trreed
Everything posted by trreed
  1. @Mopar1973Man I’ve got him considering compounds already.
  2. It’s level 1.
  3. You guys are gonna make me spend money on leather seats....... I’m waiting to get both vehicles tinted as it is!
  4. He's waiting for the compounds to roast the tires.....
  5. I'll have some 7x0.0095's for sale here soon!
  6. And then all the little ones in the head if you're feeling extra adventurous. Did the machine shop redo those ones?
  7. I've seen it where the buttefly valve in there is either closed or partially closed, and causes this exact scenario. But that map sensor code could point to a false reading and that's messing with the fueling table.
  8. They really do. Thankfully the place I got them from has a lifetime warranty too.
  9. @Raffron do you have an exhaust brake?
  10. He's considering a 62/68/12. Heavier components to spin. @Marcus2000monster I think DAP sells the pipes. Not sure if that includes turbo or not. Bet you could make it close if you found a deal on a used one.
  11. I agree with Dave. Might try a billet bolt-in one if that's the case.
  12. HX35 rebuild kit is $60 from DAP and an hour of your time. (Once the turbo is off the truck) HE351CW swap is about $400. Less if you can fabricate your own pipes. SX-E would be drop in WITH a HX40 downpipe. Also would be laggy with just 75 HP injectors and no tuner.
  13. Heater hose will break down under oil. It'll get gummy and the ends will collapse. Best to run some oil rated hose, like turbo drain hose. Expensive stuff tho.
  14. Aww my day-time ghost stories aren't working???? It's only ever happened after nightfall. During the daytime I've never had an issue. And it gets kinda chilly when you roll by it.... I'm not overly superstitious, but there are a handful of things I've experienced that I can't explain.
  15. Ignition on is what did it. Usually if I do something like that, the light goes off by itself after 4 driving cycles. Good plan on the relearn tho.
  16. Considering most of these graves are mid 1800's gold rush miners...... If they had Fords back then I'd be impressed!
  17. I don't 'need' a truck either, but I choose to keep it around. It's my hobby. Nothing is permanent.
  18. @BBHD, yes! Bald Mountain Lane. Just west of Nevadaville.
  19. @SilverMoose they came from 1AAuto. The actual product looked slightly different than the website, which annoyed me. Hopefully I don't have any issues with bad LEDs. I'd love to hear your findings
  20. If the gasket was not painted and black in color, it's a good possibility it was the OEM gasket. Would also recommend a replacement.
  21. Well that’s cause they’re from a 4th gen
  22. I still think my plain Jane projectors look goofy. That’s why I’m trying something new to add something to the housings
