Yeah I can't speak for the new 4th generation pumps. I know the raptors are junk I've got one at the house that ate the pump shaft with just the rubber seal. Weird?! I'm not fond of the adjustable fuel pressure regulator. I like the old spring and check ball they work the best. I know @Me78569 has a Pureflow pump that has zero issues. Might ask Me78569 about his...
I have a pureflow pump from the patent owner of the airdog stuff.  Different companies now.  I am not sure if airdog ended up using the pureflow design or not, but my pump is good.
I would however recommend FASS still given the run around I got from Airdog back in the day.
I have an AD II 165 for 7 years of so. I did loose the pump about 2 maybe 2.5 years ago and the sent me another no questions asked, Mine also has the adjustable pressure regulator and works fine. Had to reset a couple times when new and after replacing the pump. No other issues with it. Might go different if this one does not last we will see.
20 minutes ago, Hawkez said:
There is always the mechanical option. I have the fuel boss and it has been problem-free since the day I installed it.
Same here, 16-17psi at idle, dips a for quick second under acceleration, then 17-18 with some rpms.
1 hour ago, jlbayes said:
Why people buy these unreliable over priced pumps is beyond me. There are many many options available to put together your own systems if you are willing to spend the time.
jlbayes ...Options are limited aren't they? FASS or AIrdog, or mechanical with fuel boss?
The mechanical pump looks like a good idea. But either case I need to replace the lift pump. They use the lift pump on start up right CTcummins24valve and Hawkez?
Come to think of it, I have a warranty on the raptor, if I buy the mechanical set up the raptor would be used for only a few seconds for start up.    Still is guna be at keast 600 dollars whatever way I go. Do the belt driven ones have a return line also?
You can, with a hobbs switch. Hobbs switch only powers on when fuel pressure dips below a certain psi. Right now I have the carter pump disconnected, just running the fuel boss. Only connect the stock carter pump for filling the fuel filter housing during a filter change for me.
Yes, it does.  The fuel pressure regulator is in that line and they have it returning the fuel by way of a t-fitting in the filler neck hose.
I run the fuel boss the same way.  An electric fuel pump is installed but the fuse is pulled for power to terminal 30 of the relay.  This keeps relay triggering power flowing from the ECM to relay terminal 86, the electric fuel pump doesn't run and no fault code p o230, or p0232 is set.
8 hours ago, Alexio Auditore said:
Are there anythings to be worried about going the mechanical way? How long have some of you been running mechanical? Any issues?
I have had no issues with my fuel boss.  I have my stock lift pump still hooked up and it is only used to prime the system.  I do carry a spare belt under the back seat.  When I bought mine, Richard at GDP said he has 100K+ miles on a belt.  I've never heard of one failing, but I assume there are stories out there. My pressure is solid at 17PSI. It doesn't go up or down much at all from that.
