dripley
Retired Staff
Everything posted by dripley
  1. Did you drive the truck while connected to the sensor? If not you need to to see if voltage changes. If stays constant the sensor is most likely dead. It could still be a bad wire, thats where code diagnostics come in. While I did encounter the 237 code during my problem it only showed up occasionally.
  2. The 53 block is a big red flag to folks that dont know that all of them do not crack. Yours is most likely safe from what I have read. But it would still make me think.What are you asking for it?
  3. He likes one dollar bills as packing material. I got 10 of them in a t'stat box a long time ago.
  4. Mine runs to the manifold at the cowl but no resevoir that is visible. thats why I asked. I am still finding surprises with the truck so I dont write anything off.
  5. I have to ask, what resevoir? Never seen one on mine. Mine defauts to the defrost very quickly. Never gave it much thought since it seems to have done that for a very long time. Thought it was like that new but 17.5 years is long time to remember back. Also thought it might just be that check valve. Its 17.5 years old too. Does the vacuum pump have a check valve in it to hold vacuum? I don't remember such when I resealed mine.
  6. Proof that the Cummins will pull a house, a small house, but still a house.
  7. Mine have held pretty well. I have about 70k on them and not seeing any abnormal wear on them. I am a bit surprised after reading about them. I expected more wear.
  8. Your description in the first 3 sentences of,the 3rd fit my experience almost exactly. No dead pedal. Mine also did not die, so close to the same thing but not quite.
  9. That confuses me since in your first post you mention power loss. No dead pedal invoved for me either, but I did have blue smoke, not black while it was occuring. What mods have you done to the truck?
  10. When my oe VP gave up it was very much as you describe except it did not try to die. Down on power and I could restart the truck while moving and it come back. No hard restarts either. I am a manual also. Mine would blow blue smoke when this would happen. Never tripped the CEL either, but I also never checked it for codes. The scanner loosing touch with the truck, maybe ECM, dont know. @Me78569 would know that better than I would.
  11. I bought a new weather strip for my drivers door from LMC truck for $50 + shipping. I have yet to install it though. Mine is torn at the sill. I hope it works as good as the tubing did for you.
  12. Actually backing plate would be a better description. It goes on the inside of the door under the door panel. The mirrors need the extra support. Most of the tow mirrors come with them just the description tone sure. You can pull the screw out of the little upper triangular part of the door panel and peak in there and see if the plug for the mirrors is there.
  13. Got mine from 1aauto also. You will need the mounting brackets. If powered you will need the door switch to operate them. The heatepd part needs the hvac control with on/off switch. Both are easy to find. If your is an SLT the wiring should be there, just plug and play. Beware, the ones you link are for a 3rd gen
  14. I think you just summed up our immigration policy.
  15. Thats why I asked him if both instances were in a cruise state. Just was not clear to me if it was.
  16. While I do see the advantage of the 4:10's with the bigger tires. The problem here seems to have really raised its head after the OP messed with his waste gate, though he said waste water typo I suppose, to increase his boost. @Tymatthew are the egts you are seeing increased under the same circumstances as in just cruising. My truck is capable of 33 psi but only with my foot in it hard, empty that is. My egt's will hit 1200+ pretty quick. It does sound as if something you messed with is the culprit.
  17. Congrats. I remeber my passage of 300k. About the same as you on repairs except my ECM croaked too. Good luck to 400k.
  18. I would have agree with both of the above.
  19. Oh, I did. Its the other 150 million folks that just found out they have live off my check too that didn't.
  20. I would start by getting the trouble codes read with a scanner. If you dont have most auto parts stores will do it for you. Then post up what you found.
  21. That would be pretty darn good. Then search for me would be 8th. Cant seem to get it out of my system
  22. If the eastern half of the US is waiting on my pay, we are in deep doo doo.
  23. You nailed on the head there. If I had to use my tools everyday to pay the bills I would spend the money on them. For my use HF or Northern tool and the like is where I shop. Now specialty stuff is a bit different, sometimes you just have to pay the price if you need it.
  24. I have to add this, the 6 speed is really good with load I pull. I gross 23k and hsppy I have it. A good rebuild is going to suck but still dont think I would trade it. They extra is nice to have when you want it. Now just a bit of topic, when I did have a 5 speed I was always going for 6th gear on the interstae. I even still go for 7th gear in my 6 speed occasionally. Any body else have this disease or is it only found in chickens?
