dripley
Retired Staff
Everything posted by dripley
  1. Finally started raining here early Sunday morning. And here about 24 hours later it almost gone. But it still pouring down around Wilmington. That is 5 consecutive days for them and most of the NC coast. The coast got anywhere from 5" to 30" of rain plus the storm surge. Now they got all the rain fall from inland headed their way. We were lucky that storm did not make landfall in the category 3 or 4 range. She went to a tropical pretty quick but lingered every where she went. This thing could have been so much worse. Thankful we got spared but my heart goes at to all that got and are still being flooded out.
  2. Never used a dehumidifier myself. Used electric heaters for the most part of past 10 years. Propane just costs to much. The widows sweat some but not constantly.
  3. I have never used a dehumidifier my self. I never had any problems anywhere in the structure that I can tell. Sure the windows sweat sometimes, like when cooking but it was not constant by any means. I also stopped using the furnace for the most part and used a tower ceramic heater in the bedroom and a larger infrared heater everyone sells for the living room. Both 1500 watt heaters. I dont like drying the air out to much, its just uncomfortable. As far as a hitch, mine is a 20 year old Reese and it is still going strong. bought it with the first 5th wheel.
  4. I dont think so but I guess it is possible if the drain clogged. The fan is not in the low spot like the drain is. It is about 3" higher. I had one loose on mine a few months back and never got any water in the floor.
  5. I was wondering if I read that right. Free shipping though. The add says 1 quart 32 ozs. One down below it says $32 and change for 1 quart. still pretty pricey.
  6. Whats the difference between cap studs and head bolts?
  7. That one came off easy at the top. Almost like clips were not holding. Each one of those red things is felt so it does not rattle. I remember @IBMobile warned to make sure they were there. Some of mine werd red and some were black. Thats got me thinking maybe what i sawas not felt. Maybe he can enlighten us. The dpeefo is easily removed. 2 screws and it just unplugs from the dash and 4 screws for the clear cover. Might have that backwords. It is pretty obvious with the bezel out.
  8. Sounds sbout same, the torch part was throwing me off. No torch used on ours, just heat guns.
  9. My, my. Which one of you remebered to take return line off the head? Out of site out of mind.
  10. There is the confusing part for me is the torch down. I have used asphalt torch down where they take a torch and torch it down. The membrane roofing I am used to is heat welded at the seams with an electric heat gun and no torch. The part that is overlapped is mechanically attached to the roof deck. Same thing???
  11. I have heard it both ways depending on what use. I am pulling my carpet one day to clean it and will put something in for sound deadning. We shall see.
  12. Figured it was the same thing. I have very little experience with rubber roofing. Only used it on couple buildings a long time ago. Did it work for sound deadning? I take yu just layed on the floor pan or did you attach it?
  13. We use membrane roofing that heat welds together and a torch down asphalt roofing. Not familiar with torch down rubber. Can you enlighten me?
  14. Mine acts very much the same way. It used to be a little better on shifting but I had a throw out baering going bad and shortened my slave cylinder rod hoping to take some pressure off of it to get it home and replace it. I have gotten used to it though.
  15. That is a bit different than the one I got 9 years ago butdoes the same thing. My pickup is only 3/8". But it works fine and will drain the tank.
  16. I had to rebuild my module to install my AD. it came with a retrofit kit to remove the in tank pump. Works fine. AD might sell it by itself. Vulcan performance sells a modified basket that appears to be the same as Dodge put it mine for the in tank pump. They may as well have something also. I am also not a fan of drilling holes in the bottom of the tank. As far the fuel pressure, it could be the pump going out. Seems to me others here have experienced that with theirs. I will let them speak to that issue.
  17. The clutch safety switch will require it to be pushed darn near to the floor to start the engine. Thats why i took mine out. The shifting coul be like Mke explains. I wore a boot that went to knee my after tearing my achilles tendon. It completely imobilised my foot and i can see where you coming from. I did not drive much until it healed. Very awkward.
  18. I did not know about the oversizing. I have MOOG in mine from 2011 or 12. Right 200k on them. They are pre federal mogul. I dont believe any of the high dollar lifetime warranty ball joints are made for the 00 to 02. I will probably have to do this one more time to my truck. This just makes it even more fun to choose.
  19. Thats interesting reading especially with all the brands involved.
  20. Still no rain up my way just breezy. This is the slowest moving storm I have ever seen. It has only moved about 50 miles in the 14 hours. @Haggar is seeing more of this than me right now. He is ahout 50 miles south of me. The people on the coast are still getting drowned and 7 people have died, so still a serious storm.
  21. The base of the pump was slightly different. There was a small and very very shallow channel with 2 90* turns. It stands out in picture. Dont know what it is. No fuel leaked. I going to call them find out. You are right about the quiet part, I had to get out of the truck to hear it. But I could not hear the old once engine was running. There is definitely more in the gear rotor head. The motor appears to be the same size.
  22. I am similar to you though i have the AD II 165 purchased in 2009. It only lasted about 125k. AD covered and sent me a new pump head which lasted about the same mileage. I just got new pump today and made it home just fine. Pretty sure the second pump had a manufacture date of 2012 so maybe thats why it did not last. This time they sent me a 4G pump head. As you can see the pump is bigger and was made this year. Hopefully this one will last 250k or more. I installed it this morning at the job. The extra length of the pumped caused me to have to move the mounting bracket back about 1 1/2" to the rear to clear the bed support. No big deal. There are two loose pins used to register the pump onto the base. So i reach up over the base and place one of the pins in the wrong hole. Crap now i either have to remove the base to get it out or, brain in high gear now, get a magnet. I am in the Walmart parking lot and sure enough they have a pencil magnet. Go back to the truck and grab one of the old pins to make sure the magnet is not to big. Would'nt you know it the pins are stainless and not magnetic. So I had to pull base off the truck so I could shake it out. Pins are in the right holes, the pump is on, the truck fired right off, and I made it home. Not sure whats the difference between my old pump and the 4G pump but it worked fine. Right now I have 236k on my VP and it has survived 2 lift pump failures. More about that in another thread.
  23. Try hot wiring the pump and see if it runs. If it does run it just might be the ECM/U. Does your WTS light come on at key on? Look close, in warm weather it is only on for a second or so.
