  1. My comments are in blue... (Continue..) That truely is a shame when you pride and ego is that large that you can't admit you don't know everything. But is the same sense there is some many voice screaming in a forum of that size how do you know which voice to listen too?? Well rule of thumb I found out is that post number does count as a type of experience counter for newbie that join. They see some one with 4-6K of post and they will tend to believe him if the answers are rational. Like today I'm still getting PM notices from CF.com about old threads that people find of my 11,000+ post I put in. So look as a total newbie stand point toward CF.com... Sure it look like a huge storehouse of information... But after wading though all the BS and trying to find a answer you usually either get mis-lead by a showoff or get the answer by PM'ing a user with high post count. So Now that we are looking forward away from the chaos of the larger forums let turn this around now to making this site more a internet family site of each member helping each other. Lets put our heads together and start drawing up how we all want to see this site... I want to build more write ups but if you got information you want to share on the static side (mopar.mopar1973man.com) let me know and I'll post it up. I would also like to design the site rules to make it fair for all but also have some proper guidelines to control the spammers and un-rulely people. Thing is I see most big site gone commerial (Like CF.Com and DTR.com) were its all about advertising and corp sponsors.... I want this site to stay a family site that is governed by the members within reason... I'm going to stop here and listen for more responses...
  2. Well... In all relaity this thread should be closed but there is only 1 reason that I stop from closing it... That reason is while I listen (read) the thread I'm hearing the problem that other sites have had... Then it remind me not to become like this... I want to rise above the crowd and give you all a community that you can enjoy...
  3. I've had enough problem from over at both sites... (CF.Com and DTR.com) So After my few tidbit of problems I went to my site and startyed working at making it better... As for the members here I'm seen several comments about the site being great because there is good level of respect between members here. (Thank you all!)
  4. Looking at the failures of the common rail system which happens to be the injectors most cause by honing from debris that passes through a small orifice inside that cause the it not to seat properly later in life. But still in all I've seen prices ranging from $300 and up per injector for CR truck for a total of $1,800 for a set of re-man stock injectors. Then looking at the VP44 which happens to be the failing point of the 24V Cummins. with the failure of a VP44 based on the fact of lack of lubricity and low fuel pressure that kills them. They only happen to be now $1,100 bucks for a new pump. In either case in stock form I've seen both trucks fail just as quick but of course the CR injectors are more expensive... So what to do to protect what you got? Well the common story that seem to be sung by all shops, dealers, etc is good clean fuel. Most suggest you upgrade from the factory filter 10 micron to a 2 micron if possible. Then in both cases it good to meet the minimum pressure requirement for the CR is 9.5 PSI for the VP44 its 10.0 PSI.Another personal suggestion is a shot of fuel lubricant of some sort. (2 cycle oil, bio-diesel ,etc) In any case the CR engines have a CP3 pump which I got to admit is better that a VP44 but doesn't mean its excluded from the wear list. This pump is only fuel lubricated so if the fuel lubricity can keep up then it starts to wear. But think... There is only a edge filter before the injector... But that doesn't seem to take care of the problem. I better stop now and listen to the other comments...
  5. also be very aware that if you keep driving on wore out injectors it could lead to it just dieing or the engine going into full runaway mode... Don't drive it if you really don't have to be your going to needing to pull the injectors and have the pop tested at least to replace the ones that failed.
  6. 3K to 4K is a bit early... Even factory service manual suggest 7.5K miles... I'm changing every 10K but running Frantz ByPass filter... http://mopar.mopar1973man.com/personal/2002/frantz-filter/frantz-filter.htm
  7. They look good to me... Descent tread design... But expensive!
  8. 1/2" lines are worth it... Yeah the 1/2" AirDog fitting over a stock banjo...
  9. Exactly that... Go to Riggins, ID and enjoy nice weather like today at barely 50*F and then head to McCall, ID and go snowmobiling or skiing...
