dripley
Retired Staff
Everything posted by dripley
  1. There is plenty of room in that grommet to grow with. I still have room for whatever.
  2. dripley replied to trreed's topic in Ford
    We would not want you to have drive a tacky van.
  3. Mine have two adjustment screws but mine is not Sport model. Both are accessible from the front.
  4. dripley replied to trreed's topic in Ford
    Black gorilla tape, very sticky and has a more textured look. Really looks good after baking in the sun a few days.
  5. dripley replied to a post in a topic in General Conversations
    Saw that yesterday. The first 12 feet of that bus was just gone. Amazing no more were killed.
  6. At least tell me the humidity is low @Mopar1973Man.
  7. I ran Cummins 180 in mine many years ago and never noticed much difference in how the operated. I need some of the cooler weather you are seeing. Still in the low to mid 90's with 90% humidity out this way.
  8. I ran the thermo couple wire across the cowl and in thru the hole everything else goes in. I ran the tranny temp wire in thru the hump at the gear shift and mounted both of the "whatcha macallits" that send the signals to the gauges under the plastic trim for the shifter. Both my gauges are on the center of the dash at the windshield. I routed from there around the end of the dash and tucked the wiring down in between the dash and wind shield. Pretty convoluted way for the EGT gauge but not bad on the tranny temp. It would have been easier to put a hole in the dash, just cant make myself do that even now that it is near 6 years old.
  9. The 02 does have a gauge. I know the 02 is just a switch. Once the pressure is up to 6 or so pounds it just tells the ecm we have pressure. Then the gauge is run based on ECT and RPM I believe. I know the gauge behaves like it is reading pressure but in all actuality it does not. Learned that here about 7 or so years ago. I think my idiot light is just the gauge dropping to zero and the check gauges light comes on. After further thought the one wire makes sense. Of course I am a member of the electrically challenged club around here. One of these days I might just put a real gauge in.
  10. My 02 has the MAP on its own 5v from the ECM. The wiring diagram for 2002 shows the oil pressure sender/switch on the same supply but its not the case in my spare harness. Matter of fact my oil pressure connector only has one wire going to it. Not sure how that works.
  11. When I added my tranny temp gauge I got a 3 gauge mount for the dash. Sits right in the center against the windshield. I ran the wires to all of them around the dash and along the bottom of the windshield. The dash pad was new and I could not bring myself to drill a hole in it until I knew for sure I would like the gauges there. That was some years ago and I like the location. Still cant bring myself to drill a hole in dash pad though.
  12. That seems to be the norm right now, all clucked up. Half the permits I need and 22 weeks to do a 30 week job.
  13. And ya'll talk about me. Whats the world coming too???
  14. I thought it was pretty obvious my self, but my age still gets me too. Forgot about the gelt pads. Did not get any of those. Think i still have them on the old one. If not i can felt. Mine was actually loosing small pieces driving down the road. I had silicone smeared over all the cracks on the backside holding it together. After a year or so of that if touched it a piece would fall off. It will be nice not looking at the duct tape holding it on any more. I think it might go faster now. 20 hp out of the pedal pads and maybe 10 more now. Whooo who!!!!
  15. This might not be exiting to all but for the past 4+ years a comination of silicone caulk and duct have done one hell of a job holding my dash bezel together and on the dash. Just could never justify the $195 price tag due other things being maintained. I got nice bonus check for job in Maryland and pulled the trigger. My view will be forever changed. Merry belated Christmas Chicken Man.
  16. I have been missing one of mine, passanger side, for years with no damage. But if I had I would reinstall it. Not sure what they do but someone thought we needed them.
  17. Makes me feel better. I think you copied mine.
  18. My wife's first Dokota did that and it turned out the rear end was rotating on the springs. Something had sheared off allowing it to rotate. Did same thing yours is doing. It has been so long ago I dont remember what I had done to fix it, nor had I experienced that before or since. I noticed a weird noise and got her to put it in gear and the whole rear end rotated about an 1/8 of turn. It was weird.
  19. Fore!!!! Whatch out you guys that ball is going to Idaho or Iowa. Forgot to check the zip code before I hit it.
  20. The return, while still a bit tough to work with due to locatio, is the easiest to check in my opinion. But all the items @Mopar1973Man mentions can be culprits also. My return tee sprung a leak many years back and it is not a leak you really see unless you go looking for it. Mine was weeping fuel and not really leaving evidence on the ground. There is also a banjo bolt on the back of the for return fuel that you cannot see. The sealing washer rubber gets very hard with time
  21. Thats the beauty of this place. Everyone is learning from someone all the time. Some, ahem, more than others.
  22. Mine has the little play like yours in in the vid and is gone with engine on. Engine off my pedal travels like yours but maybe not quite as far. The only thing holding the pedal up is the rod from the hydroboost must be a little play in there that shows up without hydraulic pressure maybe???
  23. How is your starter? If it is weak it wont spin the motor as fast. A leaky return line or any small leak letting air in can cause it also. It will drain fuel back to the tank.
  24. dripley replied to Rogan's topic in Introductions
    Welcome back.
  25. Welcome.
