rburks
Everything posted by rburks
  1. well im putting this in a dually...so i will never be doing any off roading....SO WOULD THIS NOT BE A GOOD CHOICE STILL:shrug: --- Update to the previous post... I do have issues trying to get across the Mountain in the Winter though:lmao:
  2. Diff has never felt right...truck had 50K when i bought it...proably 75% ot these miles were pulling a fifth wheel camper clutch kit is gonna cost around 225.00..not to bad...but if i have to replace any gears or bearing's there wont be much difference in buying a new Eaton True Trac DIFF .....620.00 DELIVERED TO DOOR --- Update to the previous post... YEAH.. thats exactly what i dont wont...lots of curvy roads where i live..i have to drive 20 miles to get to a major highway and then its not to straight....i dont wont the front end pushing thru curves..rough on tires
  3. Yeah..but wont that make it drive and trac funny
  4. Well my limited slip Posi trac has just about shot its last Wod...has been week for some time..last winter i noticed i was getting 0 assistance from the other wheel. Comming home THE OTHER NITE FROM WESTERN KY. IT STARTED ACTING WEARD.. IM THINKING OF REPLACING IT WITH A "EATON/DETROIT TRUCE TRAC....IS ANYONE RUNNING ONE OF THESE...NEED MORE INFO:shrug:Richie
  5. Go with MOOG....Thats what i put in mine last year and i am very satisified. improved heavy duty design over OEM....and has grease fittings:thumb1:Richie
  6. Hey Gang, Last week my truck was in an accident, hit in front end and smashing the Radiator & Cold Air charger/Intercooler as well as " Fan, Bumper, Grill, A/C condencer, trans cooler, driver side Headlight and minor damage to fender. WHAT'S THE BEST CAC INTERCOOLER REPLACMENT {insurance is paying}.. Here is some i have been researching [*]BD [*]SPEARCO [*]HTT [*]BANKS
  7. Whats the TORQUE SPEC for the 10mm sinle bolt that holds the rocker on the cradle???
  8. The Prestone Dex cool is orange and it says on the jug Contains ethylene glycol in the warning label
  9. Help!!!1 I drained all the coolant out and sent my wife to get a case of regular "PEAK" or Prestone Green type antifreeze .. When she got back it was almost dark and i almost completely refilled my Radiator before i seen it was "PRESTONE DEX COOL EXTENDED LIFE 50/50 ORANGE GM:doh: IS THIS OK:shrug: Richie
  10. the fitting on the back of the head is on the return side. Imp would not cause this problem. My guess is its sucking air & loosing prime. You really need to know your fuel pressure upon start-up to find the problem...like how long does it take for the pressure to come up when you turn the key over
  11. Yes i agree, assumption is the mother of all screw-up's & i miss-understood your post, thought you already had gauges, they are very the best tool for preventive maint. once you get your fuel pressure gauge in it will most likely tell you what most of us on here already have found out the hard way.. "THE STOCK LIFT PUMPS SUCK":spend:
  12. OK Guy's.."The moment you've all been waiting for" Here is a complete start to finish Details on Converting Standard 2-headlight system to a Sport Quad headlight sys. i did a few months ago Let me tell you it was a P.I.T.A...i had nothing to go on as none of the threads i found on any of the forums involved building your own from scratch "w/Heavy Duty Stuff" ..most of the write ups were people who had bought a pre-wired harness..like the ones for example suvlights.com or others..all reported problems either "fog lights staying on..lights would not turn off, lights would not come on or lights were dim on bright, etc... So not finding any information in relation to a possiable wiring diagram i purchased a "pre-made harness w/relays from LMC..What a piece of shi$$..i mean lets totally forget that it did not work,{ lights went out or "almost out on Dimm}...this was chineese junk a frigg'n fire hazzard. .cheap light gauge wire i could bite into. connectors that "pulled out after unplugged a time or two..and last but not least.."NO SOLDERED CONNECTIONS, ALL CRIMPED AND "NO HEAT SHRINK. See none of these aftermarket harness's will work on these Trucks neither the Chinese "JUNK" nor the other decent harness's...."WHY" you ask... ..Because no one { that i was able to find } has been able or have taken the time to "Crack This system" and build a precise fit "PLUG AND PLAY" HARNESS ". The 2nd GEN Dodges have a ODD wiring system, I Call it {for lack of a better term} Ground Switching System because thats what it does. It switches the ground Neg- instead of the POS+.. The original wiring has a hot wire to Headlight plug that HOT 24/7..all the time. SO..after tryin to get around it..I started designing & building my own system. and with much help from..MICHAEL "MOPAR MAN" i eventually completed my own system.."NOW..Im passing this information on to you guys because the lights on these trucks "SUCK"..and this is an Awesome improvment that....well ..you will have to see for your self.....AND......I DONT WANT NO ONE TO GO THRU WHAT I WENT THRU BUILDING MINE ..L.M.A.O. ***note*** I soldered all my connections & used heat shrink tubing to make a moisture free system. I also harnessed all the wires in split wire loom conduit thanks Michael Check out link below: Slideshow http://s1209.photobucket.com/albums/cc389/rburks1/Dodge%20Sport%20Quad%20Headlight%20Conversion/?albumview=slideshow Pictures http://s1209.photobucket.com/albums/cc389/rburks1/Dodge%20Sport%20Quad%20Headlight%20Conversion/ Below is the Parts list complete with part numbers & prices. except for the fuse holders, I got most all parts from you can find these parts at most auto or electronic's stores and they don't have to be these brands either but i suggest using quality relays w/holders to make replacement easy. COMPLETE PARTS LIST for HD HEADLIGHT HARNESS (sport HL) ***note*** This Parts list is for reference only.. Vendor, Manufacture & Brands are open to your preference 2-male headlight connector (same as bulb)............................................