Recommendations for towing mirrors
- Replies 18
- Views 9.1k
notlimah 4 posts
dripley 2 posts
Sycostang67 2 posts
IBMobile 1 post
I'd love to have a set of those mirror but never have the extra cash to go out and buy the heated and electric mirror set up. No I will not do just manuals that is lame I've seen several truck like th
There is a bracket used on the inside of the door to support the bigger mirror. You could remove the screw holding the door panel on right where the mirror is and kook behind it to see if they are the
(Not to much showed up in search)
Trying to find some towing mirrors that don't wiggle in the wind, stay put and have good field of view. Any recommendations?
Looking at Amazon and other places. Hard to figure out what is best looking on-line. If you have aftermarket towing mirrors and happy with them....What type do you have?
I've been using the type that slide over existing mirror, works OK, but field of vision is not very good. Going to be putting in new window motors, might as well add towing mirrors at same time.
Thanks
Edited by 015point9
