Towing - MPG/HP - advice
Ok... Here I'm loaded with nearly 3 cords of firewood... My lowest MPG is 14 MPG ever on reocrd. As for weight... (empty)Total Weight 7,300# = 4,440# Front Axle + 2,860# Rear AxleI'm running a Edge Comp on 5x5 and keep my boost below 5 PSI anf pyro under 600*F and I see 20+ MPG empty. But towing the only advise is to set your cruise at 55 MPh and leave it alone...
Chris Rock - How not to get your ___ kicked by the police!
Here something funny...
Clutch Install
Well the ring gear and the clutch are toast... But the great aprt is a SB Clutch comes with flywheel and ring gear... As for the rear seal it look good to me there is no oil weeping out... Look at the back side of the flywheel is it oily???
High idle and 3 cylinder idling
Should be... But you never know if there was a change in software....
Straight Pipe Exhaust - 2001 4x4 2500
I got pulled over a while back for no mud flaps... I look back in my mirrior and ask why his vehicle didn't have any... Funny he gave me a warning and left... As for being straight piped... Just use your head and you can control the loudness of your pipe. If you got a heavy foot you going to attract every police offier around. But if you cool hand Luke you can cruise right on by and smiley every time. When I'm in Boise, ID I can run right beside police officer and just smile without a second thought... But I keep my foot light on the throotle... Been straight piped for 6 years now and never had a issues about it yet!
Need front end parts for a 1992 Dodge Cummins 1 Ton 2WD
I'm posting this for Taz... He's looking for front end part for his truck which happens to be a 1992 Dodge cummins - 2WD - 1 Ton. He needs the tierods, center link, and the idler arm. With over 630K miles on the truck I can understand why they are wore out... But let help Taz get his truck running...
Anyone know how to tell if I allready have adjustable offset balljoints in my 2000?
Here is a article that has a pic of a offset balljoint but the article offer a solution to the death wobble as well... http://dodgetruckworld.tenmagazines.com/articles.asp?page=tenarticle&aid=3849
Here is my write up... http://mopar.mopar1973man.com/personal/2002/muffler-delete/muffler-delete.htm I was so cheap I even re-used my old clamps. I went a extra step with a piece of re-bar and bent some hangers and welded them to my pipe for extra support. (not in pic)
Rough idling and smoke
As for pressurizing the fuel tank take a rag and blow gun and pack it in the filler neck. Give it a burst of air where you feel it leaking back out through the rag. (1-2 PSI at the most). This will pressure the suction system and allow for a second person looking for fresh leaking fuel that is wet at connectors, flex tubing and such. This will pressurize the system to the VP44 and the return line so check those too while your at it... Hmmm... Valve adjustment could be a issue... If you want to clean the injectors hook that truck to a trailer and find a steep hill and get the pyrometer up to about 1,000 to 1,100 and make her work for awhile. This will cook the tips clean. Being that all injectors are protected by the Edge filter inside the connector tubes... As for starting a Cummins without grid heater on a cold morning isn't a good thing in my mind... Like right now my grid heater are hooked up and I use then on the first start of the day if parked outside. After that I don't even bother... But once spring comes and I'm sure the <30*F weather is gone I disconnect mine and forget about them for the rest of the summer. Then in the fall I hook them up again... As for 0*F and colder weather I seen my truck nearly refuse to start on a single grid heater run... After two cycles it runs but still missing a beat or two for a few seconds... But thankfully enough this year we are seeing global warming (climate change)...
2nd vp44 still no pump fuel to injectors
Head over to the VP44 error code list and read some of the diagnostic it might give a clue... http://mopar.mopar1973man.com/cummins/2ndgen24v/vp44-replace/vp44-error.htm
Thankful for a fuel pressure gauge!