#CP9004CM..............7.49ea. 2- Ceramic female 9004 Connectors #CP9007CFC.............7.49ea 2-Ceramic female 9007 Connectors.......................................................#CP9004CFC.............7.49ea . 4-HELLA SPST Relays, 40A, Dual 87 outs, .............................................#HL87483...............8.00ea. **Option** 4-SPST HELLA Relays, 40AMP, Dual 87 outs, with Diode.............................#HL87753..........13.00ea. NO LONGER AVAILABLE **Option** 4-SPST HELLA Relays, 30AMP, Dual 87 outs, with Diode..............................#HL87453..........8.00ea. Available @ ralleylights.com ****** Note******* It is not mandatory to use the ones with diodes or resistors, it just helps insure safety for stereo sys, CB & The entire electronic system from EF Feedback.. You could use 30amp relays as you are using separate low and high beam circuits. In the beginning i was originally trying to use only 2 Relays, 1 on each side. I found out later this to be "IMPOSSIBLE" . YOU MUST HAVE 4-RELAYS.. You can use ones with single 87 out and wire together,, the Dual 87 out just makes a nice clean wiring system and i hat cobbled up wiring 4-Relay Holders, complete with terminals....................................................#HL87123.................3.77ea. ​I Strongly recommend using Holders, it will make changing a relay out as easy as changing a fuse if you should ever have to I got the fuse holders from Advance Auto....."Bussmann Inline, 12ga. wires............#BP/HUU...................5.49ea. I got the Dodge OEM Sport Headlight assembly's @ http://www.factorymopar.com they are a Dodge dealer with online OEM parts. there prices are way below local Dealership. Sport Headlight Assembly's : price= 233.64.. left side 225.38 ..right side There are Cheeper Options for the The Sport Headlights but be forewarned of the cheap knockoffs and there problems like "leaking", , not very good fitment or alignment, ,poor quality Adjusters that make adjustment difficult or impossible>>> "This is important cause you will have to dial these in and insure the Beam is to the left on LOW BEAM Driver side as to keep from blinding oncoming Cars. "The OEM Lights are pretty close out of the box ".. A salvage yard would probably be a good source if you could find any thats not damaged. **UPDATE PLEASE READ ** I have had several Guys PM me asking why is it that there HB indicator light stays burning even on LB...most of the time this issue is caused by wires being in wrong location on one of the Headlight plugs . A weak GROUND circuit will also cause this, You have to have a solid -GND circuit to the Headlight connectors. I used the spare Side post Terminal's on my OPTMA RED TOP BATTERIES POS+ & GND - post. BUT: There is a Post on front inner fender just below the Battery, there is a Solid 8# wire that runs from there that goes to Neg- post battery terminal on battery so this is as good as going straight to Neg without having a bunch of wires hanging off of your Battery causing mores battery issues in the future.. But first be sure it is solid and clean,, if not solid and free from corrosion then replace it. The other cause would be that you have a wire in the wrong place on the back of one or more H L connectors or in the conversion plug itself. Dodge sport Quad headlight conversion.doc Dodge Sport Quad Headlight Conversion- Relays.doc
  13. Yeah..i installed a complete set of custom 0.84" lines from sheid Diesel...it made the idle roll a little ..other than that no problems...runs fine w/RV275's... reason i changed was needed to replace my old one's..2 or 3 were leaking..these were much less than buying OEM from cummins:spend:...didn't know it would do that to idling though Richie
  14. O.K Guy's...after reading guesswho's thread where he posted an Oil analysis {see below} It got me concerned and i researched the places i have been buying my oil; WalMart & Advance Auto..both carry only DELO 400LE which in the analysis was rated at the bottom The DELO400 MULTIGRADE SAE (API CI-4 Plus) was what was ranked at the top along with Valvoline/Cummins preminum Blue. I have checked on the website's of Advance Auto, SAM'S Club, Autozone,CarQuest,etc.. None of the carry the DELO400 MULTIGRADE SAE (API CI-4 Plus) Has anybody else checked this out???? Richie
  15. WOW! I did not no there were 2-different types of DELO on the market:shrug:..i just changed my oil w/Delo i bought from Advance auto...Its the" LE" version..oh..he$$... what about the Delo at WAL-MART Richie
  16. AROUND 175.00 using DELO and Donaldson or Luberfiner Filters IF YOU DO IT YOURSELF.....TRUCK LUBES OR TRUCKSTOPS USUALLY AROUND 225.00+ ADD+ 25.00 IF YOU CHANGE BOTH FUEL FILTERS Richie
  17. I to run DELO 15W40...have always ran DELO for 15yrs+ even in my Big trucks 3406E CATS with 10% Lucas oil Stablizer..dont see me using anything else.. also have used MOPAR filter from Walmart...no problems..although have only used a couple of time's mostly use Wix and baldwin Richie
  18. Welcome to the site.. I think you are in the wrong section....this is 24-valve powertrain related section Check over in the 12-valve powertrain related section,..i am sure someone over there can help you out... Richie:thumbup2:
