Hullo!
Welcome to the family Nuke. I'm sure there are a few people around here to give you a hand with the steering gear box. As for rolling coal everyone wants to roll a little bit of smoke now and then if you didn't you wouldn't be human. But seriously we all have to keep than in check too. So enjoy the site and the other family members.
So... I have a bit of a project..
Looking at the pictures of your roof in the other photos and these I would say you roof is getting rather wore out and won't last too much longer. There is a roof coating you could treat the roof again with to extend the life of the rubber. I'm going to be getting some this summer and re-doing mine to keep the roof as long as possible. I've only had one leak in the corner of the slide (Eternabond tape lifted) so it weeped into the corner and the wall has a nice patch of wavy wallpaper now. Only about 3x4 inches. Now all you got to do is reassemble the interior right?
Consider when to travel dirt road short cuts...
Paid $8 bucks to get the truck wash in Lewiston all hand washed and then rinsed and blow dried. Still got filthy coming back home in rain and snow showers. Hence even this morning there is snow on the ground just above us. (Ugh!)
A rant about Verizon...
Firefox here too... Ad Block Plus No Script Better Privacy Click & Clean Works like magic no spam emails, no ad banners form places I've been, no popup windows, no tracking from Youtube and clean the browser up with one click. I love visiting CF without logging in to the site because even then the site is completely stripped of all ads and popups. CF.com http://www.webpagetest.org/result/140428_87_NE7/ M73M.com http://www.webpagetest.org/result/140428_DN_NK3/ I always work to provide the best User Experience...
Good ol' Potlatch paper mill. Ya it stinks but believe it or not we must of had the wind in own favor. Most of the time we were there it really didn't smell to bad. http://www.spokesman.com/blogs/hbo/2012/jan/10/duroc-its-too-bad-lewiston-smells/
Exhaust Brake
PacBrake has a lockup controller you might check in on it.
You should of seen the looks I got from all the RV'ers in Hell's Gate RV park. Fancy diesel pushers and 5th wheel trailers and here I pull in with a muddy RV and pickup. Oh boy! I was a good conversation piece in that campground. I kind of screwed up and parked in the wrong spot #39 and started rinsing off some of the mud and then some one pulls up and says "I think your in the wrong spot." sure enough I looked again at the receipt I was suppose to be in #49... http://www.reserveamerica.com/camping/hells-gate-state-park/r/campgroundDetails.do?contractCode=ID&parkId=311023#sr
Myself Turns 50 Today!?
50??? That's all??? Congrads to you DW... Cyber party? Hmmm... So what do we do FAX you a beer or shot of whiskey?
Tap it or leave it?
DAP sells pumps with a wire tap warranty now. http://www.dieselautopower.com/product-p/sovp44-wiretap.htm
Yeah gang... I ran away with the RV once again. This trip I learn a lesson. Consider you short cuts and road conditions wisely. MoparMom and I ran out toward Lewiston, ID for a two day getaway. But on my way to Lewiston I normally always take Tolo Lake cut off and sneak across a few miles of dirt roads to save a bit of time. Well this time the roads where wet and possibly freshly graded. I look in the mirrors and could see mud being slung as high as the roof. I couldn't resist I had to grab the camera and shot some pictures.
The logic in this...
Yeah I know very well... (Results are roughly speaking) http://www.stealth316.com/2-turbotemp.htm
Jet Boat Weekend on the Salmon River
Here is the turbine boat video clip. untitled.mp4 Doing a bit of attachment testing too with this post.
My Oldest Turns 16 Today!
Awesome photo period! Congrads!
This is why most daily drivers I talk to see little to no difference in upgrading exhaust. There was a person a while back that dyno'ed 3" and then upgrade to 4" and dyno'ed again and no difference was noticed. Now the ultimate way of fixing the exhaust issues is talk to TH Racing here on the site he's got a Cummins header.
Dexter EZ-Flex Installed
Both my trailers (BigTex 70TV and Jayco Eagle) are standard leaf spring packs tandem axles. I tend to favor the leaf spring suspension over torsion axles. But that's just me.
Hey, AH64ID. How much did those Dexter EZ-Flex cost you and where did you purchase them at?
Need to identify cause of power steering/brake loss...
I would double check the fluid level and being you did put in a vacuum pump rebuild did you double check to line up the coupler between the vacuum pump and the power steering pump?
Possible lift pump fix teaser
I'm not exactly fond of the pump design with sliding vanes which is the exactly the same design of the stock Carter and Holley pumps.
Awesome so far I figured your going to replace the entire roof. I wonder how the Eternalbond tape will hold up to the test of time and weather. Still doing a awesome job for repairs...
Impressive... 200GPH http://fuelab.com/products/diesel/velocity-200-gph-airfuel-separator/velcoity-200-gph-airfuel-seperator-dodge/item/30303/ 100 GPH http://fuelab.com/products/diesel/velocity-100-gph-system/velocity-100-gph-system-dodge/item/30301/
So why isn't people increasing the size of all the intake piping and intercooler? (Just to make people think a bit).
Replace Fan Hub Bearing
No joke. That's why I stay after the washing of the truck because I hate to have to use a putty knife to find all the bolts like I do on customers rigs. Not to mention it does reduce failures of parts because of less contact with grit from dust and oil build-up.
fuel lubricity study 2007
More of that here... http://articles.mopar1973man.com/general-cummins/36-fuel-system/68-hfrr-testing-of-common-diesel-fuel-additives
Dead Petal - P0216 issues
Fuel pressure is too low and should be kept between 14-20 PSI at all times for optimal health of the VP44. But you have a seized timing piston and most likely nothing can be done about it now (P0216). The other cause for this is lack of fuel lubricity and not meeting Bosch's requirement of <450 HFRR where most today's fuel is ~520 HFRR. The dead pedal is a sign of a bad alternator and AC noise causing shifting issues with the torque converter. So I would have the alternator tested for AC noise and also scan for any error codes to give more clues.
Good point! I forgot to consider that myself.
