Everything posted by Me78569
OBDLink
Mike, How we know that the header 486 is the ecm and no the pcm?
ABS and Brake lite stuck on
we tend to more DIY stuff to articles once the path has been laid out.
been through that one before I need to read the updates. I am curious to hear about your project. I am assuming the ccd bus protocol is the same in a jeep vs cummins?
I am very interested also.
- Crankcase Vent Mod
Mystery oil leak after vp change
Vacuum leaks will increase crank pressure, thus blowing more oil out of the breather.
Longer cranking...
Fuel temp is read directly from the vp44 on the quad. Fuel returns to the tank via 2 methods, overflow from the injector pop off and through the overflow. The majority of the fuel returned to the tank is from the overflow. Dodge said that "very" little fuel is returned to the tank via the injectors. Fuel can always flow through the vp44 regardless of running state, but at 14psi and above the most possible fuel is flowing through the system
loss of overdrive when ac is turned on
You need to drop the pan, once the pan is dropped it is 6 or 8 bolts, nothing the average joe can't handle.
You can have an oil leak if you don't tighten the vp44 to the case. Otherwise the common puke bottle could be to blame. I would guess the vp44 to gear case is leaking though.
Most amazing mod I've ever made to a 2d gen... a new cupholder.
Give me belly bacon and labatt blue or get hosed eh
Longer cranking...
The quadzilla reads fuel temp. my fuel temp in the vp44 is always ~15-30*f over ambient regardless of how long you drive. the tank acts as a good heat sink.
oh ea it's give me liberty or give me death, I get them mixed up.
Notes from the wilderness!!!
We recently changed their food, as the place we used to get it from went out of business. They laid good on the old stuff, we will keep trying new food until they come around. I am no carrot expert but ours are doing well. I think they like sandy soil, from what I hear. Broody sounds about right, she has turned into a she-itch . I have bigger things to fry now.
Give me coffee or give me death.
Longer cranking...
I noticed 0 improvement when I went with a big line kit. Same pressure drop. The lift pump simply cannot keep up.
just to add insult to injury, I am making some rhubarb spread right now.
I am pulling about 2 pies a week off of it.
On a side note, We harvested our first section of garlic today. Not as big as I would have hoped but not bad either. Rhubarb is growing like it is going out of style. All of our squash is doing great and cucumbers are almost growing too well. Did a lot of weeding today and replanted the next run of lettuce and spinach. Carrots are getting to the point where you can pull one at random for a snack. On a less happy note our chickens seem to be on strike. Egg production is down. We have one chicken that is pretty much staying in the laying box all day....not sure why.
i'll ship them your way mike
sounds like a plan to me.
2002 2nd gen A/C not working.
we created a switch that gets you the mpg mod plus high idle, both 3 cyl and 6 cyl modes.
2nd Gen sway bar delete????
The front bar makes a big difference. I would just fix the bushings and leave it attached.
I am going to try that one out.
so you have 0 lockup? If so check out your boost valve in the valve body, http://www.cumminsforum.com/forum/98-5-02-powertrain/622743-valve-body-parts-tranny-pan-help-i-d.html
Transfer case shifting ....
Cad is the vacuum actuated collar on the front axle that locks the inner shaft to the other. This is needed to engage 4wd. How are your fluid levels? There is a syncing ring in the transfer case. Tear down is easy and we have an article for it.