  10. Here is a map of where I live... Now Riggins, ID is about 1,800 Ft, Pollock is about 2,000 Fr, Home is 2,800 feet, New Meadows, ID is 4,000 and then McCall, ID is right at 5,100... So just going to town (depending on which direction from here could be -20*F (New Meadows) to +20*F (Riggins)
  11. That's if you still got that system hooked up... But I'm not using the stock pickup assembly any longer... But your right the stock pickup assembly does have a screen on it that helps protect the stock lift pump from damage. But the problem with the stock pickup assembly is that the trash remains in the tank to re plug the pickup assembly everytime. Some people have cut out the screen and put in a external filter so when debris is bad they can replace a filter and not have to drop the tank and clean the debris...
  12. Well as for shift points you could look into your line pressures and be sure you getting enough (updated valve body). Then re-do your band adjustment... Head over to the download tab and grab a book there is good information on trans stuff there... http://forum.mopar1973man.com/downloads.php?do=file&id=41 I've got another book to upload so hang around in time I'll get it in...
  13. Typically the return line is hooked to the filler neck of the fuel tank...
  14. Really good clutch from what I heard and rather good priced for economy reasons... But as for beyond that... I hope one of the vendors hops in and has more information on them...
  15. Actually a good question... If pre loading a stock filter housing its best to have the filter in place to be sure no trash enters the system... As for the oil filter you must be careful because anything that enter the center hole goes directly to the bearings and oil jets...
  16. All of us rejects should get together and unite with our knowledge and forums and share together... I sneak over to MWDC and check now and then on the 24V stuff but it seems rather slow at times...
  17. Wow! What a mouthful! I know I really should key in on this but I got to agree with Live Oak about DTR... As for DTR that was that I started at years ago... I got up to 2000 some odd post and then began to build my web site static pages. I was warn once for having a business card present on my web site... Like Huh??? Well about this time I found CF.com and did more updating to the site during the winter and came back with more to share but when I sent a PM to one of the guys to show what I had... I was banned instantly! I was banned for spamming! Huh? But oh well there loss now... There group can remain in the dark...
  18. I'm not much for the racing scene but I can give you this much... Most people use a mystery switch and lock up the TQ Conv right as it hits 2nd gear for better times in the quarter mile. I imagine the Trans temp gets rather hot unlock running the quarter mile..
  19. Yeap... Flman is right... The extra 2 valves tend to drop the combustion temps rapidily like at -20*F my pyro might show barely 200*F idling with 190*F worth of coolant. Yes my probe is pre-turbo. But at around 400*F which happens to be the flash point of the tar build up you start to either collect it because the cylinder temps are to cold or burn it off because you got it hot enough. Like my wood stove is really simular to the Cummins if I choke the air down to about 400*F the tar starts to build up on the stove walls and pipe walls. Then once you heat it up you burn all the trash out. Maybe that why I got a pyro on my stove...
  20. 11,000+ posts of working CF.com and I finally gave up and figure its time to build my own...
  21. Well to make you feel better talk to Cajflynn he's driving a 2001 Dodge with over 770K miles on it he's heading for the 1 million mark. Then there is Taz with over 620K miles on his 92 Dodge 12V. It's possible to do... Now as for your problem you could pull the grid heater lead on the battery. There should be 2 heavy gauge lead going from the driver side positive terminal down to the grid heater relays on the fender. Make sure you disconnect the grid heaters and they are non-functional. Now with a small burst of starting fluid in the air intake try starting the truck. If the truck starts to fire or starts then it for sure a fuel issue on the rail. Over pressure valve leaking, injector(s) leaking, etc. But basically there is a loss of rail pressure and the injectors can fire properly under 4,000 PSI...
  22. Like here is a good way to look at stock fuel system compare to aftermarket that has fix the problem for the most part... There is the AirDog Fitting (1/2" ID) over the top of a Stock banjo (6mm ID) line...
  23. Vald point... I say that there should be a pre-filter before the lift pump and then the filter after the lift pump... basically a full FASS or Airdog does this... But as for running any pump without a pre-filter is just asking for trouble...
  24. There is another common problem is the debris in the fuel... Common problem is that debris will wear the injectors out to the point that they don't close. It very difficult to explain the design of the CR electronic injector but basically there is a check ball that seats to hold the needle closed when the seat is erroded by debris then the fuel leak past this seat causing the needle leak out the nozzle. I had this shown to me at a injection shop in Lewiston, Idaho and was shock at how little damage needs to occur before the injector fails... This is a common issues for CR engine and its suggested to upgrade to 2-3 micron filters to prevent this problem...
