dripley
Retired Staff
Everything posted by dripley
  1. The fifth wheel is at the house for now. Safer there than here I think. Florence has to make her mind up first.
  2. From land fall about 250 miles to home in Hickory. That did not stop Hugo about 23 years ago. Did some damage but nothing structural. Walked around in some 60 mph wind that you could lean over and it would you up. I think the biggest danger up that way is rain. I have never seen any flooding in my neck of the woods. Not being there bothers me more than anything. Now I am about 160 miles from landfall here in SC. Still the storm looks to be slowing a little and turning towards us. We should be fine here but it is going to rain some kind of a lot. But it is mother nature and we will just have to see.
  3. Hard question to answer. Around town I can find myself in 5th at 35 mph. On the highway or in the country all different. Me I just shift when it feels right, no set rpm. Thats all empty by the way. Towing is bit different as in higher rpm, but still nothing set in stone.
  4. Very much appreciated. Florence is big storm. Still some unknowns with it.
  5. Dont take it personal please. A lot of us have had some bad experiences with the dealers. The biggest one I had was the in tank retrofit I got when my OE lift pump died. When the OE VP died I had a tech that talked to me about it alot and answered my question as much as he could. Seems fuel pressure problems I had to learn away from the dealer. It seems if I can learn about these things on the internet that the dealer could learn some also. Of course that means they dont sell the job since they dont do after market. Your insite is welcome here.
  6. What codes are seeing since the CEL is on? The ECM should be controlling the pump. Key on you should experience a short bump of the pump, a second or less. You would probably have to have someone with there ear to the filler neck or under the tank to hear it. Then you can bump the starter, no engine start, and it should run for 20 or so seconds. That is the only time you will have power to the pump unless you are starting the engine or it is running. That is if it is connected to the ECM pigtail.
  7. Me wish me had a back up with the hurricane coming in. Cant get home, fortunately it looks like I will now get the most compared to Hickory NC. I am in Columbia SC. Damn thing looks to be hooking left on us.
  8. IIRC again the AD II's come with the regulator and the regular 150's and below have the spring and ball.
  9. IIRC the pimp I got back in 2014 had a manufacture date of 2012. That might have put me into the bad time. Hopefully yours will be OK.
  10. Thats why i like the adjustable regulator on AD II's. I have only mine 3 or 4 times on bith the pump heads. Its a real shame the the pump doen't work. I was hoping Imgot mine just before the problems but maybe not. And I hoped the second one was after the problems, maybe not again. Maybe the third time will be the charm, who knows.
  11. Been thru that already. Hate to stsrt all over again, but have not ruled it out.
  12. This is my second one. They warranted the first after 4 years or so and now 4 years later it has gone. We will see what they say tomorrow.
  13. Idling in the parki g lot today and I notice 0 FP. So I dig into it and no blown fuse. Plug another relay in and nothing, hot wire the pump nothing. I have power to the pump and the ECM is triggering the relay like it should but the pump is dead. The only thing I did not do is open the cover over the gear rotor to see if something got in there. Even if something was in there the pump is not even trying to run. Any suggestions?
  14. I have heard his has very good products but the wait times for delivery can very long. No personal experience however, just what Inhave read.
  15. Belooking forward to the update. Cant imagine the price. Hopefully no worse than what dealer stuck him for.
  16. I did'nt know you could still by a new one. Thought they were all remans.
  17. That was DDT and we ysed do it too. We called ut yhe fog machine and for as long as we could keep up with it. The changes are coming and just like the buggy whip did not dissappear overnight neither will the IC engine, but its coming.
  18. Been thru the in tank pump so i highly recomend a FP gauge. I personally would not connect it to the test port and i have no idea what a Vulcan line kit is. I do know what a Vulcan Big line kit is. This is mine with the tap for the FP gauge between the VP and the filter canister.
  19. If you have time, take it. Research never hurts on electronics.
  20. Dosed it one time. It was in the overflow bottle when I changed the coolant a month back, a thick brown almost liquid. It did help but still makes wonder. I did a little extra flushing on that change.
  21. Do you mean you are installing a Vulcan big line kit between the filter canister and the VP? I would tap that line for the gauge and leave the test port open, you might need it down the line to connect a mechanical gauge to verify your electric gauge is reading correctly. Are you still running the stock block mounted pump?
  22. And yes my head is weeping near the t stat cover. It does not hit the ground, the heat in the motor evaporates the coolant before it can get there. Repair will be coming soon, just not sure when. I noticed it about 15k ago. I do have Mike beat on some stuff but I think most of it is the luck of the draw. I have had my share. But very few of them seem to happen close to home.
  23. Then 216 is not a good at all. The only time I have seen blue smoke out of mine was when the oe VP crapped out. You could disconnect the the Quad just to rule it out for peace of mind.
  24. dripley replied to Gp12's topic in Introductions
    Welcome, Greg.
