MPG fooler - Design phase
We as for the performance / economy its a give and take relationship... Economy (Hi MPG) <---------------------> Performance (Hi HP/TQ) As for the IAT temp that is a smog/emissions control so no one in the corporate field will even go here because all in all I'm sure it will turn noses up in CARB/EPA testing areas. But I look at it this way if I'm saving fuel I can't be producing that much more emissions. Kind of like the out of the box thinking of 2 cycle oil in diesel fuel... Still to this day corporate American will not acknowledge the 2 cycle oil but in the private sector like yourselves everyone is at least trying it and more like the results.
Engine Rewiring
Floating ground... It a separate ground system from the actual ground of the body.
Modifying stock horns
Your going to laugh... The air horns on my truck are over 20 years old and cheap Pep Boys air horns like $29 bucks. Then I wired the horns into the stock horns by picking out the rubber seal on the stock wire carefully and slid it back a bit then tucked the new horn wire right along side the factory wires. The end of the wires are just stripped and push into the sockets and the rubber seal pressed in place... Serious...
High Beam
Stodg hit it... I read the post and found this tidbit... http://www.candlepowerinc.com/pdfs/9004_9007.pdf
I've got a set of cheap air horns tucked behind the front bumper... I did that a long time ago... I have no idea if my stock horns work or not but I sure hear the air horns good...
Grrrrr New paint job vs Shopping cart
Well that suxs... Hopefully you get something from Harbor Frieght... I'm glad my truck is going on 10 years old and has its rash of scratches and dings... I remember the day I bought the truck brand new... Fresh paint job and worried constantly about getting scratches and dents... Sure pretty all painted up but hell of a time worrying about the paint, parking lots, door dings, shopping carts...
Greatings from Montana
Welcome to the family... As for the Smarty I wish I had one I would mail it to you and let you borrow it. But I don't, so I can... Hang loose you never know if someone might own one pop in and be able to help out...
Low Fuel Pressure Warning?
I'll say it nice way of getting your attention on the gauge when there is a bright LED winking in your face...
2 Stroke and the Common Rail
Keep reporting back your results...
Actually better at Edge Comp on 5x5... http-~~-//www.youtube.com/watch?v=xDvurlwOYsU
Smarty or a trip to the dealer would do it... As for a design template for the MPG fooler Yes... But remember you need the IAT plugs and the 2K resistor in place of the other parts shown. Yes. Prowelder is the site's manufacture of the high idle kits... Currently in debug phase for the MPG/High ilde kits.. Well the high idle designs are here... http://mopar.mopar1973man.com/cummins/2ndgen24v/high-idle/high-idle.htm The MPG fooler design are here in the thread... I'm already feeling the pinch here at $4.319 and going up yet...
Injector Virgin
Download both files?
2005 I Think
Well the limp mode should have a error code with it. I would start there and see what is going wrong...
Basically build a ECT fooler but using IAT plugs and then replace the resistor with the 2K ohm. Really simple.
Apps acting funny!!!
Just a nice molded plastic part to hold the terminals in place. That all I know of...
Sounds good in my book... as long as the field wires are hooked up and the positive cable runs back to the fuse box its all good...
Injector Virgin
Here try this one... http://forum.mopar1973man.com/downloads.php?do=file&id=182
AirDog Filters Cross over?
As far as my AD 150 there is no crossover... Either fleetgaurd or AirDog filter that's it...
Engine Rewiring
D'Oh! I could of told you that one about the grounds... Dang... So close but so far away... The sensor base there grounds on PCM grounds not body gorund. Same with ECM on the 24V truck they base off the ECM ground not body ground. This is why its so critical for grounds to the PCM/ECM be in good condition because the internal ground that the ECM/PCM create are based off them.
Failed emissions :(
Canada... Well thing is there is a lot you can do to increase the power of that truck but remember your going to have to learn how to do it so when its time to smog it again you can reset everything back again. But before you get into making power mods I would get a set of gauges first. Then if you want two knowledgable people talk to MnTom and ISX they are both 12V owners that can point oyu in the rigt direction...
Two issues with truck 6.7
Well check for the error codes and report back the codes... Rattle noise could be the CP3 pump. There is a long article somewhere on the internat about the CP3 gear index might land in a spot where the pump comes over the pressure point flings against the cam gear causing the rattle noise. I heard if you just re-index the gear in a new position it will resolve the issue. But if Wild & Free shows up he'll be able to verify this information a bit better...
coolant smell
Well its not to bad to do a heater core here is a write up of it... http://mopar.mopar1973man.com/cummins/2ndgen24v/hvac/evaporator/evaporator.htm
65v70mph worth it
First you got to have traffic to imped there none here in Idaho... Seriously drive with common sense... Don't be a jerk about getting out of the way. If there is a pasing lane stay to the right and allow traffic to pass. If you have to slow down to allow the traffic to pass you. Fuel distance for 35 Gallons 27 MPG = 945 Miles 26 MPG = 910 Miles 25 MPG = 875 Miles 24 MPG = 840 Miles 23 MPG = 805 Miles 22 MPG = 770 Miles 21 MPG = 735 Miles 20 MPG = 700 Miles 19 MPG = 665 Miles 18 MPG = 630 Miles 17 MPG = 595 Miles 16 MPG = 560 Miles 15 MPG = 525 Miles 14 MPG = 490 Miles 13 MPG = 455 Miles 12 MPG = 420 Miles 11 MPG = 385 Miles 10 MPG = 350 Miles 9 MPG = 315 Miles Dark green is my typical economy driving. Light green is following speed limit. Red is trailer towing (7K to 8K).
codes....Help
Well I would try reseting the codes with another tool just to be sure and then take for a short drive and check the codes again. If the codes remain gone (Good your done). If they return then you got a broken wire or corroded connection somewhere. More on the CCD Network. http://mopar.mopar1973man.com/cummins/general/ccd/ccd.htm
codes....Help
Well the P1694 states there is no communication between the ECM and PCM and that the CCD network is possibly damaged.
