on the injection pump that open and closes depending on intake temperature. This will effect the timing advancement of the pump. Possible the sensor isn't working right and sticking the valve closed or open and not giving proper timing? That the thing that so tough about older trucks there is nothing to give clues of what failed because there is no computer to report the issue.
  23. Level 1.. I'm running 5x3 on my Edge Comp while towing my RV or daily driving. The only time I turn it down is to gain control on slick ground be it mud or ice. What I'm running for Gauges... ISSPro EV2's. Pretty nice but also pretty pricey...
  24. Consider... They could rebuild it. http://www.kleinbottlecomputer.com/ http://www.kleinbottlecomputer.com/collections/all-services/products/dodge-1 As for dealer I've been informed the dealer is no longer selling new computers everything is re-manufactured.