Well... Its possible it a bad tank of fuel or the station you buying form has poor filters at the pump. At least I buy fuel with confindence because I know the owner of my local store and understand when and what type of filters he uses on his pumps. But when I travel out and about I normal hit the bigger diesel places like flying J or simular with high volume of diesel traffic this insures the fuel is fresh and the pump filters are kept up to par. Stop in a quiet mom and pop place and take a risk for cheaper fuel...
Another lift pump question
I'm going to be totally honest and straight forward... Back in 2002 if you asked me about a Cummins diesel I would give you a weird look and go huh? Well all my knowledge is from read post on forum, asking questions, and talking to people. Now the web site started out really small back in 2003 with basically write ups of my BOMBs and common issues like gauges, and fuel pressure. By 2007 I bought my domain then added a forum and extend the web site even more. Now in the late 2009 I had to upgrade the server because of the amount of traffic. This web site is basically collection of information found on the internet that started out being just my personal notes then other had get idea or suggestion so they came forward and helped as well. As these new tidbits come, or I repair my truck, or other trucks, I've learned from past experiences. So as I do something new i learn from these experiences so I either update a current write up or I'll create a new write up. I'm not ASE certified... I did not go to college for this... But I'm be turning wrenches and doing repairs on my own vehicles since I was 15 years old. I still own my first vehicle which is a 1973 Dodge Charger SE. This is where is started from. Then led me down the rock bumpy road of visiting wrecking yards, part houses, talking to people, and learning. I never given up or quit I just kept going forward knowing one thing... "It worked before... It's broke now... So I can't hurt it any more that what it is!" always kept the logical mind about myself and kept going... Sorry to steal the thread...
its beat to death but i gotta ask , lift pump issues uhhg
I've seen brand new Carter pumps, Campaign Pumps, and yes even a Carter 4601 fail right out of the box... Make you sick to hook up a brand new pump and it performing worse than the one you just replaced! :banghead: Yes I've been here many of time and that is one of the reason I pushed for the AirDog and bit the bullet... So that's my view on it but doesn't mean its the right choice for you... I'm going to guess a WIF sensor??
Hmmm... That's odd... I'm running AirDog 150 with 2 micron filter and only change the filter once a year (30K miles). Even then I was only losing 3 PSI...
I would check for error codes. Because if the pump is internal shorted or internal open then there would error code set. But check the pump resistance and it should be no higher than 200 ohm and no less than 20 ohms. Check the ground behind the starter. This is the location of the ECM ground...
ECM controls the lift pump directly... There is no relay in between the two...
Big line question
Not needed... Just squeeze the 2 blue tabs inward and lightly pull the line... My trick is un-screw the sender nut and then drop the tank down easy allowing the sender to hang. Then you can get right up there and squeeze the tab and pull ti loose...
Big line question
Doesn't... The AD doesn't use that line...
Yea... More I keerp reading this the more i keep thinking its a air issue. Because the fact it only happens with cold starts. If a constant issues that never went away I would lean toward the injectors more... Chasing a air leak is rather tough at times... If its on the low pressure system you might pressurize the fuel tank and have some one look over the system for wet spots.If its on the high pressure side you might have to really look for damp spots, check connector o-ring, etc...
Best online spot for OEM lift pump and Oil question
It was only a extra $20 bucks for me to upgrade from 100 to 150... Why not...
Factory fuse box in cab?
Make sure to get some pics of how you did it I might do the same thing too!
50*F is not cold enough to require the grid heaters... Hmmm... Do you have a bad O-ring on the connector tubes? Air leaking back into the system and loosing prime?
Power Steering Flush on a 3rd Gen.
http://mopar.mopar1973man.com/cummins/3rdgen/ps-flush/ps-flush.htm
Additional Fuel Filter Installs on a 3rd Gen
http://mopar.mopar1973man.com/cummins/3rdgen/fuel-filter/addon-filter.htm
Coolant Flush on a 3rd Gen
http://mopar.mopar1973man.com/cummins/3rdgen/coolant-flush/coolant-flush.htm
