Everything posted by dripley
Need Help Asap With Airdog
From what I have read it sounds like the pump is gone. You could remove the motor and see if it is full of diesel. Heard of a lot of seal failures. How old is the pump? Did Josh hang up on you at 4pm or did yall disconnect voluntarily? I keep hearing about both good and bad customer service from them and they do have some bad pumps out there. I have had mine for near 3 years with no issues, so I have not had to deal with them on any issues.
Bhaf For Mpg
I never saw any increase in mpg with the large one or the small one. They do flow good and last a long time.
60K And Lots Of Issues All Of A Sudden!
My first truck was a 68 Chevy with 3 on the tree. Cost me $600.
VP or something else??
The fuel system does not hold any pressure. When you turn the engine off all pressure is lost. If you have an air leak somewhere it will allow the fuel to drain back to the tank. That is most likely your issue. If you can park the truck with the nose down and see if the problem persists. Also the next time you have the hard start, just let your fuel pump cycle instead of staying on the starter. Try that once or twice and see if it helps. Both are sure signs of air getting into the fuel system.
Cool Runnings
Even when mine was new it was hard to warm up in cold weather. I have sat at lights and watched t drop 20* rather quick in really cold weather. On short trips to work in the morning(10 miles of less)with stop and go driving I would never see 190*. The only way I found to get up to temp was to drive on the highway and eliminate the stop and go. This was without winter fronts and below freezing. It is not uncommon to see this.
Thats possible. Just remember that if that fuse blows and the pump quits running, the VP is pulling fuel on its own. That is not good for the VP at all. The VP is a $1000 part. Carry some spare fuses and if it does go again park until you can fix it properly.
Yes,it is to the right and not the left. The power for the pump can also come from the alternator. It was an alternate source of power listed in the instructions. That is how I connected mine.
Kinda Neat
I have liked my 6 speed since day one and 6th gear always just felt like another gear to me, though I try to run it at no more than 50% throttle with the 5th wheel on(15k #). The only experience I have with the 5 speed was on my 96 with the V10. It would only pull my other 5th wheel(12k #)on dead flat ground in 5th and I hardly ever used it while towing. Not sure that s a fair comparison. 5th on the gasser always felt like an OD, where as on the Cummins 6th just feels like another gear to me.
If the AD was wired with the supplied harness and by the instructions, the relay and the fuse sill mounted on the firewall on the driver side. You can see them both to the left of the clutch reservoir. The fuse is on the left and the relay on the right. If it is wired per the instructions to the original harness for the OE pump, there will be no power to the pump unless you turn the key on and bump the starter(no engine start) and then for only about 25 seconds. You can pull the harness from the pump and check for 12v there, but only after bumping the starter. Might need a helper unless you are quick . The only time you have constant 12v at the pump is when the engine is running.
Front/rear Axle Lube
There is a allowable amount of play. Mine has it and I dont notice that it is any different than when it was new. That was 12 years ago however. I am sure someone will tell us what is normal.
I cant speak for or against synthetic, but when you open it up, its all going to drain other than what sticks to the gears. Make sure you have a good size drain pan in case the cover pops off quickly.
Programmers - Tuners?
I had to remove my Banks tuner, but still have the Banks exhaust housing and waste gate. The waste gate opens around 35 PSI. So when I get on it and the boost reaches about 22 PSI the engine defuels and sets an overboost code. I can keep it fueling if I keep the boost to around 20 PSI but that limits me to only about 70% throttle until I get the RPM up,
let me know how that one works out for you.
I believe you are correct. Great Stuff is spray foam insulation.
Will the Smarty do boost fooling.
I used RTV sealant, I think Great Stuff. The darn stuff was so sticky when I placed the cover in position it stayed there when I had to let go of it momentarily. It actually dd not move for about 45 seconds, just got tired of waiting for to move. Mike tells me the stuff I used will be a PTA to remove when I change it again, I guess time will tell. Any good sealant should do the job though. Be sure and clean the old sealant off completely. A razor blade and a scotch brite work very well.
High Mileage Badges
I just crossed 299,500 coming back from Louisiana. Might have to look into the 300k. Headed back out on Sunday the 19th for Alabama with the 5'r in tow and should cross it then.
2 cycle oil
I ran Diesel Kleen for about 4 months several years ago and never noticed it did anything for me. I dont really see cold enough temps to run it for anti gelling. Supertech TC-W3 from wally world is very popular and I did notice a differnce with it. Just came off a 1650 mile round trip running 75 to 80 mph and a consistent 18.5 Mph. As far as the filters, it has never affected the filters adversely. I currently have 40k on the AD filter with no pressure drop from it. My filter in the factory canister probably has 60k or more on it.
I have used the 80w90 GL-5 in both the front and the rear for about 40k miles now with no ill effects. Mine is a LS and I added the friction modifier to mine. The oil did not come with it.
New-To-Me Truck
I believe Mike meant mechanical's do NOT rely on electronics.
Long cranking!!
Your VP truck does not have a fuel shut off solenoid. The 12 valve truck do. Earlier you stated the truck would auto accelerate. Does it go to red line or just rev up and down on its own?
A Great Way To Gardening...
potato's not wheat
Newbie With Puking Brake Fluid
Well if all calipers are leaking, that would be unusual. Since you just bought it, maybe they were all leaking prior to buying it.?
Start Run 10 15 Seconds Then Die
I was wondering about this. The whole time I have owned my truck have never noticed going any where that had a #1 and #2 pump. All I ever remember seeing is the #2 pumps. I have been in a few places where the temps would get down to the low teens to 0, but not a steady diet of this. The first 8 years of ownership was spent up and down the east coast. Gets a little colder up in the NE, but I never went beyond NJ. I am just gong to have to assume the very few times I was in very cold locations the fuel was winterized and I just dd not know it. I was pretty naive about all this stuff until I found this group and am grateful to be here. Now I will be worried about it any time I am in the colder areas. I will sorely miss the "Ignorance is bliss" that I have gotten away with for so long.
Harvard Talent Show
I'm not sure whats more impressive, his guitar or your log. Yours looks to have been more painful, his is more entertaining.
